Z-ax motor blocked
September 21, 2015 09:00AM
Prusa i3.
Motherboard: Megatronics. + Marlin.
When I ask a Z-ax movement of 100 mm, it goes only 80 mm.
If I increase the steps per unit for the Z-ax I get problems when I put a number higher then 6800 steps per unit.
It goes perfectly up, but when I ask to go back to zero position, after 5 mm. movement the z-motors block making a big humming noise.
I cannot find any root-cause. Some-one familair with the problem?
Awaiting your suggestions,
w k r Henk
* MOVEMENT SETTINGS
#define HOMING_FEEDRATE {50*60, 50*60, 4*60, 0} // set the homing speeds (mm/min)
// default settings
#define DEFAULT_AXIS_STEPS_PER_UNIT {92.5*2,92.5*2,6800.00,100*1*1.5} // default steps per unit for Ultimaker
#define DEFAULT_MAX_FEEDRATE {300, 300, 5, 25} // (mm/sec)
#define DEFAULT_MAX_ACCELERATION {3000,3000,100,10000} // X, Y, Z, E maximum start speed for accelerated moves. E default values are good for Skeinforge 40+, for older versions raise them a lot.
#define DEFAULT_ACCELERATION 3000 // X, Y, Z and E acceleration in mm/s^2 for printing moves
#define DEFAULT_RETRACT_ACCELERATION 3000 // E acceleration in mm/s^2 for retracts
#define DEFAULT_TRAVEL_ACCELERATION 3000 // X, Y, Z acceleration in mm/s^2 for travel (non printing) moves
hdie support
Re: Z-ax motor blocked
September 21, 2015 12:50PM
Your Z max feed rate and accelerations look way too high to me, given that your steps/mm is 6800. Try a Z max feed rate of 3 mm/sec and a Z acceleration of 20.
September 21, 2015 01:18PM
6800 steps per mm seems very high. At 5mm/sec = 34,000 steps per second which would push the limits of the mega chip.
A 5mm rod with .8 mm /rev = 1/.8 * 200 * 16 steps = only 4000 steps per mm
I would have to guess you have a drv8825 driver set at 1/32 steps to get this high a value.
Try setting the driver at 16 steps. At 4000 steps your resolution is .00025 mm
September 22, 2015 10:20AM
dc42, Thanks for your help. Z max feed rate of 3 mm/sec, solved the problem.
I found a Marlin verion especially for Prusa i3, and there also the default steps were 8.000/unit. and there the speed was reduced to only 1 mm/sec.
George, I think you are completely right, but I do not know where to adjust the driver settings.
Really nice how things are solved here, within 12 hours!!! Thanks again.
