Re: Delta Printer bad prints February 18, 2015 04:51PM |
Re: Delta Printer bad prints February 18, 2015 05:42PM |
#define DELTA_SMOOTH_ROD_OFFSET 150 // mm #define DELTA_EFFECTOR_OFFSET 18 // mm #define DELTA_CARRIAGE_OFFSET 40 // mm
Re: Delta Printer bad prints February 18, 2015 08:09PM |
Re: Delta Printer bad prints February 18, 2015 09:11PM |
vreihen
Seriously, with just a little practice, you can do the job quicker manually using the gray matter between your ears than the printer can do it electronically!
Re: Delta Printer bad prints February 19, 2015 04:40PM |
22:11:33.704 : echo: Steps per unit: 22:11:33.704 : echo: M92 X80.00 Y80.00 Z80.00 E120.00 22:11:33.704 : echo: Maximum feedrates (mm/s): 22:11:33.704 : echo: M203 X500.00 Y500.00 Z500.00 E200.00 22:11:33.704 : echo: Maximum Acceleration (mm/s2): 22:11:33.719 : echo: M201 X9000 Y9000 Z9000 E2000 22:11:33.719 : echo: Acceleration: S=acceleration, T=retract acceleration 22:11:33.719 : echo: M204 S900.00 T900.00 22:11:33.719 : echo: Advanced variables: S=Min feedrate (mm/s), T=Min travel feedrate (mm/s), B=minimum segment time (ms), X=maximum XY jerk (mm/s), Z=maximum Z jerk (mm/s), E=maximum E jerk (mm/s) 22:11:33.719 : echo: M205 S0.00 T0.00 B20000 X20.00 Z20.00 E20.00 22:11:33.735 : echo: Home offset (mm): 22:11:33.735 : echo: M206 X0.00 Y0.00 Z0.00 22:11:33.735 : echo: Endstop adjustment (mm): 22:11:33.735 : echo: M666 X-1.46 Y-0.63 Z-1.19 22:11:33.735 : echo: Delta Geometry adjustment: 22:11:33.735 : echo: M666 A-0.66 B0.36 C0.30 E-0.50 F-0.50 G0.00 R92.50 D216.00 H288.40 P0.00 22:11:33.735 : echo: PID settings: 22:11:33.735 : echo: M301 P22.20 I1.08 D114.00
Re: Delta Printer bad prints February 19, 2015 05:15PM |
22:56:29.659 : echo: Steps per unit: 22:56:29.659 : echo: M92 X80.00 Y80.00 Z80.00 E120.00 22:56:29.659 : echo: Maximum feedrates (mm/s): 22:56:29.659 : echo: M203 X250.00 Y250.00 Z250.00 E40.00 22:56:29.659 : echo: Maximum Acceleration (mm/s2): 22:56:29.675 : echo: M201 X2000 Y2000 Z9000 E1200 22:56:29.675 : echo: Acceleration: S=acceleration, T=retract acceleration 22:56:29.675 : echo: M204 S900.00 T900.00 22:56:29.675 : echo: Advanced variables: S=Min feedrate (mm/s), T=Min travel feedrate (mm/s), B=minimum segment time (ms), X=maximum XY jerk (mm/s), Z=maximum Z jerk (mm/s), E=maximum E jerk (mm/s) 22:56:29.675 : echo: M205 S0.00 T0.00 B20000 X20.00 Z20.00 E20.00 22:56:29.690 : echo: Home offset (mm): 22:56:29.690 : echo: M206 X0.00 Y0.00 Z0.00 22:56:29.690 : echo: Endstop adjustment (mm): 22:56:29.690 : echo: M666 X-1.46 Y-0.63 Z-1.19 22:56:29.690 : echo: Delta Geometry adjustment: 22:56:29.690 : echo: M666 A-0.66 B0.36 C0.30 E-0.50 F-0.50 G0.00 R92.50 D216.00 H288.40 P0.00 22:56:29.690 : echo: PID settings: 22:56:29.690 : echo: M301 P22.20 I1.08 D114.00
Re: Delta Printer bad prints February 20, 2015 04:44AM |
Stephanel
I tried decreasing the M666 Hxxx value by a few tens of millimeter, but this significantly worsened the print.
Re: Delta Printer bad prints February 20, 2015 03:56PM |
Re: Delta Printer bad prints February 20, 2015 04:13PM |
Re: Delta Printer bad prints February 20, 2015 09:27PM |
Re: Delta Printer bad prints February 20, 2015 10:37PM |
lokidude
I assume you have your belts tensioned correctly?
If your belts are too floppy it will cause all sorts of issues.
( I ignored belt tensions on my kossel for a while because I thought if the belts are not skipping that is good enough but then I properly tensioned my loose belts and print quality improved 100%, no more dragging over printed lines etc)
I added a set of these to my kossel to tension the belts and it is probably the biggest improvement in print quality I have seen with my printer so far.
[www.thingiverse.com]
Re: Delta Printer bad prints February 22, 2015 02:59AM |
Re: Delta Printer bad prints February 22, 2015 07:04AM |
boksbox
Try increasing Hxxx value so the nozzle moves closer to the bed. Print one layer of test print with maybe 3 perimeters, no infill. If the first layer perimeter is equal to or thicker than what you set in your slicer, the nozzle is still too high. Increase Hxxx a bit more until the first layer is slightly thinner than the set value. Then your H is set correctly.
lokidude
triplanedave
Going back to your original prints, to me, it looked like you were printing with too little filament. As already indicated, you'll need to ensure your extruder is calibrated (meaning when you tell the printer to feed 10mm of filament, the stepper actually feeds exactly 10mm) . And, you need to measure the diameter of your filament. Yes, I know it's supposed to be 1.75mm, but sometimes it's thicker, sometimes thinner. Put the actual measurement in your slicing program, and then you can usually add/subtract some percentage for fine tuning.
As to the latest image, I agree that it looks like your mechanical setup has a lot of slop in it somewhere. The direction changes are not crisp.
Re: Delta Printer bad prints February 22, 2015 08:02AM |
Re: Delta Printer bad prints February 22, 2015 08:10AM |
Stephanel
Currently I use a RAMPS 1.4 board. Apparently, the Duet is better able to approximate circles than my board is. I will see the difference once I use the Duet.
12:45:22 G32
Endstops X0.23 Y0.16 Z-0.39, radius 104.68, height 234.35
12:39:41 G32
Endstops X0.23 Y0.17 Z-0.40, radius 104.67, height 234.35
12:39:06 G32
Endstops X0.24 Y0.18 Z-0.41, radius 104.67, height 234.33
12:38:30 G32
Endstops X0.30 Y0.21 Z-0.51, radius 104.74, height 234.33
12:37:48 G32
Endstops X0.35 Y0.23 Z-0.58, radius 105.17, height 234.48
12:36:47 M666
Endstop adjustments X0.00 Y0.00 Z0.00
12:36:43 M665
Delta diagonal: 215.00, delta radius: 106.50, homed height: 234.00, bed radius: 85.000000
Re: Delta Printer bad prints February 22, 2015 08:43AM |
Re: Delta Printer bad prints February 22, 2015 10:37AM |
Stephanel
( B ) These are the start points per layer but also places where the printer briefly stopped because the RAMPS board could not follow the print speed. This can only be fixed by lowering the print speed or changing to a Duet or similar platform.
Re: Delta Printer bad prints February 22, 2015 10:46AM |
vreihen
Stephanel
Can it be that there is some kind of buffer issue if you print too fast? It seems that my printer can follow quite well, but still it blocks every once in a while (= a few times per layer) for about 100-400msec or so. It seems to wait for a commands from the PC.
Maybe something to do with the baudrate (set to 250000)?
Do you have the option to print from an SD card? Do you have a GLCD connected? Unless you can see the USB buffering stats, I'm inclined to think that you are maxing out an 8-bit controller with delta calculations. There's a reason why delta printer owners are leading the charge to 32-bit electronics, like Smoothie, Duet, RADDS, etc.....
Re: Delta Printer bad prints February 22, 2015 11:37AM |
boksbox
Stephanel
You don't need to upgrade your electronics yet. I also use RAMPS. At first I had this problem too. Try to reduce DELTA_SEGMENTS_PER_SECOND to 80. (default is 200) Some people go as low as 50.
You can print at normal speed.
also I follow this guide especially E Steps Fine Tuning here > [reprap.org]
Re: Delta Printer bad prints February 22, 2015 12:28PM |
Stephanel
Hey!
Good point! Great tip! Didn't change this value too much. Now it also prints much faster. That fast that my Bowden extruder cannot follow anymore, so I had to slow it down :-) Now, there are no issues at the border anymore, and quite frankly, I do not see much difference in the accuracy...
Re: Delta Printer bad prints February 22, 2015 03:24PM |
Re: Delta Printer bad prints February 22, 2015 11:34PM |
Kurzaa
Question, how do you know how tight the tension needs to be?
Re: Delta Printer bad prints February 24, 2015 03:15PM |
Re: Delta Printer bad prints February 24, 2015 04:18PM |
Re: Delta Printer bad prints February 25, 2015 01:29PM |
Stephanel
I continued the discussion in a second thread about calibration for ABS printing with a heated bed.
My print now looks like this:
[attachment 49959 PLAResult.jpg]
Thanks to all for your great input!
Re: Delta Printer bad prints February 25, 2015 06:38PM |
