Three point bed adjustment November 04, 2018 07:51PM |
Re: Three point bed adjustment November 04, 2018 08:54PM |
Re: Three point bed adjustment November 06, 2018 12:51PM |
Re: Three point bed adjustment November 06, 2018 08:19PM |
Re: Three point bed adjustment November 07, 2018 08:48AM |
Re: Three point bed adjustment November 07, 2018 12:05PM |
Re: Three point bed adjustment November 07, 2018 12:47PM |
Re: Three point bed adjustment November 07, 2018 01:32PM |
charlieRC
I am building this printer...
I will check out the cast/tooling plate.
Re: Three point bed adjustment November 07, 2018 01:40PM |
the_digital_dentist
I came up with the kinematic mount because the bed gets hot and the carriage plate, on which the levelers mount, does not. That means that when the plate heats up it pushes the levelers sideways which makes things (usually the carriage plate) bend. The kinematic mount allows the bed plate to expand without creating any bending forces. The plate can expand in X or Y at the pitch adjuster by just sliding over the pitch adjuster's head, and can expand in X and Y at the roll adjuster because it can just slide on top of the roll adjuster screw.
Re: Three point bed adjustment November 07, 2018 04:08PM |
charlieRC
I am building this printer to be all lead screw. You said that you were moving from ball screw to belts. May I ask why? I would think that ball screw would provide the best accuracy of the three (lead, ball, belt). Of course this is coming from someone that until I started this project, has never used anything but belts and threaded rod.
Re: Three point bed adjustment November 07, 2018 09:56PM |
Re: Three point bed adjustment November 08, 2018 05:49PM |
gmedlicott
If you're building a printer and want to use a rigid 1/4 bed, a printer with the bed only traveling in the Z is the better option I think..
the_digital_dentist
The printer I am working on originally used a belt drive, but I switched to a precision ground ball screw because it was available for free, and because I thought it might solve some ringing problems I was seeing in the prints. I'm going back to belt drive because the ball screw/motor had a large resonance at about 50 mm/sec that caused it to skip steps. I could print at 150mm/sec with it, but whenever the speed dropped into that 50 mm/sec range, such as when printing large round objects, it would start skipping (and making a lot of noise). I had to keep print speed down to 40 mm/sec to avoid hitting that resonance, and it worked fine but was very slow and relatively noisy. Ball screws are very efficient at transferring vibrations from the motor to the bed plate.
Re: Three point bed adjustment November 09, 2018 11:10AM |
Re: Three point bed adjustment November 09, 2018 02:36PM |
the_digital_dentist
NEMA-17 motors vibrate less than NEMA-23 motors, and AFAIK, resonance seems to be less of a problem with the smaller motors. Throwing more money at the motors won't help, but throwing it at the drivers might. Advanced drivers (see [www.geckodrive.com]) sense resonance and do tricks to reduce its effect.
Re: Three point bed adjustment November 09, 2018 10:32PM |
charlieRC
Ok, so here’s the sandwich plan... I have a bottom mounting plate of 1/8th aluminum that rides on v-slot rails and wheels. The 1/4” aluminum plate will be mounted to the mounting plate with a semi fixed point in the left rear and a spring loaded leveling point in the right rear. I will have a spring loaded pitch adjusting point in the middle of the front. The heating element will be stuck to the bottom of this plate. On top of that, I will have a PEI sheet adhered to the 1/4 aluminum with 3M 468MP adhesive . The surface will be 12x12”.
What do you think of that arrangement. At this point, I am moving into unknown areas for me (no glass, PEI, 3 point leveling, etc) so I am open to suggestion.
My existing arrangement has served me well in that I have no adheasion issues, only need to reapply hairspray every 5 to 10 prints, and clean the glass plate with acetone every year or so. Having never done anything else, I thought it time to explore other options. I obviously don’t subscribe to the “if it aint broke...” mind set.
Re: Three point bed adjustment November 10, 2018 02:52PM |
very encouraging. I am at the point that I have to sneak all expendatures past my wife, so I was going to try and get by with the 1/4" `12x12 plate instead of the cast aluminum one (shipping and all is probobly about $60) but I put a staight edge ont the 1/4" plate and realize I need the casts plate. Oh well...."Hey honey... Look over there...what is that" while I pull out the credit card.Quote
sdavi
I have a similar setup to what you are planning. Duet WIFI with a custom CNCed 3mm alu plate running on V-slot (c-beam), 270x230x6.35mm ATP-5 cast aluminium plate with 3 point mounting, 24V kapton heater underneath and a PEI sheet stuck on top.
I'm using The Digital Dentists Teflon Mounting Technique. Teflon sheet from ebay cut on CNC to make the mounts. I've had this setup for over a year now and have only leveled it once (when I installed it!).
[attachment 107953 Bed.jpg]
Re: Three point bed adjustment November 11, 2018 09:46AM |
Re: Three point bed adjustment November 11, 2018 11:53AM |
Re: Three point bed adjustment November 11, 2018 12:37PM |
Re: Three point bed adjustment November 11, 2018 12:58PM |
