300mm Heatbed Options September 24, 2015 05:05PM |
Re: 300mm Heatbed Options September 24, 2015 05:14PM |
Re: 300mm Heatbed Options September 25, 2015 02:29AM |
Make_3D
Hi All,
So I have got my delta printer working with PLA but I want to print with ABS so I need a 300mm heatbed, I have had a look around and am leaning towards the mains powered silicone heatbed, are these any good? What would I need to hook it up to the Ramps 1.4? is it something that can be bought or is it something that has to be made?
This is the one I was looking at [www.aliexpress.com]
Cant see any reason why this wouldnt work in the UK, Voltage is about right.
I also saw this one [www.aliexpress.com]
Much cheaper but I doubt it would heat up that fast only being 12v.
What do you guys think?
Re: 300mm Heatbed Options September 25, 2015 05:15AM |
Re: 300mm Heatbed Options September 25, 2015 06:46AM |
Make_3D
Thanks for the responses,
is this the relay i would need? [www.ebay.co.uk]
So if i combine that relay with this heatbed it should work fine? [www.aliexpress.com]
From a safety standpoint, with the heatbed being powered by the mains in a printer with a metal frame is slightly worrying, as long as the frame is earthed with a fuse it should be okay?
Re: 300mm Heatbed Options September 25, 2015 06:51AM |
Re: 300mm Heatbed Options September 25, 2015 07:29AM |
Re: 300mm Heatbed Options September 25, 2015 10:23AM |
Re: 300mm Heatbed Options September 25, 2015 04:54PM |
Re: 300mm Heatbed Options September 25, 2015 06:04PM |
Re: 300mm Heatbed Options September 26, 2015 02:06AM |
dc42
I still use the thermistor that is embedded in the heater. The Duet has filtering on the thermistor inputs, so mains pickup isn't a problem. OTOH the thermistor is embedded in the heater pad instead of being in direct contact with the aluminium bed plate, so it over reads. I use 70C indicated temperature for PLA, and 130C for ABS.
Re: 300mm Heatbed Options September 26, 2015 04:34AM |
dougal1957
on the subject of the thermistor that is embedded I now have a full temp sheet for the one that Keenovo use and the B Value is quoted at 25/50 to be 3950.
How would I work out an adjusted b Value to get closer to say 100 degrees as a happy medium between PLA and ABS.
I have attached the table here if you would like it?
Doug
