Which stepper to buy: 68oz 0.9degrees or 70oz 1.8degrees November 06, 2013 02:14PM |
Re: Which stepper to buy: 68oz 0.9degrees or 70oz 1.8degrees November 06, 2013 08:10PM |
Re: Which stepper to buy: 68oz 0.9degrees or 70oz 1.8degrees November 06, 2013 09:10PM |
Re: Which stepper to buy: 68oz 0.9degrees or 70oz 1.8degrees November 06, 2013 11:21PM |
Re: Which stepper to buy: 68oz 0.9degrees or 70oz 1.8degrees November 07, 2013 01:19PM |
Re: Which stepper to buy: 68oz 0.9degrees or 70oz 1.8degrees November 07, 2013 04:48PM |
Re: Which stepper to buy: 68oz 0.9degrees or 70oz 1.8degrees November 07, 2013 06:38PM |
Re: Which stepper to buy: 68oz 0.9degrees or 70oz 1.8degrees November 08, 2013 12:47AM |
Admin Registered: 13 years ago Posts: 7,008 |
Re: Which stepper to buy: 68oz 0.9degrees or 70oz 1.8degrees November 08, 2013 08:49AM |
Re: Which stepper to buy: 68oz 0.9degrees or 70oz 1.8degrees November 08, 2013 01:08PM |
Re: Which stepper to buy: 68oz 0.9degrees or 70oz 1.8degrees November 08, 2013 06:33PM |
Re: Which stepper to buy: 68oz 0.9degrees or 70oz 1.8degrees November 08, 2013 06:56PM |
Re: Which stepper to buy: 68oz 0.9degrees or 70oz 1.8degrees November 09, 2013 04:34AM |
Re: Which stepper to buy: 68oz 0.9degrees or 70oz 1.8degrees December 16, 2013 11:45PM |
Re: Which stepper to buy: 68oz 0.9degrees or 70oz 1.8degrees December 17, 2013 09:30PM |
Re: Which stepper to buy: 68oz 0.9degrees or 70oz 1.8degrees December 18, 2013 02:21PM |
Re: Which stepper to buy: 68oz 0.9degrees or 70oz 1.8degrees December 19, 2013 09:54PM |
Re: Which stepper to buy: 68oz 0.9degrees or 70oz 1.8degrees December 21, 2013 03:35PM |
Re: Which stepper to buy: 68oz 0.9degrees or 70oz 1.8degrees December 21, 2013 08:03PM |
Re: Which stepper to buy: 68oz 0.9degrees or 70oz 1.8degrees December 23, 2013 04:20AM |
uncle_bob
The very fundamental problem is that people seem to be looking just at current and not at voltage or resistance (or max torque). Current by its self means absolutely nothing at all. You need the rest of the data. I can *easily* design a NEMA 17 motor that will blow away you 2.5A gizmo when mine is running 0.1A..
Re: Which stepper to buy: 68oz 0.9degrees or 70oz 1.8degrees December 23, 2013 11:17AM |
Re: Which stepper to buy: 68oz 0.9degrees or 70oz 1.8degrees December 23, 2013 06:31PM |
No, i havent said i would put 100v to a stepper driver, i intuitively though that would of been your idea behind the affirmation about you designing a stepper to run at 0.1A and beat "my gizmo" 2.5A one. Changing the driver input voltage has its benefits, but not like that and not in that sense. If you didnt thought about changing voltage, then tbh dunno what else you thought about when saying that. I think this part is over anyway - if not then feel free to expand.Quote
uncle_bob
Here's the disconnects:
Even if you could put a several thousand volt driver on the motor and run an amp through it no matter what, it's torque wold still drop off. The hysteresis and loss in the magnetic materials used in the motor are the limit here. As the frequency goes up their losses go up as well. All of your added input simply goes to heat. The easy way to look at that is the angle between the voltage and current. You can directly measure what's going on.
Imo, the starting point for dynamic behavior is technically the detent torque. The word i believe means jumping distance, and thats what i would be interested in, jumping from one step to the next. The holding torque is about static behavior e.g. "holding" position, i would be somewhat interested for an application where the motor needs to hold weight or otherwise counter forces exerted on the head. And even then still not so much: since any forces on head when one motor holds, can also manifest while is moving, and the moving one is lowest, i guess it means i would still be only interested in detent one just because its lowest value, and i would efectivelly ignore the holding one just coz its higher and thats covered.Quote
In a stepper the torque starts off at the holding torque and pretty much just drops as rpms (or frequency) goes up. Your "dynamic torque" has an upper bound in the static torque. That's what makes static torque a very important parameter on a motor. That's why you can always find it specified.
Hmm, when the motor stays still, thats not DC. Its still switched mode even then. In case you hear noise, thats where is coming from. If you dont hear noise, then its above 30kHz, hence too high for human ear. Now you see why i said i care for rise times because simply put, there is lots of it. Rise times dont count much when motor holds, but switching does occurs at all times, it has to, as its the only method of control. Without switching, current obviously would rise above setting and would burn something, probably the driver ic. But thats too plain therefore i think you must have been refering to something else by that.Quote
You *slowly* go from static DC to stepping.
I dunno what you mean by this. It makes me think about vfd as in variable frequency drives which are used for stuff like milling heads, but i dont see the resemblance here, so maybe you mean something else.Quote
Low RPM's mean low drive frequencies.
Again, i am at miss. I think this choice of words may be at least partly my fault. I think i remember saying something like that once, but was in some context of choosing the motor values, and we dont care for ohms law about motor's label values because the driver limits the current anyway, its way we can run it at much higher voltage while not caring for the low resistance coil getting burned. This is why there is switching even when motor stays still, because coils would burn otherwise. I think was wrong thing to say, poor perspective/comparison or at least unfortunate choice of words from my part. We may not care for it and even we may sometimes hide it under the carpet, but we are in fact always under ohms law in some form, even if not about label values. Actually its more than just a law, its the very definition of resistance. So there is no practical region or operating regime that is outside ohms law, if we look down hard enough, ohms law gets its finger in all operating points in one way or another. E.g. in the sense that voltage would eventually rise the current to ohms law for a final value, except the driver senses and interrupts the rise edge at the preset current point. I think you meant something similar along those lines. So again i might of misunderstood you and perhaps you meant something else.Quote
Low drive frequency means that you are completely in the ohms law region.
Re: Which stepper to buy: 68oz 0.9degrees or 70oz 1.8degrees December 26, 2013 06:15PM |
NoobMan
uncle_bob
The point is that past the point that you can establish the proper sine wave drive signal, there is no advantage to greater driver voltage. That is a very predictable level.
Imo, the starting point for dynamic behavior is technically the detent torque.Quote
The detent torque is simply the torque that will move the shaft with no current through the windings.
The jumping involved is just the "jump" that you get as the magnets align
Since the holding torque is the number with current through the coils, that's the basis for all the calculations on an operating motor. No current and yes detent torque rules.
Hmm, when the motor stays still, thats not DC. Its still switched mode even then.Quote
When the motor is still there is a constant DC current through the motor. How that current is generated by the driver does not matter. You could use a battery and a resistor to get the same effect.
Again, that's just how the driver does it's thing. It has nothing to do with how the motor operates. All it's doing is generating a DC current when the motor is still.
They only count if you believe the driver running as an ideal switcher. Due to the Q of the motor coil they are far from an ideal switcher. Since there is no "C" in the system they have some other issues as well. A normal switch configuration has more parts than one of these drivers does.
As long as it's DC current the motor will hold. You do not need fast switching to have a DC current.
The only thing you need for DC is a PWM pulse width out of the switch. You could be switching at 1KHz with 10us rise times and it would work fine. No need for speed at DC.
Re: Which stepper to buy: 68oz 0.9degrees or 70oz 1.8degrees December 29, 2013 03:53PM |
First, the current is not generated by the driver at all. The driver is not a current source. The driver just plays with the voltage by its mosfets. The current is "generated" or better said, it grows and decays inside the inductor itself. And that current is anything but "constant". Its switched mode, e.g. pulsating or else, otherwise not constant.Quote
uncle_bob
A switch is simply only one part: a switch is a mosfet or bjt or igbt, etc. Even a simple diode is a switch. Switches dont have more parts, what they do have are quadrants, and quadrants just show on which direction they conduct or block voltage or current. The quadrants help the designer to establish how a switch is implemented, e.g. why we would choose a diode specifically for that spot - see "switch realization". Other parts associated with switches may be things like snubbers, but those are not technically part of the switch itself, just support components or stuff to deal with imperfections of the switch or the load.Quote
uncle_bob
So again, its not a current sinusoid that is generated eslewhere than forced into the coil. Current just grows in the coil as result of playing with voltage, and that is the elemental law of the inducutor. Voltage across inductor builds the flux, to which the current is proportional. Now if you understand that, you will see previous statements differently and, even if most ppls dont see it, some other parts.Quote
uncle_bob
You have an R-L circuit. You generate a sine wave current to drive it. All of the switching stuff is just an odd way to generate a sine wave current. You would get exactly the same motor performance if you drove it with a stereo amplifier, a couple of resistors, and signals out of your PC. The switching stuff just confuses things because it applies only to the "amplifier" that's driving the coils.
Re: Which stepper to buy: 68oz 0.9degrees or 70oz 1.8degrees January 01, 2014 08:11AM |
NoobMan
Re: Which stepper to buy: 68oz 0.9degrees or 70oz 1.8degrees January 02, 2014 10:53AM |
Re: Which stepper to buy: 68oz 0.9degrees or 70oz 1.8degrees January 02, 2014 12:41PM |
Re: Which stepper to buy: 68oz 0.9degrees or 70oz 1.8degrees January 02, 2014 01:38PM |
Re: Which stepper to buy: 68oz 0.9degrees or 70oz 1.8degrees January 03, 2014 07:41AM |
Re: Which stepper to buy: 68oz 0.9degrees or 70oz 1.8degrees January 03, 2014 09:19PM |
If we dig deep enough, i guess something technically correct is something just a little bit different:Quote
Dala.horse
Ohms law never plays a direct role in deciding the current through the motor. The chopper circuits always limits the current to the set level.
Dala.horse
The drivers in printers are mixed analogue/digital/mechanical control systems with feedback. Ohms law is never used to describe such systems.
