Where to mount the extruder on Rostock Mini August 26, 2014 05:11PM |
Re: Where to mount the extruder on Rostock Mini August 26, 2014 05:36PM |
Re: Where to mount the extruder on Rostock Mini August 27, 2014 12:37AM |
Re: Where to mount the extruder on Rostock Mini August 27, 2014 01:47AM |
Re: Where to mount the extruder on Rostock Mini August 27, 2014 02:25AM |
Re: Where to mount the extruder on Rostock Mini August 27, 2014 03:41AM |
Maybe you could use a Rostock-Mini highboy kit to mount RAMPS board under the base of the printer.Quote
Replace
Thanks, this helps. however, the drawer won't make it in my little workbench space :-)
I used a Parametric Platform Clip with these settings:Quote
Replace
Ths extruder clamp is a good solution.
Please let me know which other clamp you use for the kapton covered build plate ?
Replace
Also I notice a (click-on ?) construction on one of each rod units, at the bottom... what is that ?
Re: Where to mount the extruder on Rostock Mini August 27, 2014 09:32AM |
Re: Where to mount the extruder on Rostock Mini September 28, 2014 05:14AM |
