RepRap software does not connect to electronics
Posted by jorenz
March 14, 2011 04:55PM
I have installed RepRap software and do not get a temp reading. Repsnapper works, but I would like to get RepRap to work. and cannot seem to find the problem. Do I have to turn on the RepRap software? I suspect it is one of the settings but I am using the same settings com4 and 19200 for Repsnapper. Any ideas?
Re: RepRap software does not connect to electronics
March 15, 2011 11:07PM
The RepRap Host software requires the standard 5D firmware for proper temp reading.
Help improve the RepRap wiki!
Just click "Edit" in the top-right corner of the page and start typing.
Anyone can edit the wiki!
March 19, 2011 06:11PM
Thanks for the information. When using Repsnapper x,y and z move, however when attempting to run the gcode for a part the xyz does a little dance and then stops. It does not continue to run the program. Does Repsnapper also require the 5D firmware? I am using the Tech zone monolithic board. Thanks. JHR
