Talk me out of (or into) a Delta November 01, 2015 01:17PM |
Re: Talk me out of (or into) a Delta November 01, 2015 02:41PM |
Re: Talk me out of (or into) a Delta November 01, 2015 02:45PM |
MightyMouth
Hey all,
I have decided to delve into the world of 3D printing. I was previously waiting for the Wally from Nicolas Seward and was signed up for the beta but that never seemed to materialise. After having had a good look around I feel a Large Delta printer fits the bill for me, I think I understand the pros and cons and don't mind a but of tinkering if I get the results I want. My main criteria in order of importance are cost, print size, print quality, print speed, ease of use and printer size. This seems to point to a delta to me but I am willing to be be persuaded if it can be argued that I can get the same print size / print speed from a similar priced non-delta printer.
I am in the UK and I have been looking at the Kossel XL from [builda3dprinter.eu] though I have also been also looking at a self build following this blog.
I really don't want to spend more than £400 but would if there was a real benefit.
I would like something as future proof as possible so the ability to add multi colour printing and print using other materials like nylon would be a bonus.
Re: Talk me out of (or into) a Delta November 01, 2015 02:47PM |
hercek
I would say it is only about one thing: Do you want to print quickly or not?
And my suspicion is that it needs to be delta with ball angle joints and not magnetic joints. I do not know whether magnetic joints can handle high accelerations. People did not respond to my questions about this.
Re: Talk me out of (or into) a Delta November 01, 2015 03:00PM |
Re: Talk me out of (or into) a Delta November 01, 2015 03:05PM |
hercek
Do you have some number how many mm/s² can N52 magnets do?Quote
thevisad
It can, you need to get the heavier duty magnets, most of the ones that are sold are the lighter versions. I think it's the N52 that support the high accelerations.
Re: Talk me out of (or into) a Delta November 01, 2015 03:14PM |
Yep. I would say one should go delta only when speed is important. And in such a case it is important to get:Quote
thevisad
Metal corners cannot be stressed enough for both stability and longevity reasons.
Re: Talk me out of (or into) a Delta November 01, 2015 03:26PM |
OK, that would mean that their steppers started to skip sooner before the magnetic joitns started to rattle. Would be good to know what steppers and at what current.Quote
thevisad
There is a conversation in the seemecnc forums regarding that, showing that the n52 (the standard magnet) could lift more then the n42, I do not recall anything about a particular mm/s though. Last I read, the n42 couldn't handle speeding up any faster, but when he switched out to the n52 he wasn't able to cause them to fail.
Re: Talk me out of (or into) a Delta November 01, 2015 03:37PM |
hercek
If you want to print quickly then you also need high acceleration especially if your models will have a lot of holes. And if you need high accelerations then you need a delta. And my suspicion is that it needs to be delta with ball angle joints and not magnetic joints. I do not know whether magnetic joints can handle high accelerations. People did not respond to my questions about this.
Well and maybe, just maybe, if you want to print very tall objects then delta can make a sense too. Kind of.
Otherwise you want a cartesian printer. If you are OK with a small then P3Steel looks like a best option. If you want something bigger then some version of CoreXY looks best to me. Cartesians are much easier to calibrate, more space efficient, do not need so much CPU resources (you can go for a cheap electronics), typically have bowden-less extruder (so no bowden related problems with precise volume of material to extrude). The only problem of cartesians is that they will not be able to achieve so high accelerations as deltas can do.
Re: Talk me out of (or into) a Delta November 01, 2015 03:43PM |
hercek
thevisad
Still I would like to hear some example numbers for maximum accelerations achieveable with magnetic joints. Jerk and accelerations are important ... not so much the speed itself. What is quick is too subjective without the numbers.
The point is that Nema17 steppers can exert about 50N force at the arms at the worst case scenario. There are two arms at one tower. So for magnetic joints to be comfortably in the good enough zone one magnet must be able to hold at least about 25N of force. I do not know how well a N52 magnet holds. And will it not be too heavy when it holds well?
25N of force is no problem for ball joints. Of course one must select joints which do not have play. If the joints are not sold completed (like traxxas) then one must be very sure to put them together properly (there rare some instructions about hot/cold water bath and who knows what). I just bought joints which are sold completed.
Re: Talk me out of (or into) a Delta November 01, 2015 07:20PM |
Re: Talk me out of (or into) a Delta November 02, 2015 03:20AM |
Re: Talk me out of (or into) a Delta November 02, 2015 04:00AM |
o_lampe
Magnets with radial magnetic orientation instead of the common axial orientation would be best in terms of magnetic flux.
But I haven't heard of such, yet.
-Olaf
Re: Talk me out of (or into) a Delta November 02, 2015 06:07AM |
dc42
hercek
I prefer delta printers to Cartesians. I have great respect for hercek because it was his wxMaxima script that inspired me to develop my least squares delta auto calibration routine. However, I disagree with two of the points he makes:
1. A delta printer is easy to calibrate if it runs RepRapFirnware and you have a working Z probe. You can do it with three iterations of bed probing, taking less than 30 seconds each, followed by copying the resulting parameters into the configuration file. Total time less than 10 minutes.
2. Cartesian printers are more space-efficient in height, but delta printers are more space-efficient in desk area. The smaller desk space taken by a delta printer is IMO a big advantage over the Cartesian printer, unless you want such a large build area that the height becomes a problem.
Here is some additional advice I have to offer:
1. For a given layer height, the larger a delta printer is, the greater accuracy you need when building it. Auto calibration (or manual calibration) cannot correct perfectly for leaning towers, or the rods not being quite the same length, or the rod spacing not being the same at both ends. My delta now has a print area 300mm in diameter. I would not want to go larger than that at 0.2mm layer height or lower until I have more experience.
2. CoreXY and HBot designs are the most space-efficient of all, so are probably best for really large printers.
3. For £400 including VAT, you won't be able to buy a good kit for a large printer. You can buy a cheap Chinese kit for that, but you will spend more money upgrading it to get it to print well. Or you could buy a small Cartesian such as the RepRapPro Huxley or small Delta such as RepRapPro Fisher. If you can afford more, talk to Think3DPrint3D about their large delta beta program, which is based on my large Kossel design (see the link in my signature). Or buy their Mini Kossel rev. 3 kit and convert it to a large Kossel later.
Re: Talk me out of (or into) a Delta November 02, 2015 06:46AM |
Re: Talk me out of (or into) a Delta November 02, 2015 07:13AM |
Re: Talk me out of (or into) a Delta November 03, 2015 06:33AM |
Re: Talk me out of (or into) a Delta November 03, 2015 11:53AM |
Re: Talk me out of (or into) a Delta November 03, 2015 02:43PM |
Re: Talk me out of (or into) a Delta November 03, 2015 04:00PM |
dc42
I don't think you will be disappointed with a kit from T3P3. Regarding the PanelDue, I would love to sell you one, however if you are happy to control the printer using the web interface from a PC, laptop, tablet or smartphone then you don't need it. The vast majority of people with Duet-controlled printers don't have a PanelDue. It's different with RAMPS electronics, because then you don't have the built in SD card socket and web interface. You can always add a PanelDue later if you want.
Re: Talk me out of (or into) a Delta November 03, 2015 04:19PM |
Re: Talk me out of (or into) a Delta November 03, 2015 04:25PM |
Re: Talk me out of (or into) a Delta November 03, 2015 05:48PM |
Re: Talk me out of (or into) a Delta November 04, 2015 02:26AM |
n8bot
One point about the web interface is that it is not as reliable as the panel due. The ajax connection can be lost, it doesn't always respond/refresh, and sometimes the server doesnt resolve at all. The paneldue ensures you always have control and readouts from the machine.
Re: Talk me out of (or into) a Delta November 04, 2015 02:33AM |
Re: Talk me out of (or into) a Delta November 04, 2015 02:44AM |
dc42
Most people find the web interface reliable, only a few have problems with it. n8bot, if the server doesn't always resolve using its netbios name, try giving it a fixed IP address instead. Yes you can use the USB connection instead. These days I only use it for debugging firmware changes.
Re: Talk me out of (or into) a Delta November 04, 2015 09:16AM |
Re: Talk me out of (or into) a Delta November 04, 2015 09:40AM |
Re: Talk me out of (or into) a Delta November 04, 2015 02:39PM |
Re: Talk me out of (or into) a Delta November 05, 2015 03:53PM |
dc42
