Folger Tech Prusia i3 Build - Z Axis End Stop Not Functioning February 11, 2015 12:41PM |
Re: Folger Tech Prusia i3 Build - Z Axis End Stop Not Functioning February 11, 2015 02:15PM |
Re: Folger Tech Prusia i3 Build - Z Axis End Stop Not Functioning February 11, 2015 02:31PM |
Re: Folger Tech Prusia i3 Build - Z Axis End Stop Not Functioning February 11, 2015 03:43PM |
#ifndef ENDSTOPPULLUPS // fine Enstop settings: Individual Pullups. will be ignord if ENDSTOPPULLUPS is defined #define ENDSTOPPULLUP_XMAX #define ENDSTOPPULLUP_YMAX #define ENDSTOPPULLUP_ZMAX #define ENDSTOPPULLUP_XMIN #define ENDSTOPPULLUP_YMIN //#define ENDSTOPPULLUP_ZMIN #endif #ifdef ENDSTOPPULLUPS // #define ENDSTOPPULLUP_XMAX // #define ENDSTOPPULLUP_YMAX // #define ENDSTOPPULLUP_ZMAX #define ENDSTOPPULLUP_XMIN #define ENDSTOPPULLUP_YMIN #define ENDSTOPPULLUP_ZMIN #endif
#ifndef ENDSTOPPULLUPS // fine Enstop settings: Individual Pullups. will be ignord if ENDSTOPPULLUPS is defined #define ENDSTOPPULLUP_XMAX #define ENDSTOPPULLUP_YMAX #define ENDSTOPPULLUP_ZMAX #define ENDSTOPPULLUP_XMIN #define ENDSTOPPULLUP_YMIN #define ENDSTOPPULLUP_ZMIN #endif #ifdef ENDSTOPPULLUPS #define ENDSTOPPULLUP_XMAX #define ENDSTOPPULLUP_YMAX #define ENDSTOPPULLUP_ZMAX #define ENDSTOPPULLUP_XMIN #define ENDSTOPPULLUP_YMIN #define ENDSTOPPULLUP_ZMIN #endif
// ENDSTOP SETTINGS: // Sets direction of endstops when homing; 1=MAX, -1=MIN #define X_HOME_DIR -1 #define Y_HOME_DIR -1 #define Z_HOME_DIR -1
// ENDSTOP SETTINGS: // Sets direction of endstops when homing; 1=MAX, -1=MIN #define X_HOME_DIR 1 #define Y_HOME_DIR 1 #define Z_HOME_DIR -1
Re: Folger Tech Prusia i3 Build - Z Axis End Stop Not Functioning February 11, 2015 08:50PM |
Re: Folger Tech Prusia i3 Build - Z Axis End Stop Not Functioning February 11, 2015 10:12PM |
#define INVERT_X_DIR true // for Mendel set to false, for Orca set to true #define INVERT_Y_DIR false // for Mendel set to true, for Orca set to false #define INVERT_Z_DIR true // for Mendel set to false, for Orca set to true #define INVERT_E0_DIR false // for direct drive extruder v9 set to true, for geared extruder set to false #define INVERT_E1_DIR false // for direct drive extruder v9 set to true, for geared extruder set to false #define INVERT_E2_DIR false // for direct drive extruder v9 set to true, for geared extruder set to false
Re: Folger Tech Prusia i3 Build - Z Axis End Stop Not Functioning February 12, 2015 12:15PM |
Re: Folger Tech Prusia i3 Build - Z Axis End Stop Not Functioning June 05, 2015 10:03AM |
Re: Folger Tech Prusia i3 Build - Z Axis End Stop Not Functioning June 07, 2015 12:47AM |
Re: Folger Tech Prusia i3 Build - Z Axis End Stop Not Functioning June 07, 2015 01:02AM |
Re: Folger Tech Prusia i3 Build - Z Axis End Stop Not Functioning June 07, 2015 01:58PM |
