sanguinololu 1.3a communication problems January 29, 2013 02:46PM |
Re: sanguinololu 1.3a communication problems February 01, 2013 09:10AM |
Re: sanguinololu 1.3a communication problems October 21, 2013 10:41PM |
Re: sanguinololu 1.3a communication problems June 21, 2014 07:08AM |
Re: sanguinololu 1.3a communication problems June 28, 2014 09:27AM |
I am having the same issue.. Using Windows 8.1 and another machine with Windows 7 i keep getting avrdude: stk500_getsync(): not in sync: resp=0x00
I followed all instructions.
I am using Arduino 1.0.5 -r2
i have downloaded the sanguinololu software. When i connect the board to the usb i can see it in the device manager listed as "USB Serial Port (COM4)" and in Arduino i see it. I have selected Sanguinololu 1284p 16mhz board and "Arduino as ISP" programmator but still get the message. I tried hitting the resset button, but no result.
I should mention that when i hit the reset button i get slightly diffetenr resp. Each time it is different, for example resp=0xd5, 0xd1, 0xd7 etc.
Can someone advise me how to proceed?
Re: sanguinololu 1.3a communication problems September 07, 2014 03:58PM |
Re: sanguinololu 1.3a communication problems September 08, 2014 08:21AM |
Admin Registered: 13 years ago Posts: 7,002 |
Re: sanguinololu 1.3a communication problems September 08, 2014 01:40PM |
Re: sanguinololu 1.3a communication problems September 08, 2014 09:04PM |
Re: sanguinololu 1.3a communication problems September 09, 2014 04:29AM |
Re: sanguinololu 1.3a communication problems September 09, 2014 05:38AM |
Re: sanguinololu 1.3a communication problems September 09, 2014 07:54AM |
Re: sanguinololu 1.3a communication problems September 09, 2014 04:43PM |
Re: sanguinololu 1.3a communication problems September 10, 2014 06:55PM |
Re: sanguinololu 1.3a communication problems October 27, 2016 02:30AM |
JOguino
First.
Dotn use Arduino 1.0.5. Use 1.0.1. (i've experimented with about 5 different IDE versions 1.0.5 never worked for me... 1.0.1 did though.)
download the software to 1.0.1 just as you did for 1.0.5.
here's where you can download all previous versions of arduino software
[code.google.com]
Second dont select "Arduino as ISP"
If you're connected to your computer directly use "parallel programmer".
