Re: Tripteron Implementation December 16, 2016 10:24AM |
o_lampe
I lost track of your actual joint design.
It's based 0n 15x15mm beams and uses M5 bolts. But what kind of bearing do you use? Simple brass bushings?
I weighted the first carbon-arm of my project, and the two 608 bearings add roughly 50% of the overall weight
Re: Tripteron Implementation December 16, 2016 12:55PM |
Re: Tripteron Implementation December 16, 2016 01:20PM |
Apsu
Alright, round two complete.
YouTube Link
Small amount of backlash/bounce present still, it's really hard to do this successfully with printed joints. Will have to think about the material design a lot harder. But it's an improvement!
Re: Tripteron Implementation December 16, 2016 01:39PM |
nicholas.seward
With a low enough jerk and acceleration setting, this could make amazing prints.
I think you just have to bite the bullet and go with wide joints. I think I would jump right to 40-50mm joints.
Re: Tripteron Implementation December 16, 2016 01:43PM |
Apsu
Hrm. Not sure how I want to proceed from here, short of machining.
Re: Tripteron Implementation December 17, 2016 04:43AM |
Re: Tripteron Implementation December 17, 2016 11:45AM |
o_lampe
It seems the collinear setup will be best with two parallel arms in 40-50mm distance. Almost like the normal delta rods looks like, but with cross-linked rods? Then use two separate screws instead of one long screw.
Re: Tripteron Implementation December 18, 2016 04:31AM |
Re: Tripteron Implementation December 21, 2016 03:25AM |
Re: Tripteron Implementation December 21, 2016 04:53AM |
Re: Tripteron Implementation December 21, 2016 06:41AM |
o_lampe
When you do the sarrus folding_under_bed test, do you see a chance to use a leadscrew to move the arms like a reversed scissor lift?
Re: Tripteron Implementation December 22, 2016 06:10AM |
Re: Tripteron Implementation December 22, 2016 10:34AM |
o_lampe
OT:
This Sarrus platform, would it be a good starting point for an SLA printer? I've seen cantilevered platforms, but the Sarrus seems stiffer against z-deflection to me.
Question is, will the resin run down the arms and mess up the whole printer? I guess, with the arms always below horizontal it would work. Laser would be below the VAT then.
BTW, I think following the ortho-tripteron path is better, especially without a machine shop.
Re: Tripteron Implementation January 01, 2017 04:36AM |
Re: Tripteron Implementation January 01, 2017 05:00AM |
Re: Tripteron Implementation January 01, 2017 05:12AM |
JonathanThompson
I vote for a two-prong approach:
1. Go with your planned high-end machined joints, as expensive as they are: this will set the high-end expectations of what someone can reasonably do with custom machining that doesn't involve a full assembly line.
2. Once that has been done, find a way with design changes to accomplish the same quality results using more 3D-printed parts (likely a number of custom-designed parts, but 3D-printed, so... does that count in your definition of custom?) that will likely be a bit more involved in design.
Then, watch and see what the rest of the community does as a result, be entertained!
Of course, the thing everyone needs to keep in mind is the Tripteron stuff is patented, so it would require licensing for more than one-off personal-use-only machines.
Re: Tripteron Implementation January 01, 2017 07:10AM |
Re: Tripteron Implementation January 01, 2017 07:18AM |
Re: Tripteron Implementation January 01, 2017 11:41AM |
o_lampe
I've been busy with my carbon rod version, too. But the rods I'm planning to use are still on their way, so I only made a mockup version based on a carrier I had left over from an older Delta printer and a set of 4x300mm long 6x4 carbon rods. ( The final version will be ~4x155mm long )
The carriers have a hole pattern of 20x20mm, so I'm planning to rotate them 90° on the MGN12 linear rails. I'll use the aluminum carriers from robotdigg, although I have to borrow them from my Kossel XL delta , until the proof of concept has been made.
Now the rods have distance of 40mm to each other and the brackets ( I have to glue them to the rods ) will provide enough stiffness, I hope.
The F628zz bearings are for M3 only but have a flange, so they clamp down by tightening the screw.
Re: Tripteron Implementation January 02, 2017 01:56AM |
o_lampe
Apsu, you like challenges?
How about building a dual X-axis printer? Make a cube from 2020 extrusions and use two carriers on the X- and Y-rail with separate Z-carriers on the opposite verticals.
Imagine how the effectors would dance with each other, simultaneously printing with two filaments
Forget it, just tried to visualize the route for separate belts for two carriers on the same rail... this would become ugly
Re: Tripteron Implementation January 02, 2017 04:14AM |
brazenrain
I've been using a lot of concepts from Tripteron/Delteron's development in my own design experiments. I'll probably end up with something that doesn't need the revolute joints, but my opinion is that a different geometry for the tripteron's Z-axis arm could make it a lot more rigid. The issue is that the effector's weight is cantilevered on just one (Z) arm, so the base joint has to carry that entire moment (the weight of the effector x the distance from the Z-axis rail to the effector. kind of like a torque). This can be optimized for by making the Z-arm's first joint wider. (The second joint in the arm's elbow only sees half the moment). Something like a Y-arm to separate the joint into two colinear bearings would help to distribute the moment into two radial loads. The upper one gets pulled forward and the lower one gets pressed back away from the effector. Tension and compression at the base of a classic cantilever beam. An even better example of what I have in mind (though it probably wasn't set up that way for the same reason) is spacex's strongback. Just turn the picture 90 degrees.
I've got another one. Put two carriages on one extra-long rail, with independent belts, and connect them to an effector with a single linkage each. Moving them both in the same direction is your x-axis, and moving them closer together is your +y direction. This video is probably a better start to visualizing it: https://youtu.be/_vp1ELEtDN4
Up to 0:16 are the 2 degrees of freedom you need. The effector's rotation needs to be constrained by a third arm, parallel with one of the first two. (Maybe it could do double duty as the cable guide.)
Unlike tripteron, the joints' radial backlash matters, but the bearings in previous designs are already up for that task. The cantilever problem is still there, but helped somewhat by having two arms and losing the elbows. I'd still use a double-joint like I described above.
Anyway, the result would be a single rail for an XY-gantry with a usable area about 1/3 of its total length, squared. So a 300x300 build area would require a 1000mm rail. Kinematics for the y-axis are similar to a delta robot's arms. the near-half of the build area has less y-resolution, the far half has more.
Calibration could be done automatically by having both carriages pass through the same point like a non-contacting endstop to measure the distance between them. As long as the two main arms are identical lengths
As for the Z-axis, with the entire XY-gantry on one rail it might be easier to set the whole thing on leadscrews and enjoy a completely stationary bed. Essentially, take a prusa i3 and replace its y axis with a second x-carriage that uses delta kinematics. (Sorry to steal your prusa/delta lovechild metaphor, Apsu, but this is way more direct).
Unfortunately the arms passing through the build area's perimeter make it difficult to enclose without boxing up the whole thing (3x the volume). For that reason I'm currently looking into other options for a cantilevered xy gantry to retain the stationary build platform, but here's what I had planned so far using openbuilds parts. $20 for the rail, $42 for wheels, and $24 for carriage plates:
Happy 2017!
Re: Tripteron Implementation January 02, 2017 05:09AM |
Re: Tripteron Implementation January 02, 2017 11:24PM |
Apsu
That said, the Delteron helpfully sidesteps pretty much all of those issues. The symmetry and arm angling causes most of the gravity load to be redirected into lateral loads on the arm joints, leaving the effector untouched. Honestly, since the same arms can be used on the Tripteron as the Delteron, if I can get a more rigid construction right away I'm going to feel hard-pressed not to try it on the Delteron first. I find it a more appealing, more elegant, and simpler design.
Re: Tripteron Implementation January 02, 2017 11:53PM |
brazenrain
Re: Tripteron Implementation January 04, 2017 12:38AM |
Re: Tripteron Implementation January 04, 2017 12:58AM |
brazenrain
Cool, sounds like we're on the same page. The arms are purely for extension, but their shape can be misleading. I had this crazy thought experiment that you could build a more easily enclosable tripteron using drag chains as arms.
They have the exact same degrees of freedom freed, but backlash probably stacks up too easily for the X and Y axes that have to move in both directions. (maybe gravity would preload out the slop for Z?)
Anyway there's no doubt in my mind that if the root problem actually is supporting the effector's weight, then a longer joint can fix it. That's just how cantilevers work, but you'll have to be crafty about making sure the bearings are coaxial so the hinge doesn't bind.
So in the spirit of simplicity and making progress faster, I wonder if this will help the current version: http://www.thingiverse.com/thing:2013647
I'd suggest printing just one to swap onto tripteron's z-axis carriage. I basically added material to brace against the printed lugs' weak direction in bending right at its weakest point, and it should improve the effector's stiffness most when the arm is extended. When the effector is closer to the z-axis rail the base joint is mainly loaded in torsion. This new geometry will help with that too but it isn't optimized for that case. If there isn't a difference at all, then the original lug thicknesses are probably sufficient. Because the new part itself is stiffer, it will require more force to clamp it down on the mating part, but I don't see it being more than you're already using. What do you think?
Re: Tripteron Implementation January 04, 2017 10:24PM |
Re: Tripteron Implementation January 04, 2017 10:43PM |
brazenrain
Ah you've been busy. Have you tested tripteron with the at least half-cube in the thingiverse model?
Yeah, I was thinking in the same direction. Also to see how well oillite-type bushings slide against each other.Quote
The problem with only using bushings is they need to slide past each other at some point which limits how much you can preload the joint. Maybe ptfe washers as a substitute for bearings.
If machined parts solve everything - a stable tripteron and non-binding delteron - that's going to be a genuinely fun task to make comparable printed parts. Aluminum is at least 20X as stiff as PLA, but there are plenty of ways to optimize the geometry to compensate. For instance, making the forks thicker will actually reduce deflection caused by bending more effectively than making the forks' radii bigger, for the same mass increase. Perpendicular flanges even more so. I'll be looking forward to the machined version working, fingers crossed.
In the meantime, if you can do it with your cad program can you post a section cut of the joint? Something like this.
Re: Tripteron Implementation January 04, 2017 10:47PM |
Apsu
Almost. I didn't get the side frame on it, just the back one. You can see it here pretty clearly.
Re: Tripteron Implementation January 05, 2017 12:49PM |
