New fixed motor movement system? September 05, 2018 12:19AM |
Re: New fixed motor movement system? September 05, 2018 12:54AM |
Re: New fixed motor movement system? September 05, 2018 02:48AM |
Admin Registered: 16 years ago Posts: 13,891 |
Re: New fixed motor movement system? September 05, 2018 07:46AM |
Re: New fixed motor movement system? September 05, 2018 01:56PM |
Re: New fixed motor movement system? September 06, 2018 12:47AM |
dX = dA ( red belt ) dY = -dA + dB ( blue )
Re: New fixed motor movement system? September 06, 2018 11:37AM |
Re: New fixed motor movement system? September 06, 2018 06:07PM |
o_lampe
Now it seems right, but the kinematic is a mix of H-Bot and CoreXY.
I don't know if it's worthadding extra length to the blue belt and get more stretch/ringing there, just to fight extruder tilt. ( which is neglectible when using linear rails and carriers)
edit: I just saw that both belts are equal length, so forget my above comment. It's even worse: both belts are extra long which is a big trade off IMHO.
Trying to figure out a belt system that has a cartesian configuration (unlike the h-bot and coreXY) so that there's no unbalanced forces being applied where you don't want them to (for example, rotational forces), but without having the motors move like in a traditional cartesian configurationQuote
the_digital_dentist
What problem is being solved here?
Re: New fixed motor movement system? September 06, 2018 10:24PM |
Re: New fixed motor movement system? September 07, 2018 09:14AM |
the_digital_dentist
Do these "unbalanced forces" cause problems?
With careful positioning of pulleys, a single-level corexy mechanism could be made free of "unbalanced forces", I think.
OTOH< if you want to try to come up with a new belt layout...
Re: New fixed motor movement system? September 16, 2018 10:59PM |
