I probably made the tiniest Z-Probe and it doesn't require changes to hardware December 02, 2016 10:12AM |
Re: I probably made the tiniest Z-Probe and it doesn't require changes to hardware December 02, 2016 08:02PM |
Re: I probably made the tiniest Z-Probe and it doesn't require changes to hardware December 02, 2016 09:59PM |
Re: I probably made the tiniest Z-Probe and it doesn't require changes to hardware December 03, 2016 06:01AM |
Re: I probably made the tiniest Z-Probe and it doesn't require changes to hardware December 03, 2016 06:13AM |
o_lampe
Did you try using the switch on a 110°C hot bed?
I always thought nozzle and bed should be at working temp before bed leveling. That wouldn't work.
I'm also concerned about the nozzle has to be perfectly clean without the smallest blob hanging out to get repeatable results.
Re: I probably made the tiniest Z-Probe and it doesn't require changes to hardware December 03, 2016 08:43AM |
o_lampe
Re: I probably made the tiniest Z-Probe and it doesn't require changes to hardware December 10, 2016 09:15PM |
