I made some enhancements to the Export module
June 13, 2011 03:53PM
Hi all,
I've just committed some changes to my github fork of Skeinforge which adds some simple, but useful, features to the Export module:
  • Add Profile To File Extension
  • Archive Used Profile As Zip
  • Export Profile Values As CSV File
  • Add Descriptive Extension
  • Add Timestamp Extension
Using these options means that each time a STL is processed one can:
  • see which profile was used (from the filename),
  • see which key values were used (from the filename),
  • see all the profile values (from the csv),
  • recreate the profile (from the zip),
  • and ensure sure that all gcode files are unique and not overwritten each time (with timestamp)
I've written up a bit more, with screenshots, on my blog.
Let me know if it's useful, and of course if you experience any problems.
Cheers,
Gary
garyhodgson.com/reprap | reprap.development-tracker.info | thingtracker.net
Re: I made some enhancements to the Export module
June 14, 2011 02:35PM
I have never tried changing any part of SF before, do I just download your module and put it in the SF folder?
__________________________________________________________________________
Experimenting in 3D in New Zealand
June 14, 2011 03:11PM
All the changes are in the export.py file, so you should be able to replace this file:
skeinforge_application/skeinforge_plugins/craft_plugins/export.py
with this one:
https://raw.github.com/garyhodgson/skeinforge/dfc7b05bcca0917ac8ae885b4d34c5b2a823ac26/skeinforge_application/skeinforge_plugins/craft_plugins/export.py
I'd make a backup just in case. Let me know if you have problems.
Cheers,
Gary
June 14, 2011 05:34PM
Done, thanks for that. Being able to have the profile name on the Gcode helps me keep track of all the profiles I have used. I was manually adding this info before.
June 30, 2011 04:13PM
I started using it too and just wanted to say "Thanks" ! smiling smiley
June 30, 2011 06:24PM
Thank You very much. I have it also in my version of SF.
Very useful...
Manufacturer of low tolerance Filaments PLA, ABS, ASA, PETG, TPU, PA, PVA,
[www.miafilament.com]
[github.com]
