Re: RepRap 3DR Delta printer Released September 16, 2013 11:45AM |
Re: RepRap 3DR Delta printer Released September 16, 2013 06:48PM |
Re: RepRap 3DR Delta printer Released September 16, 2013 07:42PM |
Re: RepRap 3DR Delta printer Released September 17, 2013 12:43AM |
Re: RepRap 3DR Delta printer Released September 17, 2013 01:58AM |
Re: RepRap 3DR Delta printer Released September 17, 2013 05:39AM |
Re: RepRap 3DR Delta printer Released September 18, 2013 06:19AM |
Re: RepRap 3DR Delta printer Released September 18, 2013 06:50AM |
Re: RepRap 3DR Delta printer Released September 18, 2013 07:49AM |
Re: RepRap 3DR Delta printer Released September 19, 2013 12:56PM |
Re: RepRap 3DR Delta printer Released September 19, 2013 01:56PM |
Re: RepRap 3DR Delta printer Released September 19, 2013 02:16PM |
Re: RepRap 3DR Delta printer Released September 19, 2013 02:23PM |
Re: RepRap 3DR Delta printer Released September 19, 2013 03:36PM |
Re: RepRap 3DR Delta printer Released September 19, 2013 03:47PM |
Re: RepRap 3DR Delta printer Released September 19, 2013 04:00PM |
Re: RepRap 3DR Delta printer Released September 19, 2013 04:08PM |
Admin Registered: 16 years ago Posts: 1,472 |
Make up three sets of Idler bearings for the Spectra line, try to use the same type of domed bolt, washer each side (not in between the bearings) an M4 nut and M4 penny or M5 washer - if you do that it will also grip the printed cover cap nicely. - The bearings are 2 x 624ZZ types (13mm outside and a 4mm hole) you can use whatever size fits, but I doubt 608's will work and won't fit under the printed cover cap.
Re: RepRap 3DR Delta printer Released September 19, 2013 04:33PM |
Re: RepRap 3DR Delta printer Released September 19, 2013 04:41PM |
Re: RepRap 3DR Delta printer Released September 19, 2013 04:54PM |
Re: RepRap 3DR Delta printer Released September 20, 2013 08:25AM |
Re: RepRap 3DR Delta printer Released September 20, 2013 11:48AM |
Re: RepRap 3DR Delta printer Released September 21, 2013 02:39AM |
Re: RepRap 3DR Delta printer Released September 21, 2013 07:16AM |
Re: RepRap 3DR Delta printer Released September 21, 2013 07:38AM |
Re: RepRap 3DR Delta printer Released September 23, 2013 12:15AM |
Re: RepRap 3DR Delta printer Released September 23, 2013 01:10AM |
Re: RepRap 3DR Delta printer Released September 26, 2013 03:13PM |
Re: RepRap 3DR Delta printer Released September 26, 2013 04:00PM |
Re: RepRap 3DR Delta printer Released September 26, 2013 05:25PM |
