Would moving from A4988 to TMC2130+ improve/affect print quality? March 29, 2018 10:29PM |
Re: Would moving from A4988 to TMC2130+ improve/affect print quality? March 30, 2018 03:34AM |
Re: Would moving from A4988 to TMC2130+ improve/affect print quality? March 30, 2018 02:48PM |
Re: Would moving from A4988 to TMC2130+ improve/affect print quality? March 31, 2018 03:00AM |
Re: Would moving from A4988 to TMC2130+ improve/affect print quality? March 31, 2018 08:11AM |
Re: Would moving from A4988 to TMC2130+ improve/affect print quality? April 02, 2018 05:10PM |
Cool, I'll pick some up.Quote
dc42
Vertical line artefacts on flat surfaces when the layer height is an exact number of full steps may be caused by low-current microstepping issues. These are common when using DRV8825 drivers, but A4988 drivers can suffer from this too. TL smoothers or equivalent (2 pairs of back-to-back diodes in series with each phase) will help with that.
Is there a feature-rich slicer that you'd personally recommend? I'm using Cura 3.2.1.Quote
dc42
If the vertical lines occur only on curved surfaces, then that's an issue with either the STL model having too low a resolution in the first place (i.e. the plane segments used to approximate a curved surface are too large) or a slicer issue.
The one on the cylinder is a layer change seam. You can choose in the slicer whether to have a seam like that or to randomise the layer change point. Layer change artefacts are difficult to get rid of, but you can experiment with the following:
- printing external perimeters first or last
- pressure advance amount, or coast to end amount in the slicer if you are not using pressure advance
- retraction on layer change
Not sure, how would I find that out? Anything in here?Quote
dc42
I think you may also have a small amount of Z banding. Are you using PID or bang-bang control of the bed heater?
; Heaters M305 P0 T100000 B4138 C0 R4700 ; Set thermistor + ADC parameters for heater 0 M143 H0 S100 ; Set temperature limit for heater 0 to 100C M305 P1 T100000 B4138 C0 R4700 ; Set thermistor + ADC parameters for heater 1 M143 H1 S300 ; Set temperature limit for heater 1 to 300C M570 H1 P30 T10 S120 ; Give more time to heat up M302 P1 ; Allows for Cold Extrusion ; Tools M563 P0 D0 H1 ; Define tool 0 G10 P0 X0 Y0 Z0 ; Set tool 0 axis offsets G10 P0 R0 S0 ; Set initial tool 0 active and standby temperatures to 0C ;M563 S1 ; Allows for tool nomenclature compatibility between Slic3r and RepRap (Tools 0&1 vs Tools 1&2)
Re: Would moving from A4988 to TMC2130+ improve/affect print quality? April 02, 2018 06:50PM |
Re: Would moving from A4988 to TMC2130+ improve/affect print quality? April 03, 2018 02:34AM |
M307 H1 A340.0 C140 D5.3 B0 S1 V0
Re: Would moving from A4988 to TMC2130+ improve/affect print quality? April 03, 2018 12:48PM |
Re: Would moving from A4988 to TMC2130+ improve/affect print quality? July 12, 2018 02:12PM |
