Kossel Mini bed leveling problem December 14, 2015 04:22PM |
22:10:45 CET M666 Endstop adjustments X1.28 Y0.45 Z-1.73 22:10:43 CET M665 Diagonal 215.00, delta radius 105.11, homed height 241.53, bed radius 85.0, X 0.49°, Y 1.19°, Z 0.00° 22:10:35 CET G32 Calibrated 6 factors using 10 points, deviation before 0.163 after 0.113 22:09:48 CET M666 Endstop adjustments X1.41 Y0.12 Z-1.53 22:09:47 CET M665 Diagonal 215.00, delta radius 105.12, homed height 241.59, bed radius 85.0, X -0.56°, Y 0.48°, Z 0.00° 22:09:42 CET G32 Calibrated 6 factors using 10 points, deviation before 0.172 after 0.135 22:08:53 CET M666 Endstop adjustments X1.18 Y0.44 Z-1.61 22:08:52 CET M665 Diagonal 215.00, delta radius 105.01, homed height 241.57, bed radius 85.0, X 0.32°, Y 1.14°, Z 0.00° 22:08:34 CET G32 Calibrated 6 factors using 10 points, deviation before 0.350 after 0.088
Re: Kossel Mini bed leveling problem December 14, 2015 06:05PM |
Re: Kossel Mini bed leveling problem December 17, 2015 05:31AM |
Re: Kossel Mini bed leveling problem December 17, 2015 10:26AM |
Re: Kossel Mini bed leveling problem December 17, 2015 04:21PM |
; Auto calibration routine for delta printers ; Before running this, you should have set up your zprobe Z offset to suit your build, in the G31 command in config.g. M561 ; clear any bed transform, otherwise homing may be at the wrong height G31 X0 Y0 ; don't want any probe offset for this G28 ; home the printer ;*** Remove the following line if your Z probe does not need to be deployed ;M98 Pdeployprobe.g ; deploy the mechanical Z probe ; The first time the mechanical probe is used after deployment, it gives slightly different results. ; So do an extra dummy probe here. The value stored gets overwritten later. You can remove this if you use an IR probe. ;G30 P0 X0 Y0 Z-99999 ; Probe the bed and do 6- or 7-factor auto calibration G30 P0 X-66 Y-30 Z-99999 ; X tower G30 P1 X0 Y-66 Z-99999 ; between X and Y towers G30 P2 X66 Y-30 Z-99999 ; Y tower G30 P3 X46 Y42 Z-99999 ; between Y and Z towers G30 P4 X6 Y62 Z-99999 ; Z tower G30 P5 X-56 Y28 Z-99999 ; between Z and X towers G30 P6 X-36.8 Y-21.25 Z-99999 ; half way to X tower G30 P7 X36.8 Y-21.25 Z-99999 ; half way to Y tower G30 P8 X0 Y42.5 Z-99999 ; half way to Z tower G30 P9 X0 Y0 Z-99999 S6 ; centre, and auto-calibrate 6 factors ;*** Remove the following line if your Z probe does not need to be retracted ;M98 Pretractprobe.g ; retract the mechanical Z probe G1 X0 Y0 Z150 F15000 ; get the head out of the way of the bed
Re: Kossel Mini bed leveling problem December 17, 2015 05:20PM |
Re: Kossel Mini bed leveling problem December 18, 2015 05:08PM |
Re: Kossel Mini bed leveling problem December 18, 2015 06:22PM |
Re: Kossel Mini bed leveling problem December 19, 2015 06:15AM |
Re: Kossel Mini bed leveling problem December 19, 2015 07:03AM |
jschenck
I first noticed that indeed the bearing spacing at the carriages was approx. 0.4mm less than the bearing spacing on the effector (strange, because all parts came from the same vendor). However, as this was the same over all three rod pairs, I suppose this can't be the problem.
Re: Kossel Mini bed leveling problem December 19, 2015 12:47PM |
Re: Kossel Mini bed leveling problem December 19, 2015 02:18PM |
Re: Kossel Mini bed leveling problem December 19, 2015 06:31PM |
Re: Kossel Mini bed leveling problem December 20, 2015 09:15AM |
Re: Kossel Mini bed leveling problem December 20, 2015 10:15AM |
tomasf
Ooh. That makes sense. Shoot, I wish I had read that before. Oh well, I'm off to get some heat-resistant paint and hope there's enough adhesive tape left on the roll so I don't have to order another one from half-way across the planet.
Thanks again!
Re: Kossel Mini bed leveling problem December 22, 2015 09:01PM |
Re: Kossel Mini bed leveling problem December 23, 2015 05:00AM |
Ace67aod
I wanted to piggy back off this post because its topic is related to mine.
So I have this very same setup (Hardware and software) everything works but when i start a print im not sure if i have the wrong starting gcode in my slicer or whaT but my printer head smashes into the bed every time. My IR sensor works and it runs through the entire probing fine it seems like its not saving the autocal adjustments? or should i be running autocal using slicer in the starting gcode?
Im not very familiar with how to set these starting g codes so this could very well be my problem.... but after calibration i should just be including the things like heaters on and autocal?
Re: Kossel Mini bed leveling problem December 23, 2015 07:42PM |
Re: Kossel Mini bed leveling problem December 24, 2015 03:02AM |
Re: Kossel Mini bed leveling problem December 25, 2015 11:23PM |
Re: Kossel Mini bed leveling problem December 26, 2015 02:33AM |
Re: Kossel Mini bed leveling problem December 26, 2015 07:31PM |
Re: Kossel Mini bed leveling problem December 27, 2015 02:05AM |
Re: Kossel Mini bed leveling problem December 28, 2015 11:06PM |
