Printtable July 11, 2016 04:36AM |
Re: Printtable July 12, 2016 04:26AM |
Re: Printtable July 12, 2016 05:30AM |
Re: Printtable July 12, 2016 05:58AM |
Re: Printtable August 08, 2016 08:09AM |
Re: Printtable December 10, 2016 03:00PM |
Re: Printtable December 10, 2016 03:03PM |
Re: Printtable January 15, 2017 03:24PM |
Re: Printtable February 03, 2017 06:20PM |
Re: Printtable February 04, 2017 12:21AM |
Re: Printtable February 04, 2017 12:32AM |
Re: Printtable February 04, 2017 03:18AM |
n9jcv
rklauco ,
I am just gonna throw 2cents out there. If it were me, I think I would remove the bearings at the top of the z lead screws. Just let them float. That will eliminate the noise and from what I have read, z wobble is worse with constrained lead screws/5mm shaft.
b
Re: Printtable February 04, 2017 03:36AM |
Yep, that may be about right.Quote
n9jcv
Wow, this seems really cool. Like it has been out for a while but this is the first I have seen or heard. Seems like you have been working on it for 6+ months rklauco?
It's pretty good. I was thinking about using some screws to stiffen it, but when I tighten the cam shaft mechanisms, the construction is quite rigid. So from my perspective, it's solid enough - I don't see any reason to make it stiffer.Quote
n9jcv
Now that yours is together, how stable is the cube? Will there be any wobble or is it pretty steady?
To cut the bottom part for the spool holder was a STUPID idea - so please, don't do itQuote
n9jcv
I was contemplating NOT cutting out the center of the table, leaving the bottom and top fully enclosed in the nice table tops. Of course that would mean a different design, but I think it would wind up looking nice.
Standard (cheapest) lm8uu. The whole partlist is here.Quote
n9jcv
Are you using lm8uu or igus?
Simple answer - Weight. The mirror alone is 4.5kg. Now add silicone, heater wire, any construction able to hold the 4.5kg and it's clear. Another reason is that if I was about to use cantilevered bed, I would have to use at least 2 bearings on Z axis, probably not LM8UU, but LM12UU (or even LU). Add a VERY beefy motor to the list (as the small NEMA17 would not be able to move it a bit) and you will jump with the price and the construction problems, too.Quote
n9jcv
why did you go with lead screws in 4 corners vs just having 1 lead screw with 2 rods and a cantilevered bed?
I am following the same approach - cam shafts instead of drilling holes and screwing. It's especially useful now in the design part, when it's relatively easy to disassemble and reassemble the whole machine. If I used wood screws, I would have to buy new table 4 times alreadyQuote
n9jcv
The author evidently has a new version that does not require drilling holes in the table, maybe that is the updated version you speak of. Other than the author and you, I have not found others that have built these or blogged about them.
Thanks. I constantly work on it - now that it actually prints it's much more interestingQuote
n9jcv
Keep going, I am interested to hear how well you can get yours working.
Re: Printtable February 04, 2017 03:41AM |
ThanksQuote
n9jcv
by the way, I love the sketchup, that is AWESOME !!!! I don't think I could do that that is a very impressive sketch. So far I have just modeled individual parts, never an entire machine.
Re: Printtable February 04, 2017 05:41PM |
Re: Printtable February 04, 2017 10:36PM |
Re: Printtable February 04, 2017 10:43PM |
Re: Printtable February 05, 2017 01:26AM |
Re: Printtable February 05, 2017 08:18AM |
Re: Printtable February 05, 2017 09:18AM |
Re: Printtable February 13, 2017 03:02PM |
Re: Printtable February 13, 2017 03:07PM |
Re: Printtable February 21, 2017 03:48PM |
Re: Printtable February 28, 2017 01:52PM |
Re: Printtable March 02, 2017 04:10PM |
Re: Printtable May 10, 2017 09:49PM |
