Sanguinololu 1.3b ? March 03, 2012 03:02PM |
Re: Sanguinololu 1.3b ? March 04, 2012 09:58AM |
Re: Sanguinololu 1.3b ? March 04, 2012 11:41AM |
Admin Registered: 17 years ago Posts: 7,879 |
Re: Sanguinololu 1.3b ? March 07, 2012 08:35AM |
Re: Sanguinololu 1.3b ? May 27, 2012 12:31AM |
Re: Sanguinololu 1.3b ? June 02, 2012 09:56AM |
Re: Sanguinololu 1.3b ? June 22, 2012 12:43AM |
Admin Registered: 15 years ago Posts: 1,470 |
Help improve the RepRap wiki!
Just click "Edit" in the top-right corner of the page and start typing. Anyone can edit the wiki! |
Sanguino-newby
Re: Sanguinololu 1.3b ? June 22, 2012 03:15PM |
Re: Sanguinololu 1.3b ? June 22, 2012 04:14PM |
Sanguino-newby
Re: Sanguinololu 1.3b ? June 22, 2012 05:12PM |
Re: Sanguinololu 1.3b ? June 22, 2012 05:19PM |
Sanguino-newby
Re: Sanguinololu 1.3b ? June 22, 2012 05:41PM |
Re: Sanguinololu 1.3b ? June 22, 2012 06:03PM |
Re: Sanguinololu 1.3b ? June 22, 2012 06:09PM |
/******************************************************************************************************* * Sanguino/RepRap Motherboard v1.2 pinout * * ATMega644P * * +---\/---+ * LED (D 0) PB0 1| |40 PA0 (AI 0 / D31) Z_MAX_PIN * (D 1) PB1 2| |39 PA1 (AI 1 / D30) Z_MIN_PIN * SD_CARD_WRITE INT2 (D 2) PB2 3| |38 PA2 (AI 2 / D29) Z_ENABLE_PIN * SD_CARD_DETECT PWM (D 3) PB3 4| |37 PA3 (AI 3 / D28) Z_DIR_PIN * SD_CARD_SELECT PWM (D 4) PB4 5| |36 PA4 (AI 4 / D27) Z_STEP_PIN * SPI MOSI (D 5) PB5 6| |35 PA5 (AI 5 / D26) Y_MAX_PIN * SPI MISO (D 6) PB6 7| |34 PA6 (AI 6 / D25) Y_MIN_PIN * SPI SCK (D 7) PB7 8| |33 PA7 (AI 7 / D24) Y_ENABLE_PIN * RST 9| |32 AREF * VCC 10| |31 GND * GND 11| |30 AVCC * XTAL2 12| |29 PC7 (D 23) Y_STEP_PIN * XTAL1 13| |28 PC6 (D 22) Y_DIR_PIN * usb comm RX0 (D 8) PD0 14| |27 PC5 (D 21) TDI X_MAX_PIN * usb comm TX0 (D 9) PD1 15| |26 PC4 (D 20) TDO X_MIN_PIN * RS485 comm INT0 RX1 (D 10) PD2 16| |25 PC3 (D 19) TMS X_ENABLE_PIN * RS485 comm INT1 TX1 (D 11) PD3 17| |24 PC2 (D 18) TCK X_DIR_PIN * TX_ENABLE_PIN PWM (D 12) PD4 18| |23 PC1 (D 17) SDA (E_STEP_PIN) * RX_ENABLE_PIN PWM (D 13) PD5 19| |22 PC0 (D 16) SCL (E_DIR_PIN) * PS_ON_PIN PWM (D 14) PD6 20| |21 PD7 (D 15) PWM X_STEP_PIN * +--------+ * ******************************************************************************************************
#define Y_STEP_PIN 23
Re: Sanguinololu 1.3b ? June 22, 2012 06:37PM |
Sanguino-newby
Re: Sanguinololu 1.3b ? June 23, 2012 04:54AM |
HI MrAlvin, Thanks again for the info. I note from this pinout diagram that the device shown only has 40 pins, whereas the device I'm using has 44. I have tried previously what you suggest, to create the 63 in configuration.h and then add the 63 definitions to pins.h This failed to work as well !!!!! Most frustrating. As far as how many pins are different, virtually ALL the pins are different between the two device formats. It's not just a case of changing one or two of them, it's all of them (excluding supply pins which aren't defined) I think I have been a bit unreasonable in my way of describing things, so it must be difficult for people to understand/grasp the setup. The only thing I can suggest, is that, if you have Eagle, check out the device in the Atmel library labelled 644A. This is the same pinout as the one on the board. Thanks again for your assist. Regards,
Sanguino-newby
Re: Sanguinololu 1.3b ? June 23, 2012 04:59AM |
Re: Sanguinololu 1.3b ? June 23, 2012 05:11AM |
Re: Sanguinololu 1.3b ? June 23, 2012 06:24AM |
