Not sure whether to put this here or in repraphost.
I've been trying to switch to skeinforge as it produces better pathing for many parts (such as PLA Bushings, for some reason RRH produces a solid flat layer midway up the print). Unfortunately, even after setting up the firmware correctly for v40, I get problems when sending data- using RRH to print Skeinforge gcodes, I get errors stating that a line was sent without a checksum, and it gives me the first 1-10 characters of the line, followed by the extruder heat shutting down. It never does this with gcode generated with repraphost. Does anyone have a better method for getting the gcode to the printer so I can start testing and calibrating Skeinforge? This error only appears to occur with the modified firmware- i.e. acceleration off, E0_STEPS_PER_MM set for feedstock rather than extruded length.
