Kossel mini movement problems. March 20, 2015 01:01PM |
Re: Kossel mini movement problems. March 20, 2015 01:02PM |
Re: Kossel mini movement problems. March 20, 2015 01:20PM |
Re: Kossel mini movement problems. March 20, 2015 04:18PM |
Re: Kossel mini movement problems. March 20, 2015 04:42PM |
TheTrashMan
AndrewBCN
what is the value you have configured for steps/mm (you can check that on the LCD)?
Is that under feedrate on the LCD?
Re: Kossel mini movement problems. March 20, 2015 05:06PM |
AndrewBCN
TheTrashMan
AndrewBCN
Sorry, I am not familiar with the Repetier firmware LCD menus, but it's probably labeled something like "X steps/mm", "Y steps per mm" or similar.
Re: Kossel mini movement problems. March 21, 2015 01:58AM |
Re: Kossel mini movement problems. March 21, 2015 08:37PM |
bigfilsing
i recently had to install repetier while investigating a problem on my machine and had the same speed issues
when you open repetier host and connect to your printer go to the config tab menu and 3rd one down is " Firmware Eeprom configuration" click that
( it will be greyed out if your not connected to the printer)
There you can adjust all the settings you need . You have to click OK to have the setting updated
in the pic i set my homing feed rate to 40 which gave nice smooth travel to home
[attachment 51429 homefeedrate.jpg]
Re: Kossel mini movement problems. March 21, 2015 11:44PM |
Re: Kossel mini movement problems. March 22, 2015 03:11AM |
bigfilsing
You're welcome Glad it worked.
I'm a believer in slow and steady. I see quite a few people ( on you tube) that have the homing rate way to high (IMO) and the carriages bang into the top end stops. Can't be good for frame or micro switches.
Ironically homing is the first part of printing and prints can run into many hours duration. So if a couple of seconds homing can protect frame and microswitches that has to be a good thing in my book
Cheers
Re: Kossel mini movement problems. March 22, 2015 05:12AM |
Re: Kossel mini movement problems. March 22, 2015 06:17PM |
bigfilsing
Slow homing also helps rescue things. With delta printers , by their very nature, having so many "open" belts. arms & pulleys moving, its easy to get a tool or loose filament trapped somewhere which can cause a disaster.
At least with a slow home speed you stand a chance of taking action
As a side note i really quite like the Repetier firmware. I was ( i think like many others ) a bit wary to start with, but having being forced to give it a try its actually pretty good. I especially like the configuration options from Repetier host.
But ill stick with Simplify3D and see how well it plays with Repetier FW when i have time.
Cheers
Re: Kossel mini movement problems. March 22, 2015 08:38PM |
Re: Kossel mini movement problems. March 31, 2015 08:10PM |
Re: Kossel mini movement problems. March 31, 2015 08:19PM |
Re: Kossel mini movement problems. March 31, 2015 08:46PM |
Re: Kossel mini movement problems. April 02, 2015 07:28AM |
Re: Kossel mini movement problems. April 04, 2015 11:56AM |
Re: Kossel mini movement problems. April 05, 2015 01:06AM |
Re: Kossel mini movement problems. April 06, 2015 12:51PM |
