What board to replace my arduino/ramps? July 14, 2015 06:29PM |
Re: What board to replace my arduino/ramps? July 15, 2015 03:36AM |
Re: What board to replace my arduino/ramps? July 15, 2015 04:41AM |
Re: What board to replace my arduino/ramps? July 15, 2015 05:32AM |
Re: What board to replace my arduino/ramps? July 15, 2015 07:35PM |
Re: What board to replace my arduino/ramps? July 16, 2015 03:38AM |
roboprint
As I understand, it is impossible to connect RRD Full Graphics LCD to Duet board?
roboprint
Also, as I understand there is only one firmware for Duet board - RepRapFirmware. Even Repetier firmware isn't ported to Duet board?
roboprint
Is RepRapFirmware web interface is usable from smartphone (Samsung Galaxy Note 3, for example)? Is it possible to change settings (config gcodes), control printer (change filament, pause/stop, change print speed or filament % multiplicator) and do other things using web ui?
roboprint
As I understand, every time new firmware comes out I need to move printer closer to computer, connect usb cable and update firmware? Firmware update via SD/WebUI/smartphone isn't possible?
roboprint
David, is your delta auto calibration works good with simple switches as on endstops of most printers?
roboprint
Is it possible to save calibration results and reuse this data on next print without recalibration?
roboprint
I have manually detachable probe: [www.thingiverse.com] Is it possible to do this via Web UI ?
roboprint
Somebody already bought Duet boards from Replikeo?
roboprint
UPD: Is it possible to connect something like ESP8266 to Duet board to use WiFi instead of etherned to control printer?
Re: What board to replace my arduino/ramps? July 16, 2015 08:19AM |
dc42
roboprint
Do what, exactly?
Re: What board to replace my arduino/ramps? July 16, 2015 08:44AM |
roboprint
Thank you for your answers, David. Looks like I'm going to buy Duet board
PanelDue is looks very good, but I think it very expensive for me ($93 without shipping from T3P3D). Looks like it would be better to buy china-made 7'' tablet from aliexpress for $35-$40 to control the printer via Web.
dc42
roboprint
Do what, exactly?
I am sorry. As you might guess, English is not my native language. I mean if I can save the results of calibration via web interface from my phone. But you've already answered my question. This is due to the fact that I attach the probe manually by hands only when I setting up/calibrating printer (correcting enstops offsets and so on), not before every start or every print. That's because I was trying to reduce the weight of effector during printing (I must switch from original 1515 extrusions to something more rigid). But this is not such a big problem to attach the probe to calibrate before printing.
Re: What board to replace my arduino/ramps? July 16, 2015 09:36AM |
Re: What board to replace my arduino/ramps? July 16, 2015 02:16PM |
Re: What board to replace my arduino/ramps? July 16, 2015 03:32PM |
wfcook
(1) Is there some summary page where I can read the specific enhancements that ReprapFirmware has to take advantage of the 32-bit architecture and which Repetier has not implemented? Is there a good comparison page? I like the large community that Repetier has (Marlin, too), and I am marginally worried about the smaller development community for ReprepFirmware.
wfcook
(2) I recently had a stepper driver go bad, and I believe it was because of an intermittently bad connection that would effectively simulate disconnection and reconnection of the motor when the power was on. Since the drivers are built into the duet, this would have been a real problem, unless they are protected from this. Are they?
wfcook
(3) I consider one of the advantages of the faster processor to be the ability to run higher microstepping rates. While this does reduce motor torque and doesn't really increase print quality, I find that it makes the printer a lot quieter, and I often have torque to spare. What is the main advantage of having the drivers built into the board?
wfcook
(4) I am considering trying to build a temperature-controlled enclosure. Would ReprapFirmware be able to handle this?
Re: What board to replace my arduino/ramps? July 16, 2015 04:11PM |
Re: What board to replace my arduino/ramps? July 16, 2015 04:14PM |
Re: What board to replace my arduino/ramps? July 16, 2015 04:31PM |
roboprint
Replikeo is selling Duet board with external linear 5V regulator. If I understand correctly, the board already has the regulator (5V 2A buck converter based on A4403 chip). Why they sell board with external the regulator?
Photo: [www.replikeo.com]
Re: What board to replace my arduino/ramps? July 16, 2015 05:15PM |
roboprint
wfcook
Last question...will it support CoreXY ?
Re: What board to replace my arduino/ramps? July 17, 2015 03:06AM |
dc42
wfcook
You can indeed damage drivers on the Duet by connecting or disconnecting stepper motors with power applied. Later versions of the Duet from RepRapPro (not sure about boards from Replikeo) use locking Molex connectors for the stepper motors.
Re: What board to replace my arduino/ramps? July 17, 2015 04:09AM |
Re: What board to replace my arduino/ramps? July 17, 2015 06:48AM |
Re: What board to replace my arduino/ramps? July 17, 2015 04:14PM |
Re: What board to replace my arduino/ramps? July 17, 2015 04:41PM |
nick0
Can someone Tell me the reference of the molex connectors? Are they 2,56mm spaced ?
Thanks for your help
Re: What board to replace my arduino/ramps? July 17, 2015 04:58PM |
Re: What board to replace my arduino/ramps? July 20, 2015 11:31AM |
dc42
Re: What board to replace my arduino/ramps? July 28, 2015 04:03AM |
Re: What board to replace my arduino/ramps? July 28, 2015 04:22AM |
nick0
I just receved my duet from replikeo.
They put a sticker to hide the "think3dprint" and "reprappro" logo?
They also could have clean the board... there are a lot of soldering flux traces (not a big deal, but not clean) but there are so much cheaper!
I'll try it soom
Re: What board to replace my arduino/ramps? July 28, 2015 04:27AM |
Re: What board to replace my arduino/ramps? July 28, 2015 07:14AM |
wfcook
dc42
In my case, the problem was a bad crimp on one of the pins in a locking connector, which would go intermittently bad for a fraction of a second. Pretty soon the driver was blown.
Re: What board to replace my arduino/ramps? July 28, 2015 07:30AM |
Re: What board to replace my arduino/ramps? July 28, 2015 12:41PM |
nick0
dc42> first thanks for your work!
second, i have follow your blog topic on installing the duet firmware and config files. I don't have a lot of time to work on it now, but i did a few test.
When i connect on the board on its IP I just have a blank page, i have to write the full path (ip/OrmerodWebControl-master/reprap.htm) to get the web interface? is it normal or do i have to put the content of OrmerodWebControl-master on the www folder and rename reprap.htm in deflaut.htm ?
thanks for your help
Re: What board to replace my arduino/ramps? July 28, 2015 01:38PM |
Re: What board to replace my arduino/ramps? July 29, 2015 06:09AM |
