Maximum angle for arms? Is it actually 90 degrees??? December 03, 2015 05:59PM |
Re: Maximum angle for arms? Is it actually 90 degrees??? December 03, 2015 06:04PM |
Re: Maximum angle for arms? Is it actually 90 degrees??? December 03, 2015 07:54PM |
Re: Maximum angle for arms? Is it actually 90 degrees??? December 04, 2015 01:14AM |
patrickrio
that is what I thought.... Wanted to make sure that there wasn't some unknown issue I did not know about....
Actually, thinking about the geometry, since all 6 arms are equal length, and since you want the shortest length of arms, 90 degrees is the angle that minimizes arm length for a given print diameter and effector size.
Re: Maximum angle for arms? Is it actually 90 degrees??? December 04, 2015 04:11AM |
Re: Maximum angle for arms? Is it actually 90 degrees??? December 04, 2015 05:08AM |
patrickrio
Re: Maximum angle for arms? Is it actually 90 degrees??? December 04, 2015 06:35PM |
Re: Maximum angle for arms? Is it actually 90 degrees??? December 04, 2015 08:28PM |
Re: Maximum angle for arms? Is it actually 90 degrees??? December 05, 2015 02:10PM |
Re: Maximum angle for arms? Is it actually 90 degrees??? December 10, 2015 03:44PM |
Re: Maximum angle for arms? Is it actually 90 degrees??? December 10, 2015 11:09PM |
Re: Maximum angle for arms? Is it actually 90 degrees??? December 11, 2015 03:07AM |
DrDoggy
going past 90deg would be impractical , since the nozzle position of 91deg would be the same as 89 deg (trig stuff)
