Optimum parallel arm width
December 30, 2014 09:58PM
Other than ensuring the hot end and fans, etc. fit between all of the arms, what criteria should be used to determine the width of the parallel arms? Is there an optimum distance based on the print bed size?
Re: Optimum parallel arm width
December 31, 2014 04:16AM
The more far away the two parallel diagonal rods are from each other the better. It has no relation to the bed size but it is limited by the platform size. (Platform is the plastic part which holds hotend.)
The bigger distance makes both:
  • small errors in diagonal rod length less important,
  • and force load on diagonal rods smaller.
December 31, 2014 04:29AM
On the other hand, increasing the size of the effector (platform) reduces the print radius. So the effector size is a compromise between getting a good print area and getting the parallel rods far apart.
December 31, 2014 08:50PM
Interestingly enough, in my current design, increasing the width 10mm only increases the DELTA_RADIUS about 3mm. That seems like it would be a worthwhile tradeoff.
Thanks for the replies.
January 01, 2015 03:38AM
etfrench
Increasing the radius of the effector by some amount should reduce the delta radius and the print radius by the same amount, if the towers are kept in the same position. By "radius of the effector" I mean the distance between the mid point of the joints connecting a pair of parallel rods and the centre of the effector.
