HyperCube OverKill Build Log January 29, 2018 10:29PM |
Re: HyperCube OverKill Build Log January 30, 2018 03:44AM |
Re: HyperCube OverKill Build Log January 30, 2018 08:06AM |
HyperCube OverKill Build Log - Gantry Frame January 30, 2018 01:33PM |
HyperCube OverKill Build Log - Perimeter RaIs February 09, 2018 08:54PM |
HyperCube OverKill Build Log - Cross Rails & Center Carriage February 11, 2018 10:58AM |
Re: HyperCube OverKill Build Log February 12, 2018 04:14PM |
Re: HyperCube OverKill Build Log February 12, 2018 08:17PM |
stamos
I like the aesthetics of carbon rods more, but that's just me.
stamos
I really like your design, but I think that is more of an Ultimaker's kinematics evolution than "Hypercube Evolution" .... evolution.
[/quote]Quote
stamos
...May be, I am wrong. I can not understand do you move both ends of x/y axis with this configuration
HyperCube OverKill Build Log - XY Motors and Idlers February 14, 2018 08:34PM |
HyperCube OverKill Build Log - XY Belts February 14, 2018 08:45PM |
This particular nut is how the end-stop trigger/belt tensioner cover will attach.
Re: HyperCube OverKill Build Log - XY Motors and Idlers February 15, 2018 04:10AM |
Re: HyperCube OverKill Build Log - XY Motors and Idlers February 15, 2018 10:00AM |
o_lampe
Your motor- and idler mount has not the best mounting to fight against belt tension.
I photoshopped a suggestion to use the T-slot as a second snap-in support.
Re: HyperCube OverKill Build Log February 15, 2018 11:03AM |
Re: HyperCube OverKill Build Log February 15, 2018 12:07PM |
the_digital_dentist
Your design has the motor attached to a relatively thin vertical blade that is attached to thin bottom plates (it sort of looks like an i3 printer frame). The belt tension is going to apply a twisting force to the motor and the blade is going to twist. If you want to make a solid motor mount that fits in the space you have allotted for it, forget the piece that goes under the motor- it isn't doing much.
the_digital_dentist
Mount the motor on a block of plastic that has holes cut in it for the pulley and belt. That will be much more solid, and it will be easily printable in a single piece.
Designing a part like this is easy- start with a solid block, make a hole for the motor shaft and pulley, cut a couple holes in the side for the belt and so you can get a tool in to tighten the pulley's grub screw, then make holes for mounting it on the printer frame and to mount the motor. Leave in as much plastic as you can, because it all contributes to the rigidity of the mount. If you really work it right you might even be able to screw the block to both the horizontal and vertical frame members. This is like a cube type printer frame compared to an i3 type frame- the cube is far more rigid.
Re: HyperCube OverKill Build Log February 16, 2018 08:07AM |
Re: HyperCube OverKill Build Log February 16, 2018 09:39AM |
Re: HyperCube OverKill Build Log February 16, 2018 09:41AM |
Re: HyperCube OverKill Build Log February 17, 2018 05:34AM |
Re: HyperCube OverKill Build Log February 17, 2018 10:10AM |
DLF
How come you choose not to make it more massive/box-like? Like DD suggested? Seems unnecessary to build such a strong frame and then add what in my mind looks like a weakpoint.
If it doesnt hinder the function I would try to add mass to that mount to prevent flexing/distortion.
Re: HyperCube OverKill Build Log February 17, 2018 02:38PM |
Re: HyperCube OverKill Build Log February 17, 2018 05:32PM |
DLF
I see. I have not tried carbonfiber filament so I dont know how it compares to other filaments. Still, if this was me building I would gladly sacrifice a bit of travel to gain all the rigidity I can get. It's still a plastic FFF mount we are talking about. Just to be Clear I am not trying to rag on your build, overall I think it looks great! These are just my two cents regarding this detail
Re: HyperCube OverKill Build Log February 17, 2018 06:10PM |
Re: HyperCube OverKill Build Log February 17, 2018 07:07PM |
the_digital_dentist
If you ever intend to enclose the printer to print ABS, or there's any chance it will ever get left in a hot car, you might want to reconsider use of PLA based filament (CF or not) for the printed parts.
HyperCube OverKill Build Log - Electronics February 21, 2018 05:31PM |
Re: HyperCube OverKill Build Log March 02, 2018 03:46AM |
Re: HyperCube OverKill Build Log March 02, 2018 12:18PM |
Vigilant
You’ve changed the kinematics, technically that’s no longer a hypercube.
Vigilant
Where did you get the carbon fibre rods? Did you cut them yourself ?
Vigilant
Is there a reason why you’re not using 1 huge diameter carbon rod instead of 2 small ones. I do think 2 14mm diameter looks neater than 4 10mm just like ultimaker.
Vigilant
Project looks good . I’m so curious how the dual motor setup performance is vs a single motor with a shaft connecting both sides. Will it introduce artifacts to the print?
Re: HyperCube OverKill Build Log - Cross Rails & Center Carriage March 03, 2018 02:14PM |
Re: HyperCube OverKill Build Log March 03, 2018 09:52PM |
Re: HyperCube OverKill Build Log March 04, 2018 06:19PM |
the_digital_dentist
I've seen printer mechanisms that run at high acceleration and it looks impressive, but making extrusion work so you get a quality print is whole different problem.
Re: HyperCube OverKill Build Log March 05, 2018 03:55AM |
