The Delta Steel, a slightly modified Delta-Pi March 02, 2015 08:18AM |
Re: The Delta Steel, a slightly modified Delta-Pi March 09, 2015 07:07AM |
Re: The Delta Steel, a slightly modified Delta-Pi March 09, 2015 09:01AM |
Re: The Delta Steel, a slightly modified Delta-Pi March 15, 2015 01:27PM |
Re: The Delta Steel, a slightly modified Delta-Pi March 21, 2015 05:32AM |
Re: The Delta Steel, a slightly modified Delta-Pi March 21, 2015 06:52AM |
Re: The Delta Steel, a slightly modified Delta-Pi April 04, 2015 09:16PM |
Re: The Delta Steel, a slightly modified Delta-Pi April 05, 2015 07:14AM |
Re: The Delta Steel, a slightly modified Delta-Pi April 05, 2015 07:46AM |
zitman
Just watched your video. - Very impressed.
I was wondering though with your dry run, what geode file did you use for the test?
I am building a RichRap 3dr and am at the test running phase and could not get any of the files I created with Slic3r to work, presumably because they were waiting for things to get up to temperature etc. I hand crafted some simple gcode which worked but was looking for something to exercise the printer a little more.
Z
Re: The Delta Steel, a slightly modified Delta-Pi April 05, 2015 07:59AM |
Re: The Delta Steel, a slightly modified Delta-Pi April 05, 2015 10:48PM |
Re: The Delta Steel, a slightly modified Delta-Pi April 05, 2015 11:31PM |
janpenguin
It looks good.
I'm planning to build a big Delta 3D Printer, probably a variant of Mini Kossel.
Except the linear movement, I'll have replaced every thing.
The build volume in my mind is 350 mm in diameter and 500 mm in height.
Few questions:
Did you bolt down the base plate on the stand?
Is the square tube made out of stainless steel or other metal?
Is the square tube hollow or solid?
How much clearance do you have on the plastic carriage and the square tube?
Re: The Delta Steel, a slightly modified Delta-Pi April 07, 2015 11:25AM |
Re: The Delta Steel, a slightly modified Delta-Pi April 07, 2015 10:23PM |
Re: The Delta Steel, a slightly modified Delta-Pi April 07, 2015 10:30PM |
janpenguin
That's really simple and effective technique for bed level calibration.
Re: The Delta Steel, a slightly modified Delta-Pi April 10, 2015 09:26PM |
Re: The Delta Steel, a slightly modified Delta-Pi April 11, 2015 07:13AM |
Re: The Delta Steel, a slightly modified Delta-Pi April 12, 2015 02:36PM |
Re: The Delta Steel, a slightly modified Delta-Pi April 12, 2015 10:33PM |
Re: The Delta Steel, a slightly modified Delta-Pi April 12, 2015 10:51PM |
Re: The Delta Steel, a slightly modified Delta-Pi April 20, 2015 12:09AM |
Re: The Delta Steel, a slightly modified Delta-Pi April 20, 2015 01:22AM |
Re: The Delta Steel, a slightly modified Delta-Pi April 20, 2015 03:35PM |
Re: The Delta Steel, a slightly modified Delta-Pi April 20, 2015 05:28PM |
Re: The Delta Steel, a slightly modified Delta-Pi April 21, 2015 08:17PM |
Re: The Delta Steel, a slightly modified Delta-Pi April 21, 2015 08:55PM |
Re: The Delta Steel, a slightly modified Delta-Pi April 22, 2015 10:01AM |
Re: The Delta Steel, a slightly modified Delta-Pi April 22, 2015 11:52AM |
Re: The Delta Steel, a slightly modified Delta-Pi April 25, 2015 07:14AM |
Re: The Delta Steel, a slightly modified Delta-Pi April 25, 2015 07:32AM |
