The first beta machine based on DC42's Kossel XL December 03, 2015 05:15PM |
Re: The first beta machine based on DC42's Kossel XL December 03, 2015 09:03PM |
Re: The first beta machine based on DC42's Kossel XL December 04, 2015 04:32AM |
Re: The first beta machine based on DC42's Kossel XL December 04, 2015 05:10AM |
Re: The first beta machine based on DC42's Kossel XL December 04, 2015 05:33AM |
Re: The first beta machine based on DC42's Kossel XL December 06, 2015 10:42AM |
Re: The first beta machine based on DC42's Kossel XL December 06, 2015 11:50AM |
Re: The first beta machine based on DC42's Kossel XL December 06, 2015 12:38PM |
Re: The first beta machine based on DC42's Kossel XL December 06, 2015 01:31PM |
Re: The first beta machine based on DC42's Kossel XL December 11, 2015 05:03PM |
Re: The first beta machine based on DC42's Kossel XL December 11, 2015 05:23PM |
Re: The first beta machine based on DC42's Kossel XL December 11, 2015 07:38PM |
Re: The first beta machine based on DC42's Kossel XL December 12, 2015 05:00AM |
Re: The first beta machine based on DC42's Kossel XL December 12, 2015 11:12AM |
Re: The first beta machine based on DC42's Kossel XL December 12, 2015 11:32AM |
MightyMouth
OK So my printer is now powered on and I can access the web interface. I have homed the axes successfully and have been reading DC42's blog post Upgrading the Mini Kossel to Duet Electronics Part 4: the Z probe but am confused what M558 parameter I should be using. My kit comes with David's IR Probe so do I use P1 or P2? My config is currently set to M558 P1 X0 Y0 Z0 which was configure by t3p3 as default I suppose but it seems to me it should possibly be M558 P2 X0 Y0 Z0.
Re: The first beta machine based on DC42's Kossel XL December 12, 2015 11:39AM |
Re: The first beta machine based on DC42's Kossel XL December 12, 2015 01:57PM |
Re: The first beta machine based on DC42's Kossel XL December 12, 2015 02:51PM |
Re: The first beta machine based on DC42's Kossel XL December 12, 2015 03:55PM |
Re: The first beta machine based on DC42's Kossel XL December 12, 2015 04:29PM |
MightyMouth
Ah great thanks, I thought you had to do the macros to get close before using the auto calibration.
Re: The first beta machine based on DC42's Kossel XL December 12, 2015 05:37PM |
M558 P1 X0 Y0 Z0
M558 P1 X0 Y0 Z0 H25 T500?
Re: The first beta machine based on DC42's Kossel XL December 12, 2015 06:03PM |
MightyMouth
OK so I don't have an H or T parameter beside M558, I assume I just add them to override defaults?
Mine looks likeM558 P1 X0 Y0 Z0
Should I make it look likeM558 P1 X0 Y0 Z0 H25 T500?
MightyMouth
Also where you say "G31 Z parameter - measure the IR sensor trigger height (between nozzle and bed) at bed centre and use that" is that with or without the copy paper in place?
Re: The first beta machine based on DC42's Kossel XL December 12, 2015 06:11PM |
Re: The first beta machine based on DC42's Kossel XL December 12, 2015 06:59PM |
Diagonal 350.00, delta radius 178.05, homed height 495.90, bed radius 140.0, X 0.15°, Y 0.12°, Z 0.00°
Endstop adjustments X-0.28 Y0.44 Z-0.17
Re: The first beta machine based on DC42's Kossel XL December 13, 2015 03:30AM |
MightyMouth
ok so after 4 runs it settled down so I ran M665 and M666 which came back
Diagonal 350.00, delta radius 178.05, homed height 495.90, bed radius 140.0, X 0.15°, Y 0.12°, Z 0.00°Endstop adjustments X-0.28 Y0.44 Z-0.17
I don't know what to do with the X 0.15°, Y 0.12°, Z 0.00° after the bed radius.
Also these are the numbers when cold, should I use these or the numbers after the hot run.
Re: The first beta machine based on DC42's Kossel XL December 13, 2015 06:51AM |
Re: The first beta machine based on DC42's Kossel XL December 13, 2015 07:04AM |
Re: The first beta machine based on DC42's Kossel XL December 13, 2015 07:09AM |
Re: The first beta machine based on DC42's Kossel XL December 13, 2015 12:54PM |
Re: The first beta machine based on DC42's Kossel XL December 13, 2015 01:54PM |
