Stepper motors in sound sensitive enviorment November 19, 2015 08:13AM |
1,00x EvoDrive St-17 Controller [www.evarobotics.com]
5,00x EvoDrive St-23 Controller [www.evarobotics.com]
1,00x EvoDrive St-17 non-optical Encoder [www.evarobotics.com]
5,00x EvoDrive St-23 non-optical Encoder [www.evarobotics.com]
1,00x Gear Ratio 100:1 Planetary Gearbox Nema 17 Stepper Motor [www.omc-stepperonline.com]
5,00x Gear Ratio 4:1 Planetary Gearbox Nema 23 Geared Stepper Motor [www.omc-stepperonline.com]
1,00x SB485L - Basic USB to RS485 Converter [www.pimzos.com]
Re: Stepper motors in sound sensitive enviorment November 19, 2015 12:28PM |
Re: Stepper motors in sound sensitive enviorment November 20, 2015 03:09AM |
Re: Stepper motors in sound sensitive enviorment November 20, 2015 03:41AM |
Re: Stepper motors in sound sensitive enviorment November 20, 2015 04:13AM |
Re: Stepper motors in sound sensitive enviorment November 20, 2015 06:03AM |
o_lampe
The steppers will always hum when the drivers are active. So a brake on the axis and disabling the stepper drivers is mandatory.
Re: Stepper motors in sound sensitive enviorment November 20, 2015 07:05PM |
smokeythebandit
Thanks for replying.
I'm using a linear encoder Link.
These encoders working conjunction with this controller Link.
This is a digital encoder. It can be controlled via either RS232 or RS485. The end goal is to connect six of these to the RS485 bus.
The master of these motors will be a piece of custom software on a PC. The software will be written in c++, and in the end offer high level controls to control the robot. This software will be made into a library, and then ported to matlab so the thing can be controlled from matlab code.
This thing wont have a stage. Like I said, these motors will surely be powerful enough. Another engineer made a design and did the calculations. The motors must be able to reach a step angle of at least 0.5 degrees, which I can manage through the use of gearing.
