Nema 17 Stepper Motor Noise
September 30, 2016 04:36PM
When my stepper motors don't move, there are noise and sound that attached file below. I use MKS Base 1.3 and config file is below
# NOTE Lines must not exceed 132 characters
# Robot module configurations : general handling of movement G-codes and slicing into moves
default_feed_rate                            4000             # Default rate ( mm/minute ) for G1/G2/G3 moves
default_seek_rate                            4000             # Default rate ( mm/minute ) for G0 moves
mm_per_arc_segment                           0.5              # Arcs are cut into segments ( lines ), this is the length for
                                                              # these segments.  Smaller values mean more resolution,
                                                              # higher values mean faster computation
mm_per_line_segment                          5                # Lines can be cut into segments ( not usefull with cartesian
                                                              # coordinates robots ).
# Arm solution configuration : Cartesian robot. Translates mm positions into stepper positions
alpha_steps_per_mm                           161               # Steps per mm for alpha stepper 78.7402
beta_steps_per_mm                            161               # Steps per mm for beta stepper 78.7402
gamma_steps_per_mm                           640             # Steps per mm for gamma stepper 400
# Planner module configuration : Look-ahead and acceleration configuration
planner_queue_size                           32               # DO NOT CHANGE THIS UNLESS YOU KNOW EXACTLY WHAT YOU ARE DOING
acceleration                                 600             # Acceleration in mm/second/second.
z_acceleration                              60              # Acceleration for Z only moves in mm/s^2, 0 uses acceleration which is the default. DO NOT SET ON A DELTA
acceleration_ticks_per_second                1000             # Number of times per second the speed is updated
junction_deviation                           0.02             # Similar to the old "max_jerk", in millimeters,
                                                              # see [github.com]
                                                              # and [github.com]
                                                              # Lower values mean being more careful, higher values means being
                                                              # faster and have more jerk
#z_junction_deviation                        0.0              # for Z only moves, -1 uses junction_deviation, zero disables junction_deviation on z moves DO NOT SET ON A DELTA
#minimum_planner_speed                       0.0              # sets the minimum planner speed in mm/sec
# Stepper module configuration
microseconds_per_step_pulse                  1                # Duration of step pulses to stepper drivers, in microseconds
base_stepping_frequency                      100000           # Base frequency for stepping, higher gives smoother movement
# Cartesian axis speed limits
x_axis_max_speed                             10000            # mm/min
y_axis_max_speed                             10000            # mm/min
z_axis_max_speed                             200              # mm/min
# Stepper module pins ( ports, and pin numbers, appending "!" to the number will invert a pin )
alpha_step_pin                               2.0              # Pin for alpha stepper step signal
alpha_dir_pin                                0.5              # Pin for alpha stepper direction
alpha_en_pin                                 0.4              # Pin for alpha enable pin
alpha_current                                1.2             # X stepper motor current
alpha_max_rate                               10000.0          # mm/min
beta_step_pin                                2.1              # Pin for beta stepper step signal
beta_dir_pin                                 0.11!             # Pin for beta stepper direction
beta_en_pin                                  0.10             # Pin for beta enable
beta_current                                 1.2             # Y stepper motor current
beta_max_rate                                10000.0          # mm/min
gamma_step_pin                               2.2              # Pin for gamma stepper step signal
gamma_dir_pin                                0.20!             # Pin for gamma stepper direction
gamma_en_pin                                 0.19             # Pin for gamma enable
gamma_current                                1.5              # Z stepper motor current 1.5
gamma_max_rate                               100.0            # mm/min
# Serial communications configuration ( baud rate default to 9600 if undefined )
uart0.baud_rate                              115200           # Baud rate for the default hardware serial port
second_usb_serial_enable                     true            # This enables a second usb serial port (to have both pronterface
                                                              # and a terminal connected)
#leds_disable                                true             # disable using leds after config loaded
#play_led_disable                            true             # disable the play led
pause_button_enable                          true             # Pause button enable
#pause_button_pin                            2.12             # pause button pin. default is P2.12
#kill_button_enable                           false            # set to true to enable a kill button
#kill_button_pin                              2.12             # kill button pin. default is same as pause button 2.12 (2.11 is another good choice)
#msd_disable                                 false            # disable the MSD (USB SDCARD) when set to true (needs special binary)
#dfu_enable                                  false            # for linux developers, set to true to enable DFU
# Extruder module configuration
extruder.hotend.enable                          true             # Whether to activate the extruder module at all. All configuration is ignored if false
extruder.hotend.steps_per_mm                    90              # Steps per mm for extruder stepper
extruder.hotend.default_feed_rate               600              # Default rate ( mm/minute ) for moves where only the extruder moves
extruder.hotend.acceleration                    500              # Acceleration for the stepper motor, as of 0.6, arbitrary ratio
extruder.hotend.max_speed                       50               # mm/s
extruder.hotend.step_pin                        2.3              # Pin for extruder step signal
extruder.hotend.dir_pin                         0.22!             # Pin for extruder dir signal
extruder.hotend.en_pin                          0.21             # Pin for extruder enable signal
# extruder offset
extruder.hotend.x_offset                        200                # x offset from origin in mm
extruder.hotend.y_offset                        200                # y offset from origin in mm
extruder.hotend.z_offset                        200                # z offset from origin in mm
# firmware retract settings when using G10/G11, these are the defaults if not defined, must be defined for each extruder if not using the defaults
#extruder.hotend.retract_length                  3               # retract length in mm
#extruder.hotend.retract_feedrate                45              # retract feedrate in mm/sec
#extruder.hotend.retract_recover_length          0               # additional length for recover
#extruder.hotend.retract_recover_feedrate        8               # recover feedrate in mm/sec (should be less than retract feedrate)
#extruder.hotend.retract_zlift_length            0               # zlift on retract in mm, 0 disables
#extruder.hotend.retract_zlift_feedrate          6000            # zlift feedrate in mm/min (Note mm/min NOT mm/sec)
delta_current                                1.5              # First extruder stepper motor current
# Second extruder module configuration
#extruder.hotend2.enable                          true             # Whether to activate the extruder module at all. All configuration is ignored if false
#extruder.hotend2.steps_per_mm                    140              # Steps per mm for extruder stepper
#extruder.hotend2.default_feed_rate               600              # Default rate ( mm/minute ) for moves where only the extruder moves
#extruder.hotend2.acceleration                    500              # Acceleration for the stepper motor, as of 0.6, arbitrary ratio
#extruder.hotend2.max_speed                       50               # mm/s
#extruder.hotend2.step_pin                        2.8              # Pin for extruder step signal
#extruder.hotend2.dir_pin                         2.13             # Pin for extruder dir signal
#extruder.hotend2.en_pin                          4.29             # Pin for extruder enable signal
#extruder.hotend2.x_offset                        0                # x offset from origin in mm
#extruder.hotend2.y_offset                        25.0             # y offset from origin in mm
#extruder.hotend2.z_offset                        0                # z offset from origin in mm
#epsilon_current                              1.5              # Second extruder stepper motor current
# Laser module configuration
laser_module_enable                          false            # Whether to activate the laser module at all. All configuration is
                                                              # ignored if false.
#laser_module_pin                             2.5             # this pin will be PWMed to control the laser. Only P2.0 - P2.5, P1.18, P1.20, P1.21, P1.23, P1.24, P1.26, P3.25, P3.26
                                                              # can be used since laser requires hardware PWM
#laser_module_max_power                       0.8             # this is the maximum duty cycle that will be applied to the laser
#laser_module_tickle_power                    0.0             # this duty cycle will be used for travel moves to keep the laser
                                                              # active without actually burning
#laser_module_pwm_period                      20              # this sets the pwm frequency as the period in microseconds
# Hotend temperature control configuration
temperature_control.hotend.enable            true             # Whether to activate this ( "hotend" ) module at all.
                                                              # All configuration is ignored if false.
temperature_control.hotend.thermistor_pin    0.24             # Pin for the thermistor to read
temperature_control.hotend.heater_pin        2.7              # Pin that controls the heater, set to nc if a readonly thermistor is being defined   2.7
#temperature_control.hotend.thermistor        RRRF100K       # see [smoothieware.org]
temperature_control.hotend.beta             4280             # or set the beta value
temperature_control.hotend.set_m_code        104              #
temperature_control.hotend.set_and_wait_m_code 109            #
temperature_control.hotend.designator        T                #
#temperature_control.hotend.p_factor         13.7             # permanently set the PID values after an auto pid
#temperature_control.hotend.i_factor         0.097            #
#temperature_control.hotend.d_factor         24               #
#temperature_control.hotend.max_pwm          255               # max pwm, 64 is a good value if driving a 12v resistor with 24v.
# Hotend2 temperature control configuration
temperature_control.hotend2.enable            true             # Whether to activate this ( "hotend" ) module at all.
temperature_control.hotend2.thermistor_pin    0.25             # Pin for the thermistor to read
temperature_control.hotend2.heater_pin        1.23             # Pin that controls the heater
#temperature_control.hotend2.thermistor        RRRF100K        # see [smoothieware.org]
temperature_control.hotend2.beta             4300              # or set the beta value
temperature_control.hotend2.set_m_code        884              #
temperature_control.hotend2.set_and_wait_m_code 889            #
temperature_control.hotend2.designator        T1               #
#temperature_control.hotend2.p_factor          13.7           # permanently set the PID values after an auto pid
#temperature_control.hotend2.i_factor          0.097          #
#temperature_control.hotend2.d_factor          24             #
#temperature_control.hotend2.max_pwm          64               # max pwm, 64 is a good value if driving a 12v resistor with 24v.
temperature_control.bed.enable               true             #
temperature_control.bed.thermistor_pin       0.23             #
temperature_control.bed.heater_pin           2.5              #  2.5
temperature_control.bed.thermistor           RRRF100K         # see [smoothieware.org]
#temperature_control.bed.beta                3960             # or set the beta value
temperature_control.bed.set_m_code           140              #
temperature_control.bed.set_and_wait_m_code  190              #
temperature_control.bed.designator           B                #
#temperature_control.bed.bang_bang            false           # set to true to use bang bang control rather than PID
#temperature_control.bed.hysteresis           2.0             # set to the temperature in degrees C to use as hysteresis
                                                              # when using bang bang
# Switch module for fan control
switch.fan.enable                            true             #
switch.fan.input_on_command                  M106             #
switch.fan.input_off_command                 M107             #
switch.fan.output_pin                        2.4              #
switch.fan.output_type                       pwm              # pwm output settable with S parameter in the input_on_comand
#switch.fan.max_pwm                           255             # set max pwm for the pin default is 255
#switch.misc.enable                           true             #
#switch.misc.input_on_command                 M42              #
#switch.misc.input_off_command                M43              #
#switch.misc.output_pin                       2.4              #
#switch.misc.output_type                      digital          # just an on or off pin
# automatically toggle a switch at a specified temperature. Different ones of these may be defined to monitor different temperatures and switch different swithxes
# useful to turn on a fan or water pump to cool the hotend
#temperatureswitch.hotend.enable	            true             #
#temperatureswitch.hotend.designator          T                # first character of the temperature control designator to use as the temperature sensor to monitor
#temperatureswitch.hotend.switch              misc             # select which switch to use, matches the name of the defined switch
#temperatureswitch.hotend.threshold_temp      60.0             # temperature to turn on (if rising) or off the switch
#temperatureswitch.hotend.heatup_poll         15               # poll heatup at 15 sec intervals
#temperatureswitch.hotend.cooldown_poll       60               # poll cooldown at 60 sec intervals
# Switch module for spindle control
#switch.spindle.enable                        false            #
# Endstops
endstops_enable                              true             # the endstop module is enabled by default and can be disabled here
#corexy_homing                               false            # set to true if homing on a hbit or corexy
alpha_min_endstop                            1.24^            # add a ! to invert if endstop is NO connected to ground
alpha_max_endstop                            nc               # NOTE set to nc if this is not installed
alpha_homing_direction                       home_to_min      # or set to home_to_max and set alpha_max
alpha_min                                    0                # this gets loaded after homing when home_to_min is set
alpha_max                                    200              # this gets loaded after homing when home_to_max is set
beta_min_endstop                             1.26^            #
beta_max_endstop                             nc               #
beta_homing_direction                        home_to_min      #
beta_min                                     0                #
beta_max                                     200              #
gamma_min_endstop                            nc               # 1.28^!, switch icin 1.28^ olacak.
gamma_max_endstop                            nc               #
gamma_homing_direction                       home_to_min      #
gamma_min                                    0                #
gamma_max                                    200              #
# optional order in which axis will home, default is they all home at the same time,
# if this is set it will force each axis to home one at a time in the specified order
#homing_order                                 XYZ              # x axis followed by y then z last
# optional enable limit switches, actions will stop if any enabled limit switch is triggered
alpha_limit_enable                          true              # set to true to enable X min and max limit switches
beta_limit_enable                           true              # set to true to enable Y min and max limit switches
gamma_limit_enable                          false              # set to true to enable Z min and max limit switches
alpha_fast_homing_rate_mm_s                  50               # feedrates in mm/second
beta_fast_homing_rate_mm_s                   50               # "
gamma_fast_homing_rate_mm_s                  4                # "
alpha_slow_homing_rate_mm_s                  25               # "
beta_slow_homing_rate_mm_s                   25               # "
gamma_slow_homing_rate_mm_s                  2                # "
alpha_homing_retract_mm                      5                # distance in mm
beta_homing_retract_mm                       5                # "
gamma_homing_retract_mm                      1                # "
#endstop_debounce_count                       100             # uncomment if you get noise on your endstops, default is 100
# optional Z probe
zprobe.enable                                true            # set to true to enable a zprobe
zprobe.probe_pin                             1.28^           # pin probe is attached to if NC remove the !  - 1.28!^
zprobe.slow_feedrate                         5               # mm/sec probe feed rate 5
#zprobe.debounce_count                       100             # set if noisy
zprobe.fast_feedrate                         100             # move feedrate mm/sec
zprobe.probe_height                          5               # how much above bed to start probe 5
gamma_min_endstop                            nc              # normally 1.28. Change to nc to prevent conflict,
# associated with zprobe the leveling strategy to use
leveling-strategy.three-point-leveling.enable         true        # a leveling strategy that probes three points to define a plane and keeps the Z parallel to that plane
leveling-strategy.three-point-leveling.point1         120,38       # the first probe point (x,y) optional may be defined with M557
leveling-strategy.three-point-leveling.point2         35,195      # the second probe point (x,y)
leveling-strategy.three-point-leveling.point3         199,195     # the third probe point (x,y)
leveling-strategy.three-point-leveling.home_first     true        # home the XY axis before probing
leveling-strategy.three-point-leveling.tolerance      0.03        # the probe tolerance in mm, anything less that this will be ignored, default is 0.03mm
leveling-strategy.three-point-leveling.probe_offsets  1,28.94,0.289  # the probe offsets from nozzle, must be x,y,z, default is no offset 1.12
leveling-strategy.three-point-leveling.save_plane     false       # set to true to allow the bed plane to be saved with M500 default is false
# Panel
panel.enable                                 true             # set to true to enable the panel code
#panel.lcd                                    smoothiepanel     # set type of panel
#panel.encoder_a_pin                          3.25!^            # encoder pin
#panel.encoder_b_pin                          3.26!^            # encoder pin
# Example for reprap discount GLCD
# on glcd EXP1 is to left and EXP2 is to right, pin 1 is bottom left, pin 2 is top left etc.
# +5v is EXP1 pin 10, Gnd is EXP1 pin 9
panel.lcd                                   reprap_discount_glcd     #
panel.spi_channel                           0                 # spi channel to use  ; GLCD EXP1 Pins 3,5 (MOSI, SCLK)
panel.spi_cs_pin                            0.16              # spi chip select     ; GLCD EXP1 Pin 4
panel.encoder_a_pin                         3.25!^            # encoder pin         ; GLCD EXP2 Pin 3
panel.encoder_b_pin                         3.26!^            # encoder pin         ; GLCD EXP2 Pin 5
panel.click_button_pin                      1.30!^            # click button        ; GLCD EXP1 Pin 2
panel.buzz_pin                              1.31              # pin for buzzer      ; GLCD EXP1 Pin 1
panel.back_button_pin                       2.11!^            # back button         ; GLCD EXP2 Pin 8
panel.external_sd                     true              # set to true if there is an extrernal sdcard on the panel
panel.external_sd.spi_channel         1                 # set spi channel the sdcard is on
panel.external_sd.spi_cs_pin          0.28              # set spi chip select for the sdcard (or any spare pin)
panel.external_sd.sdcd_pin            0.27!^            # sd detect signal (set to nc if no sdcard detect) (or any spare pin)
# pins used with other panels
#panel.up_button_pin                         0.1!              # up button if used
#panel.down_button_pin                       0.0!              # down button if used
#panel.click_button_pin                      0.18!             # click button if used
panel.menu_offset                            0                 # some panels will need 1 here
panel.alpha_jog_feedrate                     6000              # x jogging feedrate in mm/min
panel.beta_jog_feedrate                      6000              # y jogging feedrate in mm/min
panel.gamma_jog_feedrate                     200               # z jogging feedrate in mm/min
panel.hotend_temperature                     185               # temp to set hotend when preheat is selected
panel.bed_temperature                        60                # temp to set bed when preheat is selected
# Example of a custom menu entry, which will show up in the Custom entry.
# NOTE _ gets converted to space in the menu and commands, | is used to separate multiple commands
custom_menu.power_on.enable                true              #
custom_menu.power_on.name                  Power_on          #
custom_menu.power_on.command               M80               #
custom_menu.power_off.enable               true              #
custom_menu.power_off.name                 Power_off         #
custom_menu.power_off.command              M81               #
# Only needed on a smoothieboard
currentcontrol_module_enable                  true            #
return_error_on_unhandled_gcode              false            #
# network settings
network.enable                               true             # enable the ethernet network services
network.webserver.enable                     true             # enable the webserver
network.telnet.enable                        true             # enable the telnet server
#network.ip_address                           auto            # use dhcp to get ip address
# uncomment the 3 below to manually setup ip address
network.ip_address                           192.168.3.221    # the IP address
network.ip_mask                              255.255.255.0    # the ip mask
network.ip_gateway                           192.168.3.1      # the gateway address
#network.mac_override                         xx.xx.xx.xx.xx.xx  # override the mac address, only do this if you have a conflict
open | download - 2016-09-30-22_40_13.ogg (61.9 KB)
Re: Nema 17 Stepper Motor Noise
October 01, 2016 08:10AM
I can't make out much from your recording, but kudos for trying it!
Is this something that was working and then failed, or are you trying to get it working for the first time?
When steppers don't turn there are usually just a few things to check.
1) motor current is much too high or low. If the motor is getting hot quickly, the current is probably too high. You values in the config look reasonable assuming typical NEMA-17 sized motors.
2) one motor coil is disconnected or wired backwards.
3) acceleration and/or speed is too high- your values look OK- check the speeds set in the slicer...
4) the motor driver is damaged- often occurs when the motor is connected/disconnected while the board is powered up. If one of the motor wires has an intermittent connection, it can destroy the motor driver.
5) there may be a mechanical problem (binding int he mechanism) preventing the motor from turning.
October 12, 2016 05:56PM
I use Stepper Motor - 68 oz.in (400 steps/rev).
I heard half-stepping options. Motors work quieter with half-stepping. How to change full stepping to half stepping?
October 13, 2016 04:38AM
since your showing smoothie configuration I presume you talking about MKS Sbase 32-bit Controller not as you listed MKS Base
As I understand it this board is always in 1/16 or 1/32 microstepping mode
see
October 13, 2016 06:51AM
Thank you for your helping. I changed the pin and current values and sound decreases, but "viyuv viyuv" sounds continue to come.
October 13, 2016 07:48AM
The step pulses are too short. Try changing it to 5 us.
Why does the definition on the left not match your note on the right? ~80 steps/mm is typical of a 200 step/rev motor with a 20 tooth pulley running at 16:1 ustepping.
Edited 2 time(s). Last edit at 10/13/2016 07:54AM by the_digital_dentist.
October 13, 2016 11:04PM
they are using 0.9 degree steppers not 1.8 degree, this all values are approximately double
" I use Stepper Motor - 68 oz.in (400 steps/rev)."
October 14, 2016 07:36AM
Try increasing pulse duration...
October 14, 2016 10:51PM
Sorry to make you confused.MKS SBASE is compatible with Smoothieware that supports 1/16 and 1/32 .But MKS BASE is MEGA2560,use 4982stepper drivers which only supports 1/16.
October 15, 2016 11:07AM
Yes, my motor is 0.9 degree. Which values should be double?
Dust
October 15, 2016 01:55PM
I think the problem may be that the MKS SBASE uses DRV8825 drivers, which are known to be noisy with low-inductance motors when configured in fast decay mode, especially when using higher supply voltages. But I don't know whether the MKS SBASE does configure the drivers in fast decay mode. See [cabristor.blogspot.co.uk] for more.
December 21, 2016 04:04PM
dc42
I looked at the website (http://cabristor.blogspot.co.uk/2015/02/drv8825-missing-steps.html), but there is also sound (like a music) when extruder print a circle shape. I listen to Zortrax, Makerbot and Ultimaker, there is no sound when printing. Why? What are their boards, motors or motor drive?
December 21, 2016 05:45PM
cagtag
...but there is also sound (like a music) when extruder print a circle shape. I listen to Zortrax, Makerbot and Ultimaker, there is no sound when printing. Why? What are their boards, motors or motor drive?
That sound is entirely normal unless you either use stepper drivers with very high microstepping (e.g. 256x which is what I use), or you use dampers and soundproofing which I expect the commercial machines have.
December 21, 2016 07:11PM
dc42
cagtag
That sound (like a music) is not normal. In commercial machines there is no music, it is very silent. Which value do you say for microstepping in config file (I shared it in the first entry). If you can help me, I will very happy.
December 22, 2016 03:43AM
Read all of my response, not just the first 4 words.
One of my printers uses 16x microstepping, no dampers, and has no enclosure. It produces the "music", which is normal for this design of printer. The other is virtually silent while printing, apart from the fans, since I switched it to 256x microstepping. Again it has no dampers or enclosure.
Your DRV8825 drivers are limited to x32 microstepping, which is better than the x16 that is still used by a lot of 3D printers. If you want to make it quieter without changing the drivers, you could try installing Astrosyn dampers if your printer has room for them. I've never used them, so this isn't a recommendation.
Edited 4 time(s). Last edit at 12/22/2016 03:52AM by dc42.
December 22, 2016 11:36AM
dc42
Astrosyn dampers are awesome! I found them! Thank you smiling smiley Additionally, which boards include 256x microstepping stepper drives? I buy it directly.
December 23, 2016 12:04AM
cagtag
Duet Wifi.
BZB
January 04, 2017 02:59AM
or See
