Re: Grounded Experimental Delta Printer December 06, 2013 06:54PM |
A2
@nicholas.seward
Simpson 3d printer calibration:
What does calibration involve, after thinking about it I don't have a clue
If I were to guess calibration would entail some of the following:
Accurately measure the center to center distance of pivots (arm lengths).
Temperature control of hot end and platen.
End stop firing.
Stepper motor voltage, amps.
Platen leveling.
The amount of nonlinear movement of the end effector.
Range of motion (envelope perimeter).
Or is it about testing sleeve pulleys for the string, and things of that nature?
Re: Grounded Experimental Delta Printer December 06, 2013 10:49PM |
nicholas.seward
@pjoyce42: You can print it in the orientation given. Most printers can bridge that far. It may sag but you have tons of layers until you get to the gear part so most printers will self-correct.
However, there is an untested version here. I am not sure if the tuner can be inserted. I think it can.
Re: Grounded Experimental Delta Printer December 07, 2013 05:14PM |
owens
nicholas.seward
No issues at all putting the tuner in; there's plenty of clearance. I'm printing my third motor arm now. . .
Re: Grounded Experimental Delta Printer December 07, 2013 05:18PM |
Re: Grounded Experimental Delta Printer December 08, 2013 06:34AM |
Re: Grounded Experimental Delta Printer December 08, 2013 07:05AM |
Re: Grounded Experimental Delta Printer December 08, 2013 03:25PM |
Re: Grounded Experimental Delta Printer December 08, 2013 03:41PM |
Re: Grounded Experimental Delta Printer December 08, 2013 03:42PM |
Re: Grounded Experimental Delta Printer December 08, 2013 06:50PM |
Re: Grounded Experimental Delta Printer December 08, 2013 10:00PM |
dpharris
I had a similar thought re mounting GUS in Lisa. GUS build height could be more easily increased with a elevating base.
Maybe another silly question ... Can GUS's arms reach below the ground plane? Could we increase the printing height by mounting the base of the arms above the ground plane?
Re: Grounded Experimental Delta Printer December 09, 2013 12:13AM |
pjoyce42
dpharris
theoretically there is nothing to stop GUS from printing a depth below the plane nearly equal to its maximum height above the plane. However, the ground plane represents the widest XY plane within GUS' printing envelope. What this means is that lowering the printing plane relative to the arm mounts will shrink the maximum printable foot print, so you could print more tall skinny things, but fewer wide/long short things. In practical terms, if you lowered the printing surface too much, GUS would not be able to self replicate because the arms would be too big.
Re: Grounded Experimental Delta Printer December 09, 2013 12:20AM |
Re: Grounded Experimental Delta Printer December 09, 2013 03:44AM |
nicholas.seward
For those builders that haven't made it over to [forum.conceptforge.org] should do so. ...
Re: Grounded Experimental Delta Printer December 09, 2013 10:24AM |
Quazzer
nicholas.seward
Setting up ConceptFORGE forum is admirable and should be a great place for Conceptforge activities that you've hinted at in the past. But please keep all of your great work alive here on the Reprap forum.
Re: Grounded Experimental Delta Printer December 09, 2013 10:55AM |
Re: Grounded Experimental Delta Printer December 09, 2013 10:58AM |
Re: Grounded Experimental Delta Printer December 09, 2013 10:59AM |
Re: Grounded Experimental Delta Printer December 09, 2013 03:01PM |
Re: Grounded Experimental Delta Printer December 19, 2013 09:31PM |
Re: Grounded Experimental Delta Printer December 19, 2013 09:47PM |
