Aligning linear guides November 28, 2015 09:02AM |
Re: Aligning linear guides November 28, 2015 09:06AM |
Re: Aligning linear guides November 28, 2015 12:46PM |
Re: Aligning linear guides November 28, 2015 05:41PM |
Re: Aligning linear guides November 29, 2015 12:17AM |
Re: Aligning linear guides December 02, 2015 04:03AM |
Re: Aligning linear guides December 02, 2015 04:18AM |
Re: Aligning linear guides December 02, 2015 07:47AM |
Re: Aligning linear guides December 02, 2015 08:21AM |
the_digital_dentist
I see a lot of metal or plastic corner gussets on a lot of machines made from T slot aluminum. I haven't seen one of those machines that takes advantage of the T slot design to screw the corners together. I'm trying to figure out what those gussets are actually doing in those builds. Are they being used to square the frame? Are the typical 20mm square T-slot beams so flexible they need the extra extra support to control flex? If so, why are the gussets so small? If so, why not use larger cross section T-slot extrusions?
Re: Aligning linear guides December 02, 2015 11:03AM |
Re: Aligning linear guides December 02, 2015 11:57AM |
Re: Aligning linear guides December 02, 2015 02:00PM |
the_digital_dentist
Re: Aligning linear guides December 02, 2015 08:39PM |
Re: Aligning linear guides December 02, 2015 09:33PM |
