New build, pre-design questions, extrusions, shafts, dimensions, electronics February 03, 2017 06:04AM |
Re: New build, pre-design questions, extrusions, shafts, dimensions, electronics February 03, 2017 07:15AM |
Re: New build, pre-design questions, extrusions, shafts, dimensions, electronics February 03, 2017 09:51AM |
Re: New build, pre-design questions, extrusions, shafts, dimensions, electronics February 03, 2017 10:47AM |
Re: New build, pre-design questions, extrusions, shafts, dimensions, electronics February 03, 2017 02:21PM |
Re: New build, pre-design questions, extrusions, shafts, dimensions, electronics February 03, 2017 06:18PM |
Re: New build, pre-design questions, extrusions, shafts, dimensions, electronics February 05, 2017 10:28PM |
Re: New build, pre-design questions, extrusions, shafts, dimensions, electronics February 06, 2017 07:50AM |
Re: New build, pre-design questions, extrusions, shafts, dimensions, electronics February 18, 2017 05:17AM |
Re: New build, pre-design questions, extrusions, shafts, dimensions, electronics February 18, 2017 10:47AM |
Re: New build, pre-design questions, extrusions, shafts, dimensions, electronics February 19, 2017 07:28AM |
Re: New build, pre-design questions, extrusions, shafts, dimensions, electronics February 20, 2017 02:41PM |
Re: New build, pre-design questions, extrusions, shafts, dimensions, electronics May 13, 2017 03:17PM |
the_digital_dentist
2) They like to experiment with different surfaces: Some people will put kapton tape on one glass plate, PEI on another, and some other magical stuff on the third, fourth, and fifth plates, depending on whether they get better first layer adhesion with whatever material they are printing. Changing plates and print surfaces may require releveling and zeroing with each change. Pulling ABS prints out of a warm printer instead of letting it cool slowly may result in checking and delamination.
Re: New build, pre-design questions, extrusions, shafts, dimensions, electronics May 13, 2017 03:57PM |
SaleB
6. electronics. I have not been able to find if ARM boards do support Marlin firmware and does Marlin support this kind of machine. I would like it to be a 2560 Arduino based board, as I do want to pair it with a Raspberry I do not need all the functions that faster boards have. After the initial search I found a few boards interesting, but no reviews on any of them. The options that awoke my interest are MakerBase MKS 1.4, Megatronics 3.0 and Rumba. Essentially the board should have a few removable drivers and enough of them for at least two extruders, expansion connectors for card slot and graphic display. I like Rumba at most, but could not really tell why. Is there any real difference between the Rumba from various chinese sellers, highest price I found at a place called ReprapDiscount (with a bull head logo on back side), and for half of that price at a place called BigTreeTech (BIQU logo on the back side) , can there be any real difference between two chinese sellers? The only differences that I saw are blue and green screw terminals and heat sinks on the BIQU board against the black screw terminals and capton tape on the usb connector without the heat sinks on the RD board, both are clean and well soldered, and also one coil has different value between the two beards.
Re: New build, pre-design questions, extrusions, shafts, dimensions, electronics May 13, 2017 06:50PM |
Re: New build, pre-design questions, extrusions, shafts, dimensions, electronics May 13, 2017 07:58PM |
*splutter* that's.. that's a truly dreadful well-researched hard-hack: two diodes to lose 1.4v across each so that you get the proper sine-wave characteristics, eurghhQuote
the_digital_dentist
A couple things to know about the MKS Sbase boards:
1) DRV8825 drivers require some simple modification for them to work properly otherwise they will skip steps when moving slowly. See: [www.engineerination.com]#! 3D printers are not the right application for those driver chips, which should tell you something about the engineering that went into any 3D printer controller/driver module that uses them.
2) When you buy the MKS Sbase boards you don't get any support. The board runs smoothieware which is open source, but the MKS folks don't contribute to the project at all so the people who designed the smoothieboard and wrote smoothieware are not enthusiastic about helping people set up and debug their MKS Sbase boards. They'll help, but only after you try (and fail) to get help from MKS. See [smoothieware.org][]=mks
Re: New build, pre-design questions, extrusions, shafts, dimensions, electronics May 13, 2017 08:23PM |
Re: New build, pre-design questions, extrusions, shafts, dimensions, electronics May 13, 2017 09:33PM |
the_digital_dentist
Should the smoothieware/smoothieboard developers be answering questions about print problems caused by DRV8825 drivers? I think they have enough work to do to support the stuff they produce and to produce more and new stuff. The smoothieware folks were nice enough to open source their work. It doesn't mean they have to provide free tech support for every company that chooses to use their stuff.
Re: New build, pre-design questions, extrusions, shafts, dimensions, electronics May 16, 2017 04:51AM |
lkcl
ok please for god's sake don't use removable drivers. i've mentioned this any number of times but the history behind the original sanguilino-based reprap printer board for the very first mendel was that they used *prototyping* boards supplied by the manufacturer, which you see on those little breadboards. i know someone who actually had one: he showed it to me and i now have it. in actual use they STOPPED WORKING half way through a print because they got so hot. the datasheet CLEARLY STATES that the driver ICs use the exposed pad to wick heat away, and that there is a CERAMIC INSULATOR on the top, and that the *PCB* is supposed to be designed to remove the heat. now, the problem with the insulator being on the top of those ICs is that no amount of heatsinks or fans will help you to stop them from overheating and failing during a printrun. those tiny PCBs are *nowhere near* big enough for the heat to properly dissipate AS THE IC IS DESIGNED AND INTENDED TO BE USED BY THE MANUFACTURER.
so please.
for god's sake.
would people *please* stop designing and selling polulu and polulu "compatible" electronics, and please stop recommending them.
the_digital_dentist
Re: New build, pre-design questions, extrusions, shafts, dimensions, electronics May 16, 2017 07:22AM |
i found out only yesterday that reprappro - the business that adrian started when he began the 3d printing revolution - has sadly had to shut down. why? because there is *so much* out there - most of it not really very good - that they decided to quit whilst they were still in the black. there's a huge amount that people don't know - me included, we're all learning, but i find it quite sad that we can't get our (plural) act together and financially support the people who provide the best information and hardware.Quote
SaleB
I did not know that.
My safe bet was Azteeg, but this new information disqualifies most of their products.
the_digital_dentist
Taking the this into account there are only a few controller boards left, both Duets, Replicabe, Smothieboard, but non of them cheap. And all of that makes much better case for a Duet.
In the mean time a have found a few more controllers, one of them being Aligator board which may be abandoned project or still a work in progress and something new that I have found in last few days.
Another Chinese product, a Pibot uses a new approach, independent motor drivers which may or may not be an advantage. It does not use the DRV8825's, but rather Toshiba 6600. It can handle 24V, and has more powerful processor.
