compile troubles June 08, 2015 11:43AM |
Re: compile troubles June 09, 2015 04:56AM |
Re: compile troubles June 10, 2015 01:31AM |
Re: compile troubles June 14, 2015 01:50AM |
Re: compile troubles June 15, 2015 01:23AM |
Re: compile troubles June 15, 2015 05:50AM |
In file included from Marlin.h:21:0, from temperature.h:24, from ultralcd.cpp:1: ultralcd_st7920_u8glib_rrd.h: In function 'void ST7920_SWSPI_SND_8BIT(uint8_t)': fastio.h:45: error: 'DIOLCD_PINS_D4_RPORT' was not declared in this scope #define _WRITE(IO, v) do { if (&(DIO ## IO ## _RPORT) >= (uint8_t *)0x100) {_WRITE_C(IO, v); } else {_WRITE_NC(IO, v ); }; } while (0) ^ fastio.h:68:23: note: in expansion of macro '_WRITE' #define WRITE(IO, v) _WRITE(IO, v) ^ ultralcd_st7920_u8glib_rrd.h:29:5: note: in expansion of macro 'WRITE' WRITE(ST7920_CLK_PIN,0); ^ fastio.h:34: error: 'DIOLCD_PINS_D4_WPORT' was not declared in this scope {DIO ## IO ## _WPORT |= MASK(DIO ## IO ## _PIN); }\ ^ PS C:\Users\Алексей> fastio.h:45:80: note: in expansion of macro '_WRITE_C' #define _WRITE(IO, v) do { if (&(DIO ## IO ## _RPORT) >= (uint8_t *)0x100) {_WRITE_C(IO, v); } else {_WRITE_NC(IO, v ); }; } while (0) ^ fastio.h:68:23: note: in expansion of macro '_WRITE' #define WRITE(IO, v) _WRITE(IO, v) ^ ultralcd_st7920_u8glib_rrd.h:29:5: note: in expansion of macro 'WRITE' WRITE(ST7920_CLK_PIN,0); ^ In file included from Marlin.h:21:0, from temperature.h:24, from ultralcd.cpp:1: fastio.h:34: error: 'DIOLCD_PINS_D4_PIN' was not declared in this scope {DIO ## IO ## _WPORT |= MASK(DIO ## IO ## _PIN); }\ ^ fastio.h:17:26: note: in definition of macro 'MASK' #define MASK(PIN) (1 << PIN) ^ fastio.h:45:80: note: in expansion of macro '_WRITE_C' #define _WRITE(IO, v) do { if (&(DIO ## IO ## _RPORT) >= (uint8_t *)0x100) {_WRITE_C(IO, v); } else {_WRITE_NC(IO, v ); }; } while (0) ^ fastio.h:68:23: note: in expansion of macro '_WRITE' #define WRITE(IO, v) _WRITE(IO, v) ^ ultralcd_st7920_u8glib_rrd.h:29:5: note: in expansion of macro 'WRITE' WRITE(ST7920_CLK_PIN,0);
Re: compile troubles June 15, 2015 05:53AM |
Re: compile troubles January 24, 2017 05:15AM |
Re: compile troubles January 24, 2017 06:21AM |
