problem.halfway printing, extruder change position
Posted by nonaak
April 23, 2011 11:17AM
Hallo all,
First sorry for my bad. English.
I make a Mendel with Gen3 elektroniks and pololu stepper controllers, and use Repstrapper software.
My problem is: If i print a part the first 15 layers or so, Its go super good, but after the extruder take a other (X Y) position and continues the print.
I tray with a other part that have more then 30 layers and every thing go good.
So one part have problems and a other part (with te same height) go wrong
I load a STL file in to Repsnapper, i dont use steinforce ( i dont now how to use steinforce yet).
Will it be a setting wrong in Repsnapper?
Please help
Gr nonaak
First Gen Mendel made by Adrian Bowyer
Controller: RAMPS 1.4
Extruder: Greg's Wade Universal Accessible Extruder
Firmware :Marlin
MendelMax extra groot
RAMPS 1.4 grafisch display (diy)
Marlin
E3D v6
220V hotbed (diy)
Lang niks in 3Dprinting gedaan, begin nu weer hobby op te pakken.
Weer begonnen met:
Prusa Graber i3 "wood"
RAMPS 1.4 (mks tft28 v1.2 smart touch)
Marlin
E3D extruder v6 lite
Re: problem.halfway printing, extruder change position
April 23, 2011 11:46AM
If the tool path display in repsnapper looks good, then you might be missing steps in the x and y stepper motors.
April 23, 2011 03:06PM
thanks for the replay.
its not that, i ingrase the current of the pololu stepper driver. And have the same problem.
Gr nonaak
Firmware :Marlin
Marlin
E3D v6
220V hotbed (diy)
Weer begonnen met:
Marlin
April 23, 2011 06:30PM
Is your pulley slipping on the motor shaft?
April 23, 2011 07:25PM
Most likely that the stepper driver is overheating. This may cause you to loose steps. Are you motors hot?
