Re: Grounded Experimental Delta Printer December 01, 2013 10:40PM |
nicholas.seward
I already have the electronics for the beta kits but all of those will be getting paired with the mechanicals so I can do some consistent beta testing. It won't be until December when I will be doing this for real.
Re: Grounded Experimental Delta Printer December 01, 2013 10:49PM |
Re: Grounded Experimental Delta Printer December 01, 2013 11:14PM |
Re: Grounded Experimental Delta Printer December 01, 2013 11:34PM |
Re: Grounded Experimental Delta Printer December 02, 2013 04:38AM |
Re: Grounded Experimental Delta Printer December 02, 2013 06:06AM |
brandonh
Nicholas, that mod looks great. Why not make that the default? I don't see any disadvantages. If there's a part you're on the fence about, you can alway push it to a branch on GitHub. Then everyone can have access.
Also related to the part, where does the string go from the tuner spool? This is what I'll call the part that the string goes in and then turns, on the guitar peg winder. Looking at the Simpson Flickr set (e.g. [www.flickr.com]), the positioning of the tuner spool is quite different. On the most recent files I'm looking at, the tuner spool and a screw are both popping out of the big flat side, just like the motor. On the pics, the tuner spool goes into the channel between the two gear halves. I have to assume this was some design improvement; do you have any pics with the (presumably newer) motor arm showing the line winding? Thanks.
Re: Grounded Experimental Delta Printer December 02, 2013 07:59AM |
Re: Grounded Experimental Delta Printer December 02, 2013 08:28AM |
Re: Grounded Experimental Delta Printer December 02, 2013 09:07AM |
nicholas.seward
@brandonh: Added the branch. Great idea. I am new to source management. [github.com] I will merge it once we can verify that it doesn't cause any problems.
nicholas.seward
The string goes from the pulley around a motor/slave bolt pair and then around the back edge and to a spring or the tuner. Sorry no pictures yet. I have the switch over in my queue. :-)
nicholas.seward
Taper the end of the PTFE tube and then thread a M4 nut directly on. I have yet to test it myself but owens assures me that it is super strong as in it can't be pulled off by hand. Try it out and let me know. I opted to not go for the pressfits because they are a specialty item and I figure I already exceeded my quota with the tuning pegs. I originally had a pressure cone. That worked but if you over tighten the cone decreased the ID of the tube and added drag.
I just realized I probably should make the BOWDEN NUT taller so it can keep the tube perpendicular to the nut. I will test this soon. No need to optimize unless there is a problem.
Re: Grounded Experimental Delta Printer December 02, 2013 09:14AM |
Re: Grounded Experimental Delta Printer December 02, 2013 10:18AM |
Re: Grounded Experimental Delta Printer December 02, 2013 10:23AM |
brandonh
Right, but then you've got to thread an m4 nut on slippery PTFE for 3 full inches, which seems like a bit of extra effort. If the nut was at the bottom of Hub Bottom, next to the hotend, and inserted first, you could eliminate the Bowden nut entirely, as well as chop 20 mm of plastic off of this part. Yes, you might need to thicken Hub Bottom to do that, and yes, it might be harder to remove the tube.
Re: Grounded Experimental Delta Printer December 02, 2013 03:02PM |
Re: Grounded Experimental Delta Printer December 02, 2013 03:08PM |
Re: Grounded Experimental Delta Printer December 02, 2013 11:28PM |
Re: Grounded Experimental Delta Printer December 03, 2013 01:54AM |
pjoyce42
Is the GUS Simpson a viable option as a first 3D printer? Why or why not?
pjoyce42
I'd like to know how big of a project it would be to try and build a GUS from just the github files, and this forum
[forums.reprap.org]Quote
nicholas.seward, November 21, 2013 12:58PM
I use a Printrbot Plus. I hope I can get Simpson and Wally dialed in enough that I can use them also but for now it is just the Printrbot Plus.
nicholas.seward, October 09, 2013 05:03PM
As you can see from the graph that I was off as much as .4mm. While 400 microns isn't a whole lot it should still be accounted for. You can see on the graph that when I go to 2.5 wraps like I plan to do it should bring the max error down to 230 microns. However, math is cheap.
nicholas.seward, October 11, 2013 12:19PM
2) The math is not hard. See annirak's equations above. I haven't implemented yet because I need a few hours to make absolute certain that I make the second order adjustments in the right direction.
Re: Grounded Experimental Delta Printer December 03, 2013 11:31AM |
Re: Grounded Experimental Delta Printer December 03, 2013 10:18PM |
Re: Grounded Experimental Delta Printer December 04, 2013 12:58AM |
Re: Grounded Experimental Delta Printer December 04, 2013 01:20AM |
Re: Grounded Experimental Delta Printer December 04, 2013 01:41PM |
A2
@Owen,
The new arms look great! Tks for posting the video.
Hysteresis, Brownian motion, White noise:
Am I seeing hysteresis (string lag) at the start of the first movement?
I don't envision it being an issue with all 3 arms in motion, and printing a raft will also account for it.
Re: Grounded Experimental Delta Printer December 04, 2013 10:10PM |
Re: Grounded Experimental Delta Printer December 05, 2013 01:48AM |
Re: Grounded Experimental Delta Printer December 05, 2013 01:55AM |
The max travel for the OneUp is approximately 100x100x125mm while the TwoUP has 175x175x125mm.Quote
pjoyce42
I will probably get a QU-BD OneUP [...] then I will probably start working on a GUS, or Lisa Simpson.
Re: Grounded Experimental Delta Printer December 05, 2013 08:55AM |
Re: Grounded Experimental Delta Printer December 05, 2013 11:13AM |
Re: Grounded Experimental Delta Printer December 05, 2013 11:42AM |
dpharris
Getting non-printed arms absolutely equal length might be hard.
Re: Grounded Experimental Delta Printer December 05, 2013 02:05PM |
Re: Grounded Experimental Delta Printer December 05, 2013 03:10PM |
Re: Grounded Experimental Delta Printer December 05, 2013 05:42PM |
