I have a stepper motor that is required to lift a weight but when the power shuts off the thing falls. I need it to be in the same position. What should i do?
Re: how do i stop the motor shaft which has a load, from rotating when the power is shut off
May 26, 2016 03:31AM
some sort of a brake on a solenoid
When power is on brakes are retracted, when power is off brake is applied
Because this is a common problem, there are solutions ready to buy! This page describes the exact scenario [www.orientalmotor.com] "Electromechanical brake type used for vertical operation" There are stepper motors with builtin electromechanical brake, and you can also get braking units.
Whether off the shelf or DIY, the principle is the same as Dust describes.
What is Open Source?
What is Open Source Hardware?
Open Source in a nutshell: the Four Freedoms
CC BY-NC is not an Open Source license
Vexta Stepper Motor Stepping PH264-01-C41 with Brake
$25 USD
[www.ebay.com]
confused smiley
Balance the load, with a counterbalance or spring.
Thingiverse ID Alan1279
Use a screw to lift the load...
