Re: RepRap 3DR Delta printer Released April 12, 2014 06:27PM |
Re: RepRap 3DR Delta printer Released April 13, 2014 09:27AM |
Re: RepRap 3DR Delta printer Released April 13, 2014 10:20AM |
If only one rod is slightly longer/shorter then it will lead mostly to head rotations. These will not have significant impact on bed levelling but will have impact on XY error. Since your pair of diagonal rods is not too near to each other then one diagonal rod error should not amplify much.Quote
payala
the diagonal rods are all the same length to 0.02mm, except one of them that has a difference of 0.05mm to the average
Re: RepRap 3DR Delta printer Released April 13, 2014 11:50AM |
Re: RepRap 3DR Delta printer Released April 13, 2014 04:51PM |
// Horizontal offset of the universal joints on the carriages. (This is measured from the edge of the M6mm Rod to the cent of universal joint, 14mm on Mini Delta (3DR) #define DELTA_CARRIAGE_OFFSET 14.0 // mm // Was 25.0 // mm This you may need to change if you are using a different linear bearing / rod size / bushing / or a modified carriage design. If not, 14.0mm should be correct for 3DR using normal carriages and LU6UU bearings.code source
Re: RepRap 3DR Delta printer Released April 14, 2014 10:59AM |
Re: RepRap 3DR Delta printer Released May 23, 2014 06:18AM |
Re: RepRap 3DR Delta printer Released June 02, 2014 10:47PM |
Re: RepRap 3DR Delta printer Released June 03, 2014 07:03PM |
Re: RepRap 3DR Delta printer Released June 03, 2014 11:49PM |
Re: RepRap 3DR Delta printer Released June 04, 2014 03:31PM |
Re: RepRap 3DR Delta printer Released June 06, 2014 03:15AM |
Re: RepRap 3DR Delta printer Released August 07, 2014 07:36PM |
Re: RepRap 3DR Delta printer Released August 08, 2014 01:22PM |
Re: RepRap 3DR Delta printer Released August 08, 2014 02:11PM |
misan
First thing is to tell your slicing software to position the parts at 0,0 (not at 100,100 like many cartesian printers with 200x200mm beds).
But when you home your printer x and y should be at 0,0.... what firmware are you using? have you tried starting with Richard's?
Re: RepRap 3DR Delta printer Released August 08, 2014 04:23PM |
Re: RepRap 3DR Delta printer Released August 08, 2014 07:30PM |
3DR Delta printer and Melzi V2.0 August 16, 2014 06:59AM |
Re: 3DR Delta printer and Melzi V2.0 August 18, 2014 10:25AM |
Re: 3DR Delta printer and Melzi V2.0 August 18, 2014 10:54AM |
Re: 3DR Delta printer and Melzi V2.0 August 19, 2014 02:49PM |
Re: RepRap 3DR Delta printer Released August 20, 2014 11:50AM |
Re: RepRap 3DR Delta printer Released August 24, 2014 05:46PM |
Re: RepRap 3DR Delta printer Released August 24, 2014 06:07PM |
Re: RepRap 3DR Delta printer Released August 24, 2014 11:38PM |
Re: RepRap 3DR Delta printer Released August 25, 2014 05:12PM |
Re: RepRap 3DR Delta printer Released August 26, 2014 05:20AM |
moreover, it's missing the 1.28 mm flat part around the orifice, so it practically ends with a sharp point with a flat of only 0.7-0.8mm diameter.Quote
reprap.org, chapter 8.2.2
Nozzle orifice length
Mk IV hot-ends (up to the middle of May 2012), and earlier models, had a nozzle orifice length of approximately 1.25mm.
Mk IV hot-ends (after the middle of May 2012) and Mk V hot-ends have a nozzle orifice length of approximately 0.50mm.
Note: Due to the nature of 5c collets, the nozzle orifice length can vary as much as 0.25mm.
Re: RepRap 3DR Delta printer Released August 30, 2014 07:54PM |
Re: RepRap 3DR Delta printer Released September 25, 2014 06:39PM |
Re: RepRap 3DR Delta printer Released September 26, 2014 04:58PM |
