What is this board and can it run Marlin 1.1.8
Posted by NozzleMover
February 06, 2018 01:37PM
Hello everybody!
Let’s give it a quick introduction: I am owner of an orcabot 0.43 since some weeks now. I made it work and print and also started modding it.
Now I am at the point where I want to change some firmware settings. Unfortunately Igor the printer just as it is, no sifteare,, no docu and no one to ask. I did not find a single picture that matches my Bord. I guess it is a gen 6 electronic of some kind.
Is there any intelligence out there to tell me
  1. What board that is
  2. If Marlin 1.1.8 will run on it
  3. What sanguino settings I need to choose in Arduino software for flashing
I thing I red something about backup. I will of course try that because the printer is working with whatever firmware is on it now.
Enclosed is a picture of the board. Thanks for any ideas on that thing.
Picture size is quite limited, so here is a link to the picture:
[www.dropbox.com]
Orcabot 0.43 with heated bed.
Re: What is this board and can it run Marlin 1.1.8
February 06, 2018 05:31PM
It does look very similar to a Gen 6
It depends on what main chip is on it
644p is two small for modern firmware
1284p is tight with modern firmwares (and can run into issues if you have a LCD or enable to many options)
Your going to have to clean that chip (isopropyl alcohol and a cotton bud) and read the number on it.
February 07, 2018 12:47AM
Thanks. That was a good hint. On the chip it reads:
ATMEL
ATMEGA 644P
20AU 1048
I don’t have an LCD installed and currently don’t use ABL or Software retraction. I guess too many of these kind of things can cause the problems. Only thing I have is a heated bed.
The thing that I want to do is mainly enabling fan support like here unter “spare pin extension”:
[reprap.org]
It would also be O.K. to know the firmware that is currently on the device reconfigure it and reinstall it just with the fan modification. Is there a command to read the installed firmware version?
Edited 1 time(s). Last edit at 02/07/2018 12:48AM by NozzleMover.
February 07, 2018 02:06AM
Most id themselves over serial on power on..
but not all, and early marlin just said v1, for everything
Most come to the same issue with this...
you can retrieve a lot of setting from the firmware with M501
But, it does not tell you anything about what thermister type you have.
Edited 1 time(s). Last edit at 02/07/2018 02:18AM by Dust.
February 07, 2018 05:05AM
Thanks again.
So my plan would than be the following:
  1. Back up the running firmware like described here: [reprap.org]
  2. Use the M501 command to get most of the settings
  3. Donwload Marlin 1.1.8 and adapt it to my printer (incl. the fan support)
  4. Enabel additional features carefully, if at all
  5. See if it works (if not, re-install image of running firmware)
The chip is the one from the Gen6 electronics, as far as I understood the corresponding RepRap Wiki. And I want to be using the the 1284 settings of the sanguino in Arduion although it sais 1048 on the chip, right? Or just see what works best?
February 07, 2018 04:57PM
The chips says "ATMEGA 644P"
so you need to use the 644p settings
1048 is probably a date code for manufacturer 48th week 2010
It also says its "20AU" so its a 20mhz chip... you need to look at the crystal and see what speed its actually running at probably only 16, but you need to set ardunio IDE to correct speed or serial communications will not work.
also backup eeprom as it may contain valuable data
eg avrdude -p m644p -c stk500v2 -P {your com port} -b 38400 -U eeprom:r:eeprom_backup_file.hex
February 08, 2018 10:50PM
I just got my printer setup again which uses the GEN6 board. I was looking at updating the firmware. Did you get 1.1.8 to run on the GEN6 board?
February 09, 2018 01:34AM
No. I will earliest try it end of next week due to time constraints...sad smiley
February 14, 2018 10:53PM
Ok so I got over my fear of bricking the only controller for this printer and was finally able to get Marlin 1.1.8 on my GEN6 board. So as I am sure you have found out the GEN6 board has an older bootloader which is most likely from Arduino legacy days (00XX). Marlin 1.1.8 needs to be compiled in something newer than Arduino IDE 1.6.8. I downloaded Arduino IDE 1.8.5 and installed it from:
[www.arduino.cc]
Now the Arduino IDE 1.8.5 does not have native support for the Sanguino based boards, so you need to download the files for that board and put in the .\arduino\hardware folder. You can get the files from here:
[github.com]
Once added you are ready to burn the bootloader from the Arduino IDE via the ISP method. Since I do not have an ISP programmer I used an Arduino Uno R3 as an ISP. You need to connect the Uno to the PC and open the example sketch ArduinoISP (it is number 11). On line 81 I uncommented #define USE_OLD_STYLE_WIRING and uploaded the sketch to my Uno. Once uploaded I powered both the GEN6 and the UNO off and wired the Uno to the GEN6's ISP pins as shown in the link below.
[www.arduino.cc]
Once everything was wired up I plugged the USB into the Uno and applied power to the Uno (the GEN6 will get it's power from the Uno). After double checking my wiring to make sure the only thing connected to the GEN6 was the Uno I burned the bootloader to the GEN6 by following the instructions below:
Open Arduino IDE
Click Tools. Set Board to "Sanguino"
Click Tools. Set Processor to "Sanguino W/ ATmega644P or ATmega644PA (16 MHz)" (Obviously you will want to verify what chipset you have by looking at the print on the board and what numbers are
on the crystal)
Click Tools. Under Programmer, choose "w Arduino as ISP".
Click Tools. Click Burn Bootloader
Arduino will begin burning the bootloader. The process takes about a minute or less.
After Arduino reports "Done", press the reset button on your GEN6 board.
Disconnect the power from the Uno board, unplug the USB cable and disconnect ISP wiring.
You're ready to load firmware!
Sorry if this seems overly simplified but I was tired of searching the net for all of this info and second guessing myself on if this would work on a GEN6 board. So if this saves one person that frustration it is worth it. Well time to move on to getting manual mesh bed leveling setup so I can compensate for the +/- .004" that bed leveling wasn't able to correct. Good luck!
February 15, 2018 12:29AM
your a bit out of date... thats the old, not supported way to install Sanguino
use this method:
Start up Arduino IDE
Open up the menu File|Preferences
At the bottom is a field Additional Boards manager URLs:
Enter "https://raw.githubusercontent.com/Lauszus/Sanguino/master/package_lauszus_sanguino_index.json"
Click OK
Open up the menu Tools|Board:|Boards manager...
This will open the manager. Scroll down till you see Sanguino
Click more info, this will reveal an install button.
Hit install.
Close the Board manager.
Your done!
February 15, 2018 10:17PM
lol yea that is a bit easier! I was searching the net and trying to follow the path from 00xx days till now. Yes my board and my expertise was out of date a lot has changed since I built my printer in 2010-2011. Honestly the changes are rather amazing that has happened. Thank you for the updated info!!
February 16, 2018 02:45AM
Dust
use this method:
Click OK
Hit install.
Your done!
Wow that sounds like it has saved me a lot of trouble. To make sure I got it right: This is the procedure to compile and then install the new firmware, right? Hopefully it also works this way on my Mac.
Thanks a lot for the comments. I will also keep trying...
February 16, 2018 02:51AM
rotinaj13
Ok so I got over my fear of bricking the only controller for this printer and was finally able to get Marlin 1.1.8 on my GEN6 board. So as I am sure you have found out the GEN6 board has an older bootloader which is most likely from Arduino legacy days (00XX). Marlin 1.1.8 needs to be compiled in something newer than Arduino IDE 1.6.8. I downloaded Arduino IDE ...
Did you back up your old firmware first?
How to validate that the backup worked?
How to bring it back on the board in case you need to?
Thanks again for your help!
February 16, 2018 04:38AM
no this is just how you add Sanguino support to the Ardunio IDE (your chip is a Sanguino)
From there you select the board Sanguino then select the processor 644p @ 16mhz (or 20... you need to look at that crystal)
Then load up marlin and make sure in configuration.h the motherboard line is "#define MOTHERBOARD SANGUINOLOLU_12"
Then you can verify (which just complies but doesn't try to upload)
If no errors then you can try an upload.
rotinaj13 recommends installing a new boot loader, this may or may not be needed... If you cant upload then you probably need it. For that you need a AVR ISP. A device that lets you put data on the chip without a bootloader. (can be as simple as another ardunio board running AVRISP firmware)
Edited 2 time(s). Last edit at 02/16/2018 04:49AM by Dust.
February 17, 2018 10:15PM
Yea the method I posted gets around the old boot loader generating errors when you attempt to upload firmware. Since my Gen6 was older and I would be wiling to bet yours is as well you will need to update the boot loader unless someone has done this which would most likely be the case if it is running 1.1.x. The information Dust posted replaces my link for downloading the drivers for Sanguino and putting them in the arduino/hardware folder. This link talks about using AVR dude to backup the firmware but I am not sure how the port portion of the command is phrased on a mac. I did backup my firmware which I used an install of Arduino 00XX that was previously installed and had the Sanguino drivers built in. I never verified my backup just moved forward:
[reprap.org]
If you go to upload and get errors that look like this then either your baud rate is wrong, wrong board selected or you need to burn the boot loader:
avrdude: stk500_getsync(): not in sync: resp=0x00
Dust: Are you sure about the board in the configuration.h? I had mine set as
#define MOTHERBOARD BOARD_GEN6
February 18, 2018 04:24AM
bah... brain fart...
should be #define MOTHERBOARD BOARD_GEN6
I used to use SANGUINOLOLU boards ... Same CPU, different pin outs
Edited 1 time(s). Last edit at 02/18/2018 04:25AM by Dust.
March 04, 2020 04:09PM
As some time has passed I finally managed to get the backup running. I need to do this now, because I have to install a new different thermistor. Question is now, should I try the newest FW 2.0.4.4? Has anyone successfully done it for a gen 6 deluxe board?
March 10, 2020 11:42AM
Today I completed a Marlin 1.1.9 version with all the settings for my Orca. I set the Arduino to Sanguino and the processor to ATmega644P 16Hz. Done so, the compiling runs without errors. Before I send it through Arduino I made sure that I can upload the old backup-hex file and it worked like a charm. Sending it to the gen 6 deluxe board produce an error.
avrdude: stk500_recv(): programmer not ready
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x03
After I got this from Arduino I d´tried the command line way that had worked before for my backup. Now the command line also produces the same error. Is somehow the fuse set wrong? I guess something is wrong with the boot loader. Any ideas?6.3
Reading is still possible with Avrdude V 6.3.
It closes with safe mode: Fuses O.K. (E:00, H:00, L:00)
March 10, 2020 05:04PM
O.K. I got the transfer to work with avrdude. The Orcabot (gen6 deluxe ATmega644p 16Hz) needs to be started freshly to accept a hex-file from avrdude.
I used this command and AVRDUDE 6.3 (config file form etc-folder needed to be transferred to bin-folder):
avrdude -c avrisp -b 38400 -i 10 -p m644p -P /dev/ttyUSB0 -F -U flash:r:factory_gen6.hex:i
After compiling the 1.1.9 Marlin I took the hex-file to avrdude and transferred it successfully. But neither ponterface nor octoprint want to connect after update. Any idea?
March 11, 2020 02:34AM
check the serial port in Marlin is set to 0 and look at the baud rate you set.
Pronterface baud rate has to match baud rate you set in Marlin.
March 11, 2020 01:06PM
They do match, and it is set to 0.
I found this out today (avrdude verification fails):
[reprap.org]
March 12, 2020 07:45AM
when you compile marlin, it tells you at the end how many bytes it uses
Eg for a mega2560
Sketch uses 52806 bytes (20%) of program storage space. Maximum is 253952 bytes.
Global variables use 2398 bytes (29%) of dynamic memory, leaving 5794 bytes for local variables. Maximum is 8192 bytes.
You need to verify that the "Sketch uses" value is less than the maximum flash size of 65536 bytes (this is for a 644p without bootloader, for AVRISP upload only)
Edited 1 time(s). Last edit at 03/12/2020 07:49AM by Dust.
March 12, 2020 01:04PM
YES! Thank you! It was a size issue. Now it is working. I removed ARC support and it fits on the 644p!!
Edited 1 time(s). Last edit at 03/12/2020 01:05PM by NozzleMover.
August 20, 2020 10:03AM
I'm pretty sure I read in the Marlin documentation that linear advance puts a lot of load on the poor 8-bit AVR. They recommend to run communications with line numbers and checksums active at a maximum of 115200 baud to minimize impact from communication errors. 192.168.100.1 192.168.1.1 jpg to pdf
Edited 1 time(s). Last edit at 08/20/2020 06:10PM by adomanim.
August 23, 2020 03:10PM
I don’t really understand what you mean. All I can say is that the printer is running like a charm with the new firmware. Also very long print jobs of six hours and more run smoothly and the only errors that I get is when the nozzle is clogged or my filament gets too hot and is ground in the extruder. I have not seen a print failure due to a software issues since I updated.
