Leadscrew driven XY gantry printer? March 21, 2018 09:23PM |
Re: Leadscrew driven XY gantry printer? March 22, 2018 04:54AM |
Re: Leadscrew driven XY gantry printer? March 22, 2018 08:40AM |
o_lampe
I think I want to implement this design, except without moving the mass of the motors like in the video above shows.
Will be interesting to see, how?
My first idea was: bevelled gears and a keyed smooth rod to drive the bevelled gear.
Re: Leadscrew driven XY gantry printer? March 22, 2018 11:00AM |
o_lampe
Re: Leadscrew driven XY gantry printer? March 22, 2018 12:06PM |
gtj
o_lampe
So the "differential" slides along the keyed drive rod? Could be cool. Maybe use a square shaft rather than a keyed round one?
Re: Leadscrew driven XY gantry printer? March 22, 2018 03:23PM |
Re: Leadscrew driven XY gantry printer? March 24, 2018 11:06PM |
Re: Leadscrew driven XY gantry printer? March 24, 2018 11:10PM |
Trakyan
I recall lkcl planning to build a printer similar in concept. He wanted to use belts, thought but the placement of the driving force was the same (the belts/screws apply force very close to the X intersection). He ended up having an issue with binding when the XY assembly was further off center, it would cause a moment on the perimeter bearings since you're pulling/pushing close to one set of bearings than the other.
Re: Leadscrew driven XY gantry printer? March 25, 2018 02:12PM |
Re: Leadscrew driven XY gantry printer? March 25, 2018 04:13PM |
Re: Leadscrew driven XY gantry printer? March 25, 2018 04:47PM |
Re: Leadscrew driven XY gantry printer? March 25, 2018 05:20PM |
the_digital_dentist
It is laid out in a big circular loop. The frame attached end opens toward the front of the printer and the extruder carriage end opens toward the rear of the printer. That keeps the radius of curvature relatively large which should minimize wire failures due to excessive flexing. It's a little dark but you can see what it's doing in this picture:
