Nema 23 cant go fast HELP ME! November 24, 2015 10:42AM |
Re: Nema 23 cant go fast HELP ME! November 24, 2015 10:57AM |
Re: Nema 23 cant go fast HELP ME! November 24, 2015 10:58AM |
Re: Nema 23 cant go fast HELP ME! November 24, 2015 11:05AM |
Re: Nema 23 cant go fast HELP ME! November 24, 2015 11:50AM |
Re: Nema 23 cant go fast HELP ME! November 24, 2015 12:55PM |
Re: Nema 23 cant go fast HELP ME! November 24, 2015 01:01PM |
Re: Nema 23 cant go fast HELP ME! November 24, 2015 02:10PM |
Re: Nema 23 cant go fast HELP ME! November 24, 2015 03:13PM |
Re: Nema 23 cant go fast HELP ME! November 24, 2015 03:17PM |
george4657
If you only can go 250 RPM something is wrong.
At 3000 RPM = 3000*400/60 = 20,000 steps per second which an arduino should be able to do.
You can run this fast but will have no power at this speed. See torque chart.
What are your current settings?
What program are you using to run the stepper?
Does the motor get warm/hot when running?
How are you measuring the RPM?
Re: Nema 23 cant go fast HELP ME! November 24, 2015 03:26PM |
Re: Nema 23 cant go fast HELP ME! November 24, 2015 03:31PM |
the_digital_dentist
The curve shows pps- pulses per second. If you use 1/2 stepping, 400 pulses represents 1 rev. which figures to 17.5 rev/sec which is 1050 rpm where you are getting almost no torque.
Sw5-8 control stepping. The one entry missing from the table is all switches on- that may give you full steps, or might fry the driver. Check the manual.
Re: Nema 23 cant go fast HELP ME! November 24, 2015 03:59PM |
Re: Nema 23 cant go fast HELP ME! November 24, 2015 04:04PM |
Re: Nema 23 cant go fast HELP ME! November 25, 2015 03:01AM |
the_digital_dentist
You can't get a stepper to go that fast, even with no load. You'll need a different type of motor.
You can do full steps with that driver, but at 2000 rpm you need 400k steps per second. I don't think the driver can keep up with that pulse rate.
If you need precision and speed like that you need to look at servo motors and drivers.
| Triffid Hunter's Calibration Guide | --> X <-- Drill for new Monitor | Most important Gcode. |
Re: Nema 23 cant go fast HELP ME! November 25, 2015 06:17PM |
Re: Nema 23 cant go fast HELP ME! November 25, 2015 06:44PM |
burnley1
Someone on the forum told me about inductance, that I should have around 90-100 volts of voltage from powersupply for 6.8 mH of inductance.... what do you think?
Re: Nema 23 cant go fast HELP ME! November 26, 2015 01:26AM |
Re: Nema 23 cant go fast HELP ME! November 26, 2015 02:11PM |
Re: Nema 23 cant go fast HELP ME! December 01, 2015 02:44PM |
