Millennium Peregrine – High Speed Large Format 3D Printer Project - Detailed Build Diary March 21, 2018 09:08PM |
Re: Millennium Peregrine – High Speed Large Format 3D Printer Project - Detailed Build Diary March 21, 2018 09:14PM |
Re: Millennium Peregrine – High Speed Large Format 3D Printer Project - Detailed Build Diary March 21, 2018 09:15PM |
Re: Millennium Peregrine – High Speed Large Format 3D Printer Project - Detailed Build Diary March 21, 2018 10:39PM |
Re: Millennium Peregrine – High Speed Large Format 3D Printer Project - Detailed Build Diary March 21, 2018 10:45PM |
Re: Millennium Peregrine – High Speed Large Format 3D Printer Project - Detailed Build Diary March 22, 2018 11:47AM |
Re: Millennium Peregrine – High Speed Large Format 3D Printer Project - Detailed Build Diary March 22, 2018 12:05PM |
Re: Millennium Peregrine – High Speed Large Format 3D Printer Project - Detailed Build Diary March 22, 2018 11:21PM |
Re: Millennium Peregrine – High Speed Large Format 3D Printer Project - Detailed Build Diary March 23, 2018 12:27AM |
Re: Millennium Peregrine – High Speed Large Format 3D Printer Project - Detailed Build Diary March 29, 2018 10:40PM |
Re: Millennium Peregrine – High Speed Large Format 3D Printer Project - Detailed Build Diary April 02, 2018 12:28PM |
Re: Millennium Peregrine – High Speed Large Format 3D Printer Project - Detailed Build Diary April 02, 2018 12:54PM |
Re: Millennium Peregrine – High Speed Large Format 3D Printer Project - Detailed Build Diary April 02, 2018 10:18PM |
Re: Millennium Peregrine – High Speed Large Format 3D Printer Project - Detailed Build Diary April 02, 2018 10:40PM |
Re: Millennium Peregrine – High Speed Large Format 3D Printer Project - Detailed Build Diary April 03, 2018 12:03AM |
Re: Millennium Peregrine – High Speed Large Format 3D Printer Project - Detailed Build Diary April 04, 2018 09:48PM |
Re: Millennium Peregrine – High Speed Large Format 3D Printer Project - Detailed Build Diary April 05, 2018 09:24AM |
CinciCliff
@ the_digital_dentist
For our heated build enclosure ABS printer, I am thinking about using a localized closed loop air cooling system for the motors, extruder, ball nuts, etc. That would be a great blower to help keep things cool and maybe less complexity than water cooling?
Re: Millennium Peregrine – High Speed Large Format 3D Printer Project - Detailed Build Diary April 06, 2018 09:05PM |
Re: Millennium Peregrine – High Speed Large Format 3D Printer Project - Detailed Build Diary February 21, 2019 08:13AM |
Re: Millennium Peregrine – High Speed Large Format 3D Printer Project - Detailed Build Diary February 27, 2019 08:35PM |
Re: Millennium Peregrine – High Speed Large Format 3D Printer Project - Detailed Build Diary February 28, 2019 03:26PM |
Re: Millennium Peregrine – High Speed Large Format 3D Printer Project - Detailed Build Diary February 28, 2019 11:50PM |
Re: Millennium Peregrine – High Speed Large Format 3D Printer Project - Detailed Build Diary March 01, 2019 02:36AM |
CinciCliff
Cool - Thanks for sharing that the E3D SuperVolcano is out! Sanjay showed us this at MRRF and it looks like a great idea! We will order one to test.
This looks like a really nice design! I appreciate the one piece nozzle. Our prototype uses standard V6 nozzle mated up to an M6 threaded rod sleeve. We added a screwdriver slot at the end of our sleeve - but this has been challenging to remove from the block once we gum it up with filament.
With a 50 mm block length, this looks more practical to mount to a printer than the 80 mm block we built.
The SuperVolcano might get us closer to the target Millennium Peregrine flow rate. SuperVolcano is rated for 6600 mm^/min (46 mm/sec for 1.75 mm filament). Our target is 9600 mm^/min (66.5 mm/sec for 1.75 mm filament).
Re: Millennium Peregrine – High Speed Large Format 3D Printer Project - Detailed Build Diary March 01, 2019 10:21AM |
Re: Millennium Peregrine – High Speed Large Format 3D Printer Project - Detailed Build Diary March 11, 2019 09:49PM |
Re: Millennium Peregrine – High Speed Large Format 3D Printer Project - Detailed Build Diary March 11, 2019 09:59PM |
Re: Millennium Peregrine – High Speed Large Format 3D Printer Project - Detailed Build Diary March 11, 2019 10:13PM |
Re: Millennium Peregrine – High Speed Large Format 3D Printer Project - Detailed Build Diary March 11, 2019 11:35PM |
Re: Millennium Peregrine – High Speed Large Format 3D Printer Project - Detailed Build Diary March 11, 2019 11:45PM |
