Nozzle drag June 27, 2011 03:29PM |
Re: Nozzle drag June 27, 2011 04:33PM |
Re: Nozzle drag June 27, 2011 05:51PM |
Re: Nozzle drag June 27, 2011 06:16PM |
Admin Registered: 17 years ago Posts: 7,879 |
Re: Nozzle drag June 27, 2011 06:22PM |
Re: Nozzle drag June 27, 2011 09:13PM |
Re: Nozzle drag June 27, 2011 09:22PM |
Re: Nozzle drag June 27, 2011 09:27PM |
Re: Nozzle drag June 27, 2011 09:33PM |
Re: Nozzle drag June 27, 2011 09:54PM |
Re: Nozzle drag June 27, 2011 11:06PM |
Re: Nozzle drag June 28, 2011 12:02AM |
Re: Nozzle drag June 28, 2011 03:57PM |
Re: Nozzle drag June 28, 2011 04:34PM |
FFF Settings Calculator | Gcode post processors | Geometric Object Deposition Tool Blog |
Tantillus.org | Mini Printable Lathe | How NOT to install a Pololu driver |
Re: Nozzle drag June 28, 2011 04:47PM |
Re: Nozzle drag June 28, 2011 05:01PM |
Re: Nozzle drag June 28, 2011 05:10PM |
Re: Nozzle drag June 28, 2011 05:27PM |
Re: Nozzle drag June 28, 2011 06:34PM |
Re: Nozzle drag June 28, 2011 06:53PM |
Re: Nozzle drag June 28, 2011 08:42PM |
Re: Nozzle drag June 28, 2011 09:06PM |
Re: Nozzle drag June 29, 2011 03:01AM |
Re: Nozzle drag June 29, 2011 03:09AM |
http://fabmetheus.crsndoo.com/wiki/index.php/Skeinforge_Fill
Infill Width over Thickness (ratio)
Default: 1.5
This parameter tells skeinforge how thick the extrusion is expected to be in relation to the layer thickness. The effect of increasing this is to cause the lines that create the infill to be further apart. So if your solid base infill is sparse decrease the value. If solid infill appears too full increase the value. Infill Perimeter Overlap (ratio) also effects solid infill by shortening the lines. If you look at a solid base layer that has been laid down on glass or tape without a raft you can often see how the plastic flows and see which to alter for the best result.
Re: Nozzle drag June 29, 2011 03:36AM |
Re: Nozzle drag June 29, 2011 08:38AM |
Re: Nozzle drag June 29, 2011 09:19AM |
Re: Nozzle drag June 29, 2011 09:29AM |
Re: Nozzle drag June 29, 2011 09:36AM |
Re: Nozzle drag June 29, 2011 03:40PM |
