Re: RepRap 3DR Delta printer Released January 11, 2014 04:44AM |
Re: RepRap 3DR Delta printer Released January 11, 2014 05:32AM |
Re: RepRap 3DR Delta printer Released January 11, 2014 11:36AM |
Re: RepRap 3DR Delta printer Released January 21, 2014 05:27PM |
steps_per_mm = ((360/motor_step_angle) * driver_microstep) / thread_pitch = ((360/1.8) * 16 ) / 56.549 = 56.588
Re: RepRap 3DR Delta printer Released January 21, 2014 06:57PM |
#define DEFAULT_AXIS_STEPS_PER_UNIT {110.6, 110.6, 110.6, 230} #define DEFAULT_MAX_FEEDRATE {380, 380, 380, 50} // (mm/sec) #define DEFAULT_MAX_ACCELERATION {9000, 9000, 9000, 9000} // X, Y, Z, E maximum start speed for accelerated moves #define DEFAULT_ACCELERATION 3000 // X, Y, Z and E max acceleration in mm/s^2 for printing moves #define DEFAULT_RETRACT_ACCELERATION 3000 // X, Y, Z and E max acceleration in mm/s^2 for retracts #define DEFAULT_XYJERK 35.0 // (mm/sec) #define DEFAULT_ZJERK 35.0 // (mm/sec) Must be same as XY for delta #define DEFAULT_EJERK 20.0 // (mm/sec)
Re: RepRap 3DR Delta printer Released January 21, 2014 09:40PM |
Re: RepRap 3DR Delta printer Released January 22, 2014 12:11AM |
Re: RepRap 3DR Delta printer Released January 22, 2014 12:26AM |
Re: RepRap 3DR Delta printer Released January 22, 2014 12:43AM |
Re: RepRap 3DR Delta printer Released January 22, 2014 02:45AM |
It happened something similar to me on my first prints, it's probably because you set the print center to the half of global printer XY area and in delta machines it should be set at 0 (X = 0, Y = 0). In your video X tower carriage tries to move the extruder outside the print area but, of course, it never reaches the point its wants because of "dimensional limits" of arms... I don't know if you understand me. Anyway, I see you have solved the problem =)Quote
caffeinatedsoap
Not to worry about the video. I grabbed HaDe's Slic3r config file and compiled using that. It works fine. Seems that I need to go over this and learn what I did wrong. Thanks for the quick reply though.
Re: RepRap 3DR Delta printer Released January 22, 2014 02:52AM |
Re: RepRap 3DR Delta printer Released January 22, 2014 07:12AM |
Re: RepRap 3DR Delta printer Released January 22, 2014 03:14PM |
Re: RepRap 3DR Delta printer Released January 22, 2014 05:38PM |
Re: RepRap 3DR Delta printer Released January 26, 2014 09:03PM |
Re: RepRap 3DR Delta printer Released January 26, 2014 11:05PM |
Re: RepRap 3DR Delta printer Released January 27, 2014 02:34AM |
Re: RepRap 3DR Delta printer Released February 19, 2014 06:52PM |
Re: RepRap 3DR Delta printer Released February 20, 2014 01:05AM |
Re: RepRap 3DR Delta printer Released February 20, 2014 04:35AM |
Re: RepRap 3DR Delta printer Released February 20, 2014 10:24PM |
Re: RepRap 3DR Delta printer Released February 21, 2014 07:27AM |
Re: RepRap 3DR Delta printer Released February 24, 2014 09:08PM |
Re: RepRap 3DR Delta printer Released February 25, 2014 02:41AM |
Re: RepRap 3DR Delta printer Released February 25, 2014 04:34AM |
Re: RepRap 3DR Delta printer Released February 25, 2014 04:43AM |
Re: RepRap 3DR Delta printer Released February 25, 2014 04:52AM |
Re: RepRap 3DR Delta printer Released February 25, 2014 07:51PM |
Re: RepRap 3DR Delta printer Released February 27, 2014 08:29AM |
Re: RepRap 3DR Delta printer Released February 28, 2014 09:02AM |
