Can i use the Rostock mini with a Ramps instead of a Sanguinololu ? December 03, 2014 10:48AM |
Re: Can i use the Rostock mini with a Ramps instead of a Sanguinololu ? December 03, 2014 02:09PM |
Re: Can i use the Rostock mini with a Ramps instead of a Sanguinololu ? December 03, 2014 02:15PM |
Re: Can i use the Rostock mini with a Ramps instead of a Sanguinololu ? December 03, 2014 02:52PM |
Re: Can i use the Rostock mini with a Ramps instead of a Sanguinololu ? December 04, 2014 01:07AM |
Re: Can i use the Rostock mini with a Ramps instead of a Sanguinololu ? December 04, 2014 01:08AM |
Re: Can i use the Rostock mini with a Ramps instead of a Sanguinololu ? December 04, 2014 09:07AM |
Re: Can i use the Rostock mini with a Ramps instead of a Sanguinololu ? December 04, 2014 05:54PM |
Re: Can i use the Rostock mini with a Ramps instead of a Sanguinololu ? December 05, 2014 02:22AM |
Re: Can i use the Rostock mini with a Ramps instead of a Sanguinololu ? December 05, 2014 10:30AM |
Re: Can i use the Rostock mini with a Ramps instead of a Sanguinololu ? December 06, 2014 12:52AM |
Re: Can i use the Rostock mini with a Ramps instead of a Sanguinololu ? December 06, 2014 01:41AM |
"It is recommended that you get approximately 13.7 N-cm (= 0.137 N-m or 1400 gf-cm or 19.4 ozf-in or 1.21 lbf-in) of holding torque (or more) for RepRap axis motors to avoid issues, although one stepper with less has been used successfully. For Wade's Geared Extruder (most widely used one as of 2012) it is suggested to use motor that is capable of creating a holding torque of at least 40 N-cm."
Re: Can i use the Rostock mini with a Ramps instead of a Sanguinololu ? December 06, 2014 09:37AM |
Re: Can i use the Rostock mini with a Ramps instead of a Sanguinololu ? December 17, 2014 04:43PM |
Re: Can i use the Rostock mini with a Ramps instead of a Sanguinololu ? December 17, 2014 06:41PM |
Re: Can i use the Rostock mini with a Ramps instead of a Sanguinololu ? December 18, 2014 02:56AM |
RipseR
Mine is 3DprinterCzar kit.
Sourcing partson mine one would be more expensive and time consuming.
@Replace
@DinoK
How is your vertical (tower) stability?
How bad is the linear bearings and Traxxas joins play?
I had to put 3 bearings per tower to minimise the play in the towers,
and I am not impressed in the Traxxas joints eather....
