MendelMax 1.? Build Instructions February 17, 2016 06:37PM |
Re: MendelMax 1.? Build Instructions February 18, 2016 03:51AM |
Admin Registered: 13 years ago Posts: 7,005 |
Re: MendelMax 1.? Build Instructions February 18, 2016 08:12AM |
Re: MendelMax 1.? Build Instructions February 18, 2016 11:34AM |
Re: MendelMax 1.? Build Instructions February 19, 2016 06:02AM |
Re: MendelMax 1.? Build Instructions February 22, 2016 11:19AM |
Re: MendelMax 1.? Build Instructions February 25, 2016 02:35PM |
Re: MendelMax 1.? Build Instructions March 11, 2016 05:40PM |
Re: MendelMax 1.? Build Instructions March 11, 2016 07:52PM |
Re: MendelMax 1.? Build Instructions March 13, 2016 12:33PM |
Dust
Endstops are normally wired so that if they are disconnected they are triggered
You have no max endstops... so they are disconnected. They should be disabled
eg in marlin find //#define DISABLE_MAX_ENDSTOPS and remove the two // at the front
Yes if axis run the wrong way you can either invert in firmware, or rewire your steppers (or just turn the 4 wire stepper plug around 180 degrees, only do this while power is off)
eg in firmware find
#define INVERT_X_DIR false and change to true to invert the X direction.
