Re: Tripteron Implementation January 05, 2017 01:08PM |
o_lampe
I just stumbled across an interesting bearing type called "cam follower cf5"
This might be a good solution for the z-axis dual rods?
Re: Tripteron Implementation January 06, 2017 02:11AM |
Re: Tripteron Implementation January 06, 2017 11:15AM |
brazenrain
It sure would be nice if there was a 15mm version of this. You could just throw in some slippery washers or thrust bearings and be done with it.
I'm not sure if you could find any made for 1515 and 2020 is pretty bulky, but this is what I had my eye on previously. I also don't know what kind of lateral load stiffness they have, but it's probably pretty good since they're designed for framing moving portions of large assemblies.|
Re: Tripteron Implementation January 06, 2017 02:49PM |
Re: Tripteron Implementation January 06, 2017 10:43PM |
Re: Tripteron Implementation January 07, 2017 08:38AM |
MechaBits
Nice joints, musta cost a packet, looking forward to seeing them in action.
Not going to be cheap, but I hope to A) have a kickass machine and
better inform the next design iteration. We'll find out!
Re: Tripteron Implementation January 07, 2017 12:47PM |
Re: Tripteron Implementation January 07, 2017 01:41PM |
brazenrain
In the meantime I'm looking into these. How do you think delteron will hold up with 10mm arms?
Re: Tripteron Implementation January 08, 2017 01:16AM |
Re: Tripteron Implementation February 03, 2017 12:55AM |
Re: Tripteron Implementation June 29, 2017 07:19AM |
Re: Tripteron Implementation September 02, 2017 05:43AM |
Re: Tripteron Implementation September 02, 2017 12:23PM |
Re: Tripteron Implementation September 02, 2017 01:30PM |
Re: Tripteron Implementation September 02, 2017 01:44PM |
Re: Tripteron Implementation September 14, 2017 03:06PM |
Re: Tripteron Implementation October 05, 2017 10:16AM |
Re: Tripteron Implementation December 28, 2017 04:02AM |
Prined with ABS 400mm stroke from Peter Pozorek on Vimeo.
Tripteron Three point servo bed probing from Peter Pozorek on Vimeo.
First print ,wrong stepping on Z axis,bad slicer settings from Peter Pozorek on Vimeo.
Re: Tripteron Implementation December 30, 2017 03:35AM |
Re: Tripteron Implementation December 30, 2017 01:51PM |
o_lampe
Good to see it working. But the overkill in part count you mention above, will make it a rare beast.
I gave up on my project, because printing those critical parts is almost impossible. I tried round carbon tubes and cam-followers as bearings but the housings either were too loose or cracked from pressing in the bearings.
Re: Tripteron Implementation July 26, 2018 03:40PM |
Apsu
brazenrain
I also ran across these but they're for larger profiles
[www.minitecframing.com]
But man are they rated for high lateral loads and appear to be rock-solid!
I wouldnt mind some of these, but cant see a price do you have any idea how much & who has them?
Re: Tripteron Implementation July 25, 2019 02:31PM |
Re: Tripteron Implementation July 30, 2019 01:10AM |
Re: Tripteron Implementation July 30, 2019 02:25PM |
Re: Tripteron Implementation July 31, 2019 05:08AM |
Admin Registered: 13 years ago Posts: 3,096 |
Apsu
So I've been thinking about this a lot lately, and I think that one of the difficulties I was facing even with the machined joints is that the bearings are the weakest point now. It occurred to me that I only went down the bearing route in the first place because I was trying to solve for printed joints. But if I get the machining route, there's some extremely simple and cheap to make part geometries that could be used instead.
For instance, using something very similar to a 3 or 4-hole flat plate designed for aluminum extrusion, bolted to the end of extrusion to form a fork, and similar on the other extrusion (to go outside the first fork), then a shoulder bolt or smooth shaft + low friction thrust washers/bushings could be used to fasten them together. Assuming there weren't premade parts that would work, these sorts of plates are extremely easy to machine so cost would be very low.
I may get some nylon or PTFE (or maybe even Igus) thrust washers and try a proof of concept with the simple 3-hole aluminum plates I have on hand, and report the results. But really, I don't think the bearing system is necessary and is an extreme overcomplication when not trying to use entirely printed parts.
Re: Tripteron Implementation August 15, 2019 01:15PM |
Ohmarinus
What if you were to use long polymer bushings or some long version of this: [www.robotdigg.com]
I think that could take care of both having linear movement as well as rotational movement and have a tight diameter without much play? Am I missing important details why this is or isn't a good idea?
Re: Tripteron Implementation August 15, 2019 01:48PM |
Re: Tripteron Implementation August 16, 2019 11:40PM |
Re: Tripteron Implementation August 17, 2019 02:26AM |
