What is this board and can it run Marlin 1.1.8 February 06, 2018 01:37PM |
Re: What is this board and can it run Marlin 1.1.8 February 06, 2018 05:31PM |
Re: What is this board and can it run Marlin 1.1.8 February 07, 2018 12:47AM |
Re: What is this board and can it run Marlin 1.1.8 February 07, 2018 02:06AM |
Re: What is this board and can it run Marlin 1.1.8 February 07, 2018 05:05AM |
Re: What is this board and can it run Marlin 1.1.8 February 07, 2018 04:57PM |
Re: What is this board and can it run Marlin 1.1.8 February 08, 2018 10:50PM |
Re: What is this board and can it run Marlin 1.1.8 February 09, 2018 01:34AM |
Re: What is this board and can it run Marlin 1.1.8 February 14, 2018 10:53PM |
Re: What is this board and can it run Marlin 1.1.8 February 15, 2018 12:29AM |
Re: What is this board and can it run Marlin 1.1.8 February 15, 2018 10:17PM |
Re: What is this board and can it run Marlin 1.1.8 February 16, 2018 02:45AM |
Dust
your a bit out of date... thats the old, not supported way to install Sanguino
use this method:
Start up Arduino IDE
Open up the menu File|Preferences
At the bottom is a field Additional Boards manager URLs:
Enter "https://raw.githubusercontent.com/Lauszus/Sanguino/master/package_lauszus_sanguino_index.json"
Click OK
Open up the menu Tools|Board:|Boards manager...
This will open the manager. Scroll down till you see Sanguino
Click more info, this will reveal an install button.
Hit install.
Close the Board manager.
Your done!
Re: What is this board and can it run Marlin 1.1.8 February 16, 2018 02:51AM |
rotinaj13
Ok so I got over my fear of bricking the only controller for this printer and was finally able to get Marlin 1.1.8 on my GEN6 board. So as I am sure you have found out the GEN6 board has an older bootloader which is most likely from Arduino legacy days (00XX). Marlin 1.1.8 needs to be compiled in something newer than Arduino IDE 1.6.8. I downloaded Arduino IDE ...
Re: What is this board and can it run Marlin 1.1.8 February 16, 2018 04:38AM |
Wow that sounds like it has saved me a lot of trouble. To make sure I got it right: This is the procedure to compile and then install the new firmware, right? Hopefully it also works this way on my Mac.
Thanks a lot for the comments. I will also keep trying...
Re: What is this board and can it run Marlin 1.1.8 February 17, 2018 10:15PM |
Re: What is this board and can it run Marlin 1.1.8 February 18, 2018 04:24AM |
Re: What is this board and can it run Marlin 1.1.8 March 04, 2020 04:09PM |
Re: What is this board and can it run Marlin 1.1.8 March 10, 2020 11:42AM |
Re: What is this board and can it run Marlin 1.1.8 March 10, 2020 05:04PM |
Re: What is this board and can it run Marlin 1.1.8 March 11, 2020 02:34AM |
Re: What is this board and can it run Marlin 1.1.8 March 11, 2020 01:06PM |
Re: What is this board and can it run Marlin 1.1.8 March 12, 2020 07:45AM |
Sketch uses 52806 bytes (20%) of program storage space. Maximum is 253952 bytes. Global variables use 2398 bytes (29%) of dynamic memory, leaving 5794 bytes for local variables. Maximum is 8192 bytes.
Re: What is this board and can it run Marlin 1.1.8 March 12, 2020 01:04PM |
Re: What is this board and can it run Marlin 1.1.8 August 23, 2020 03:10PM |
