Extruder qeustion July 25, 2010 02:11PM |
Re: Extruder qeustion July 25, 2010 04:58PM |
Re: Extruder qeustion July 25, 2010 06:06PM |
Admin Registered: 19 years ago Posts: 7,883 |
Re: Extruder qeustion July 25, 2010 09:09PM |
Re: Extruder qeustion July 26, 2010 04:57AM |
Re: Extruder qeustion July 26, 2010 05:45AM |
nophead
Normally the plug is about 5-10mm in the PTFE insulator. That is very slippery, so as long as you have a seem-less joint with the brass, the extruder should be able to push it.
Re: Extruder qeustion July 26, 2010 07:46AM |
Re: Extruder qeustion July 26, 2010 08:14AM |
I just picked up my package from the Zollamt (customs) this morning with two of Brian Reifsnider's Hybrid design extruder hot ends (with 0.5 mm nozzles). However, I want to use them for my 2nd Mendel where I also want to try Adrian's geared extruder design as I am tired of having to remove the motor and the gear every time I need to work on the hot end. With Adrian's design it would appear that this is not necessary. Plus my 2nd Mendel will be made out of ABS RP parts so I can finally add a heated bed for printing ABS. My current Mendel (that is almost printing) has PLA RP parts and as such can not really be used to print ABS parts.|
Re: Extruder qeustion July 26, 2010 10:53AM |
Re: Extruder qeustion July 26, 2010 07:08PM |
sooo what dissolves epoxy
Re: Extruder qeustion July 26, 2010 08:38PM |
Re: Extruder qeustion July 28, 2010 12:20AM |
Re: Extruder qeustion July 28, 2010 02:26AM |
DanielG
PEEK=fail, PTFE=pass
Re: Extruder qeustion July 28, 2010 08:41AM |
Re: Extruder qeustion July 28, 2010 12:33PM |
Re: Extruder qeustion August 03, 2010 12:42AM |
