Homemade Delta, printing problem, need professional advice March 29, 2015 03:22AM |
Re: Homemade Delta, printing problem, need professional advice March 29, 2015 10:21AM |
Re: Homemade Delta, printing problem, need professional advice March 30, 2015 12:17AM |
jmf
From the pictures I see no obvious problems, are the towers perpendicular and 90 degrees to the build surface, are they spaced evenly from each other at 120 degrees,
what firmware are you using.
Double check all the delta offsets.
I've attached my configuration.h and configuration_adv.h files in case you are using Marlin firmware, this is my setup for my delta which works perfectly.
Re: Homemade Delta, printing problem, need professional advice March 30, 2015 06:16AM |
Re: Homemade Delta, printing problem, need professional advice March 30, 2015 08:09AM |
Re: Homemade Delta, printing problem, need professional advice March 30, 2015 09:00PM |
Re: Homemade Delta, printing problem, need professional advice March 30, 2015 10:26PM |
vreihen
@jmf - My response was to them in response to them asking for someone else's Repetier EEPROM settings, *not* a criticism of anything you posted.....
Re: Homemade Delta, printing problem, need professional advice April 03, 2015 10:37AM |
Re: Homemade Delta, printing problem, need professional advice April 03, 2015 03:20PM |
