Re: First Printer, 225mm^3 printer / mill combo build April 12, 2014 12:30AM |
Re: First Printer, 225mm^3 printer / mill combo build April 13, 2014 08:54AM |
Re: First Printer, 225mm^3 printer / mill combo build April 13, 2014 03:58PM |
Re: First Printer, 225mm^3 printer / mill combo build April 18, 2014 11:02PM |
Re: First Printer, 225mm^3 printer / mill combo build April 19, 2014 03:04PM |
Re: First Printer, 225mm^3 printer / mill combo build April 19, 2014 10:35PM |
Re: First Printer, 225mm^3 printer / mill combo build April 23, 2014 10:50PM |
gmh39
Did you try loosening the tension on the filament? (Hobbed bolt). The filament should not be getting that distorted.
I don't run a Bowden, just assuming the filament tension is similar to a non-bowden extruder.
Re: First Printer, 225mm^3 printer / mill combo build May 15, 2014 07:13PM |
Re: First Printer, 225mm^3 printer / mill combo build May 16, 2014 10:55AM |
Re: First Printer, 225mm^3 printer / mill combo build May 16, 2014 11:04AM |
Re: First Printer, 225mm^3 printer / mill combo build May 16, 2014 12:52PM |
Re: First Printer, 225mm^3 printer / mill combo build May 16, 2014 01:18PM |
Re: First Printer, 225mm^3 printer / mill combo build May 16, 2014 03:17PM |
Re: First Printer, 225mm^3 printer / mill combo build May 28, 2014 11:40AM |
Re: First Printer, 225mm^3 printer / mill combo build May 28, 2014 12:12PM |
Re: First Printer, 225mm^3 printer / mill combo build May 28, 2014 12:14PM |
Re: First Printer, 225mm^3 printer / mill combo build May 28, 2014 01:13PM |
Re: First Printer, 225mm^3 printer / mill combo build May 28, 2014 10:33PM |
Re: First Printer, 225mm^3 printer / mill combo build May 29, 2014 06:12AM |
Re: First Printer, 225mm^3 printer / mill combo build June 01, 2014 10:57PM |
Re: First Printer, 225mm^3 printer / mill combo build June 01, 2014 11:31PM |
Re: First Printer, 225mm^3 printer / mill combo build June 02, 2014 12:23PM |
A2
Congrats on making it into the top 10 finalist of the Misumi "Build Brag Win" Contest
A2
Got a link to where you read this.
powool
On my 3mm bowden E3D, I have to run the fan all the time, and when a print is ended, make sure that I retract - I do it manually when I abort a print.
Re: First Printer, 225mm^3 printer / mill combo build June 02, 2014 02:25PM |
Re: First Printer, 225mm^3 printer / mill combo build June 02, 2014 03:43PM |
cnc dick
Yeah that's really pretty fast not to say that you can't do it but probably something you don't want to do on every print. That would be something to use on hollow single wall thickness and still get a good print but as a rule I usually print with ABS which is a little slower and I stay between 50 and 80 mm a second it can go much faster but print quality suffers not from machine wobbles but how well the plastic welds to layer below. I've never seen a pro printer in person but I did see plenty of videos and I don't think they even print at 100 mm a second maybe 80 mm a second. If you can post a couple videos of it running we would all like to see it
Re: First Printer, 225mm^3 printer / mill combo build June 02, 2014 04:36PM |
Re: First Printer, 225mm^3 printer / mill combo build June 02, 2014 04:58PM |
Alexander1984
What I saw from that last video seems like a lack of cooling the filament after being extruded.
You should definately get some sort of fan blowing at the PLA sideways.
Look at the Ultimaker 2 for example - it has two! fans more or less constantly blowing at the printed/extruded Plastic.
I saw one guy have just one of those two fans fail and the quiality went down a lot, so imagine how it would be without proper cooling.
Alexander1984
Also 235° seems really really hot.
Alexander1984
What layer-height are you printing at?
I'm at:Quote
Alexander1984
What are your values for Acceleration and Jerk?
#define DEFAULT_MAX_ACCELERATION {9000,9000,100,10000} // X, Y, Z, E maximum start speed for accelerated moves. E default values are good for skeinforge 40+, for older versions raise them a lot. #define DEFAULT_ACCELERATION 3000 // X, Y, Z and E max acceleration in mm/s^2 for printing moves #define DEFAULT_RETRACT_ACCELERATION 3000 // X, Y, Z and E max acceleration in mm/s^2 for retracts #define DEFAULT_XYJERK 20.0 // (mm/sec) #define DEFAULT_ZJERK 0.4 // (mm/sec) #define DEFAULT_EJERK 5.0 // (mm/sec)
Re: First Printer, 225mm^3 printer / mill combo build June 02, 2014 05:12PM |
Re: First Printer, 225mm^3 printer / mill combo build June 02, 2014 05:21PM |
A2
Tks found more about the nozzle orifice land length in this thread: [forum.seemecnc.com]
He put the hot end in the freezer to help extract the filament intact from the nozzle orifice.
Re: First Printer, 225mm^3 printer / mill combo build June 02, 2014 11:37PM |
Re: First Printer, 225mm^3 printer / mill combo build June 05, 2014 12:41PM |
